leeRS Clio Sport 172 ph2
SharpyClio
@SharpyClio what was the duct you purchased to do yours with?
Looks a bit more of an oval shape.
It’s was an intake from a Vauxhall Astra
Decent fit, just need to get decent adhesive as mine came away as it never seemed to set: I was going to redo it but got the blanks. Should do it really in case of a wet track day and I need lights.
lee M4RSH
Perfect, thanks!
Still got a few weeks until the respray is completed so need little odd jobs to do so things one of them.
Presuming you just separated the lens, drilled a hole and stuck the duct in place.
Reseal the lens and good to go?
SharpyClio
Perfect, thanks!
Yep. I got some small metal clips to help hold the lens to the backing while it set but I just left them in place.
lee M4RSH
@SharpyClio ehats the technique to separating the lens?
Is it just these clips holding it in place which seem to be glued on?
Will a hairdryer be enough heat or do I need to put it in the oven?
Also - did you remove the light behind where the duct is and if so, how did it look inside the light fitting when you had finished.
