Kangoo Compact (aka Racevan3)
Brigsy
  T.Turbo
You mad man, love it
A crack habit would be cheaper than owning this but i might aswell send it. See if my own engine build will make the numbers.
There's the new Gen 2 G series now too.
Do a G25-700.
350-700bhp range.
Cheers mate ill have a look. I think 400hp will be the sweet spot on the street but be nice to have an efficient setup to make good numbers on high boost.
It's a f**king riot with a standard turbo... Let alone a Garrett šŸ˜‚
Honestly needs no more power but ill send it regardless :LOL: Cant wait to see what it goes like on a g series setup.
Brigsy
  T.Turbo
Road trip to Grimbsy yesterday, for car parts obvs.
Donny services was pretty s**t.
Loads of 6 gear cruising.
20t hybrid makes all the noise.
Just the right size for 4x rims with no tyres :LOL:
260 mile round trip. Easy driving apart from lack of air con.
Thanks for reading!!
Brigsy
  T.Turbo
Used the Kangoo to take my track wheels down to local garage for tyre swap. 4x 18" wheels and 4x 18" tyres is a bit of a squeeze :LOL:
Brigsy
  T.Turbo
Updates
Kangoo headlamps were starting to yellow/uv fade on the top. Not the worst but longer you leave it, the harder it is to get them nice again.
Hard to get a pic but on their way at the top.
No wetsanding required, panel wipe, cutting compound / medium pad on da polisher, followed by final polish using finishing pad.
15 mins, done.
Used a ceracote trim wipe on them to protect from uv.
Whilst the wipe was still wet i done the scuttle panel, as the wipes go quite far if your fast.
From faded grey to black again.
Small improvements.
Big job on yesterday moving some gear too.
No updates on the turbo setup yet. Still researching but think ive got a plan;)
Brigsy
  T.Turbo
Updates.
Went to Trax and back in it beginning of the month. No dramas.
Todays job was reprogramming epas. I found out a while back that you can adjust the epas assist on meg2 rs epas on rstuner. Steering is a bit light at speed on the Kangoo and a bit van like so was room for improvement. I made enquiries with Henk to see if a module was possible for the kangoo, but he did not have one for NSK eps ecu so idea was shelved.
Talking to Neil Brooke (Rs independant specialist) yesterday and he said he had seen the same settings on meg epas ecu via Renolink, with settings 1-5 available but unsure what it done. With this in mind i assumed that it might be doable via Renolink on the Kangoo as very similar.
Hooked up Renolink and searched for eps.
Looked in select tuning and found that adjustment was possible, but no idea what mode is what. Its set at 3 originally, and workshop manual flirts around it saying you config it to a certain model but no more info. I assume this is wheel size/engine size specific.
With this in mind i plugged Renolink into my Meg r26 to see what that was set at. Noted number 1, steering feels good on it so assume that it is dulled down for weighted feel.
R26, diff menu same flavour.
With this in mind, i took the send it approach and wrote number 1 to the Kangoo. Took it for test drive and noted steering felt great, loads more weighted feel at slower speeds. With this in mind, i tried every setting to see what they done, and number 5 is very light around the streets. Number 3 is middle ground.
Settled at number 2 which feels great. Light enough for easy driving at low speeds, and great at speed giving more confidence.
Ive also seen that you can do what looks to be custom speed settings/assist. I dont think this is needed for me as its light at low speeds/weighted at higher as oem, but means you could dial in a track car or whatever.
A nice little win. Feels more like a megane when driving which is great and a lot more confidence inspiring at speed.
Also handed the arse to a bam 225 audi tt exiting a roundabout, was right up my arse pushing me. Assume it was stock as it went backwards so fast it was comical..the look of shock/wtf happened on the drivers face was class. Sunday drivers eh.
Klumpy Dumpy
My old dCi had the cup pack so the steering had variable assistance
At low speeds it was super light and at high speeds it was heavy. It was proper good, deffo worth looking at if you can code it in
Brigsy
  T.Turbo
Thats the one mate. It seems to work exactly like r26 on setting 2. Massive improvement as it was too van like before with loads of assist.
Brigsy
  T.Turbo
Forgot to add, went to U pull it on Sat for a bonnet matt for the 250 (ours is fucked for some bizarre reason) and new is NLA.
Sniffing round i found a complete mk3 megane 2.0tce 180. This engine is visually the same as a 250 with diff turbo etc. Anyway i stripped loads of spares off the engine for the price of a drink.
Inlet is to be modified for kangoo, little idea i have in mind.
Got the continental ems3110 ecu. Its a tce but id imagine its very similar to 250 albeit diff software. I reckon i can de immobilise one and sync up to kangoo.
I had a discussion with Chris @ Efi last week regarding ecu upgrade to 250 ems 3110, for vvt etc. We both agreed the ecumaster black that i have in stock would be a better option for more safety and features.
But still as a project, i might see if i can do the immobiliser and sync. If so it would be a cheap way to run vvt and boost control on a meg conversion. Need to find a cheap tool to bench read the ecu and go from there.
Klumpy Dumpy
U-Pull-It is one of the last places you can go and strip stuff yourself and not have someone in a hi-viz watching over your shoulder when you're stripping something off
They've always been spot on with me and my dad every time we've been. Pulled the head off a MK4 Astra once and the bloke on the checkout was amazed that it was done so fast and nothing has been taken off with a hammer🤣
Brigsy
  T.Turbo
Agreed u pull it are spot on, yards like that have dissappeared. What turned into a half hour visit ended up being 2 hours of *carefully removing a meg front end (brute force).
I do miss the days of going down the breakers and getting bits for projects but all the good ones near me have closed. Used to be 4 cars high in one and it was sketchy as climbing up to the top. Good buzz when car was rocking all over.
There is a local large jap breakers near me and they had a mk2 meg in so popped down recently. Ive been looking for a qtr panel to cut. I could see the f**king car from the office and asked if he would do me a cut. Only answer i got was no and he didnt say anything else, no explanation was bizarre. Just walked out the door and went at that point.
Brigsy
  T.Turbo
Updates.
Cleaned and a coat of c2v3 and a run out.
Still mocking up parts for the g25 setup. Tried the trophys tial mvs wastegate on the nortech manifold. It does not fit the downpipe dump tube flange as its different, so have ordered a turbosmart compgate 40 to save chopping the downpipe.
Will order a turbo soon. 2x options.
G25-550 which will prob limit hp to around 450.
G25-660 which should give better peak hp with slightly slower response. From looking at dyno graphs there is only a couple of hundred rpm in it though so hardly nothing.
Decisions, decisions.
Brigsy
  T.Turbo
I think its going to be 660.
Updates
Changed egt bosses on the Nortech manifold to a more common size of 1/8 NPT so i can run motorsport inconel egt sensors.
Purchased a new turbosmart compgate 40 which bolts straight on.
Just turbo to order now. Oil return fittings have been ordered so can mock up on my spare engine once turbo is here.
In other news i have been looking into a larger throttle to suit the 250 inlet manifold. I have been using the 40mm 225 throttle body for years with a home made adaptor plate to fit to the 250 inlet. This works with oem ecu fine, but as going over to ecumaster black, i can run any dbw throttle so makes sense to get rid of the small throttle and adaptor plate.
Main reason to go up in size, is pressure differential pre and post throttle. From looking at the logs, approx 1.5psi is lost on current setup, making the turbo work a little harder to make required boost.
Log showing pressure differential, boost pressure sensor is pre throttle, map on inlet. Readings in mbar absolute.
Id like to get the pressure drop as close to zero as possible. 250 throttle body is 45mm blade so better, and logs look better with less pressure differential. The problem is, it has a bolted on boost pipe/flange so id need an adaptor.
A while back i got wind of a bosch throttle body that bolts straight on. 54mm throttle blade, and regular silicone hose fitting.
54mm throttle on the left vs 250 45mm throttle on the right.
Offered it up to 250 inlet, and it bolts straight on.
To make it bang on, the inlet throat needs 3mm or so of porting doing to remove a step. Ill get the die grinder on that soon.
Hopefully the pressure drop will be reduced to zero or near as, with the turbo not working as hard to meet required boost levels at the inlet/engine.
We will see.
Brigsy
  T.Turbo
Updates.
I needed a custom turbo oil feed making up for my new turbo setup, so popped down Global Hydraulics (formerly northern hose and hydraulics).
Excellent service as usual, £35 made in ten mins whilst waiting. Recommended if needing custom hoses in Teesside area.
-4an one end (7/16jic??) with bsp to metric adaptor at the other end. The oem had a metric banjo that bolts to the block which is made of unobtanium so this should be the solution.
90deg 3/8 bsp to metric connector to replace banjo.
I have the old forged f4r out of the kangoo sat on the engine stand for mock up purposes, so offered it up.
That will do the job. I will work out a way to support it with p clips and simple brackets once ive mocked up the starter motor, turbo, external wastegate and downpipe.
Just short of a couple of parts now, coolant hoses, vac hoses etc.
Cookson
  Mk1 Audi TT 3.2 V6
Sorry if you've mentioned it earlier in the thread, but where's that downpipe heat wrap from? I guess it's more of a sock than a wrap?
Brigsy
  T.Turbo
it is indeed like a sock - Basalt Thermal Exhaust Pipe Sleeve. Ive ordered it from here a couple of times https://hilltop-products.co.uk/hilb...SbZ99opPuODvDODYvgYs5JsAL0s6sSCTxnmD_HBsMtmJA
Its good stuff, and in theory it should be mega easy to fit compared to normal 50mm wrap. In practice doing a tidy job is a bit of a carry on, the ends fray so need to be folded on itself, Also easy to get the length wrong. This should run to the wastegate pipe, but due to expansion of the sleeve and ends fraying it turned out a bit shorter. Overall, not bad though.
Cookson
  Mk1 Audi TT 3.2 V6
Thanks man. Is it fairly flexible? Just wondering if it would get over the flange on my downpipe and decat as they aren't V-band
Brigsy
  T.Turbo
Should go over ok as it expands a fair bit. Pretty difficult to fit in situ but not too bad on the bench.
Brigsy
  T.Turbo
Updates.
The nortech manifold for the g25 conversion has been a right fcuk on. I was sold it as repaired/good nick and fairly priced to suit. In the back of my head i knew this would need work but always stay positive eh?
Anyway seller royally f***s me about and it arrives 8 weeks later. As soon as i opened the box i could see the flange was a country mile out with 3mm bow at both ends. Seller obviously oblivious to this.
It was quite obvious that the flange had not been clamped when repaired and its gone on the piss with heat. In hindsight i should have fucked it right off at that point and bought new (still an option) but anyway proceeded to attempt to put it right.
Steps to put it right if anybody has similar issues if interested.
As seen the flange was so far out that if cnc'd or milled flat the flange would be too thin in the centre. With this in mind, it was put it in the press and the flange was supported both ends and the middle was pressed flat. This worked well with it slightly pressed over flat approx 0.5mm so it would pull in. As sods law goes, its never straightforward and welds cracked on runners 1 & 4 at the flange so ended up having that tig welded and added new 1/8 npt bosses for egt probes, as it had unknown ones fitted.
The mainfold at this point was useable but rocked a little when fitted, and when torquing up to the head the bolts were under a bit of tension in the centre to pull it in. I.e. tighten inner nuts and outer need nipping again etc. It was acceptable but needed to be closer.
With this in mind i looked into getting it milled flat. With the manifold shape its not easy to clamp and finding anybody to attempt it is pretty difficult from asking round.
Next option was belt linish the flange flat. This is accepted as close enough for trueing up slightly warped exhaust manifolds after fabrication. Problem is finding a machine shop with a large one, my local fabricators all had ones which were too small for the job. Almost bought a 2nd hand large 3 phase belt linisher for the job but no room for stuff like that for a one off.
Fabricator said spend a couple of hours and hand finish it. I dont have an engineers plate for a flat surface, so going back to my joinery days, i know glass is always flat as fook and available cheap.
I picked up 2x 900 x 300 x 12mm thick toughened pieces of glass off fb marketplace for £5. Can of impact adhesive and 80grit sandpaper stuck on.
Simply push forwards and backwards. The design of the manifold makes it easy as its like using a smoothing plane which i have loads of experience from my joinery days. After 30 mins or so you could see it was starting to true up nicely.
After 2 hours it was almost fully done. Ran out of time being honest or would have went the full monty.
Prob need another hours worth of sanding to get it all the way. As it is, its flat as fook when checked with steel ruler, and bolts up to the head with no issues. Deemed good enough for farmwork and the crush of the gasket will get the rest.
Ballache but doable. If manifold gives any issues when fitted ill buy new. We will see..
Thanks for reading.
Brigsy
  T.Turbo
Updates
More turbo pipework mock ups. The oil return pipe on these g25 setup's is tight due to top mounted turbo and compact manifold design.
I done a bit of research on how the turbo return has been done on other kits and every method does not look great being honest.
1st attempt..an10 pipe knocked up from a few spare bits out of the random pipe and fitting box.
Fitted
Tight
The whole setup was deemed dogshit. I reckon it would work in a fashion, but the tight 90deg is not great. Oil flow should not be massive as ball bearing turbo/restricted feed so it might pass. My main concern was radiant heat off the manifold runner damaging the o rings in the swivel an10 fitting over time causing leaks. Could have wrapped the fitting and sent it, which might have been ok for a while.
Looked for better solutions. Attempt 2, purchased an all in one 600mm long stainless flexible oil return pipe to try. Typically the nut was larger than standard an10 so would not fit on the threaded turbo drain between the compressor cover and exhaust housing! Almost got the grinder on the nut but sacked it off, returned for refund and onto solution number 3.
Solution 3 is another stainless flexible oil return pipe with flange that bolts straight onto the turbo oil return. Did not hold my breath when offering it up, however it looks like a good useable solution. Very oem like.
With the flexble design, and heat resistance of the stainless, the bend can be a more shallow angle than previous, and still clears the runner.
All it needs to finish, is a short bit of hose joining to sump fitting. Need to order another straight an10 fitting to complete, ill have shares in torques at this rate..
Water feed solution done. 90deg an fitting fitting was stupidly tight here, so changed for banjo.
Its not optimal but itll do. Ideally all the fittings need to be custom bent pipes tig welded together. I really should learn to tig weld and this would be a relatively easy job.
Started mocking up airfilter setup as larger inlet than current setup.
Need to do some measuring on the vehicle before cutting to length. Ill prob get the join tig welded in the middle to make a tidy job.
Getting there, very slowly but some progress is better than none.
Thanks for reading!
Brigsy
  T.Turbo
Updates.
Had a spare hour earlier so done a bit more to the turbo setup to keep progress moving.
Oil return finished with a short bit of stainless braided hose, an10 fittings and firesleeve. Its solid enough, but will prob make a small bracket to hold it when in situ.
Id say its good enough to be fitted now. Just need a good day to get it done. Water hoses and induction pipe to be finished in situ.
With this done i moved onto fitting the larger bosch motorsport throttle body to my spare 250 inlet. The inlet port needed matching to get rid of a 3mm step. Bit of backyard engineering required.
Trace round throttle body with paper and oily finger to get a template, cut out centre with knife.
Transfer to inlet. Note 3mm or so difference.
i was going to die grind it, but found a worn down old flapper wheel that goes on a drill. It was worn on an angle from previous job which was perfect. 5 mins and done.
Im going to tidy up the rest of the inlet externally removing unecessary brackets and cutting clearance for the cam sensor before painting up.
Brigsy
  T.Turbo
Updates.
More mods done to the inlet in prep for the ecumaster black ecu upgrade.
Removed a couple of brackets that wont be used again and tapped the oem map sensor hole to suit an adaptor for a takeoff for the new ecu. Also removed the electronic breather crap, plugged with a bung and welded.
Needs a final clean and paint up before fitting, but another small job ticked off the never ending list.
Brigsy
  T.Turbo
Sunday update.
Inlet done. I removed another unused bracket on the front, cut the clearance required for cam sensor on 197 head and started to remove some of the oem renault casting marks. I was going to remove all the casting marks and smooth the lot, but stopped as its time consuming and not adding value to the setup i.e. going to add horsepower.
Give it a thorough clean up with brake cleaner and a stiff brush inside to remove any swarf. Pressure washed it out to finish. Masked up the ports, coat of vht aluminium and lacquer and ill call it done. Never be pretty but looks better than the stock 250 inlet.
Cam sensor clearance below, as 197 cam sensor is fitted in the head vs 250 fitted in the cam cover.
Bosch motorsport throttle body fitted.
Much better than oem rs250.
Need to look at fitting the turbo setup soon.
Brigsy
  T.Turbo
Updates.
Sent the Kangoo and r26 gearknobs and gaitors off for retrim to Otto Retrims recently. Received them back this week, fresh nappa leather.
Had a spare hour on Sat so stuck the kangoo gaitor and knob on.
Looks mega, and the new supplied gear gaitor frame otto sourced for me actually clips in as the old one was broken. The steering wheel needed a quick clean as it was starting to look shiney, so give that a quick once over.
Mot is due soon, ill get it booked in and sorted before turbo fitting.
Cub.
It’s funny, but sometimes I think it’s the smallest of aesthetic details internally, that make a car genuinely feel like ā€œyoursā€, as much as big engine or external changes.
I love doing the small things that make big differences.
Good work, looks great .
