My rusty Williams, where to start?
Industrial engineering here.
Yes, the repair costs are definitely testing how much I love the car :ROFLMAO:
Just got another quote to fabricate and install: Outer sills, lower + upper inner front arch sections, prime, underseal and paint those areas for £9600. I'm not sure it's wise to do the outer sills and not the inner sills.
I can't find any of those bodywork sections anywhere so they probably will have to be fabricated. Apart from maybe these:
But I'm pretty sure it says they fit the Williams 1, when I set the filter to Williams 2 + 3 it doesn't say they fit. Does anyone know if they're compatible?
I'm off to VJB in Maldon tomorrow for a quote, I'll see what they reckon
Outer sills don't exist but the lower spec ones simply need to be cut down to size as they're shorter on the 16v/Williams so that's relatively easy
There's a company on ebay (can't remember the name but will have to dig about to find it) that does R5 bits & bobs and the inner sills they make for them are compatible and a few people have used them with success
Inner front arches are cheap & readily available as well https://www.ebay.co.uk/itm/26698904...PDWpwANYouWt0VDrW54dbnvg==|tkp:Bk9SR9iPieO4Zg
When it comes to the metal structural bits on a Mk1 Clio, the only bits that are different are the outer side panels after the A pillar - even the 5 door ones - so you can ignore the majority of stuff when it's listing the compatibility being different etc because every single Mk1 Clio is structurally identical
Here’s the differences between the 3 versions.
Pretty sure it’s only paint and spec that makes them different. Oh and AC.
I've never seen a UK spec car with AC, there's deffo some European ones that had it though, the only significant difference is the W3 having a sunroof and ABS as standard
Sorry yeah I think I got AC and ABS mixed up.
Inner front arches are cheap & readily available as well https://www.ebay.co.uk/itm/266989046731?fits=Cars+Type:Williams|Model:Clio&_skw=clio+williams+inner+wing&itmmeta=01K73328YKVB07FXZFCRR50XKF&hash=item3e29c98bcb:g:ehgAAOSwCclm8-yP&itmprp=enc:AQAKAAAA8FkggFvd1GGDu0w3yXCmi1c2Mk80IIprtIORnse9VvoFYnqmvuYKKL2IMtGdqfe5fqKvrPbG7Rkk7uqWK/51VZUuim0C1Ytk0eTvXAuOiA3t1NLq2YHfqpZsoTFDduwVD9DsQogUS89C/Ojpp--7vae6vUazOI7PpNGrctUwUUSE5MMHDyUY8fQy5rPZE0VV/QUeM/zoTkknQb0enguK8XkH4hfvqgqzh1ZN6ber48xV6ZlKfuLn3xOtUTRx2bsbpu8DUClU9jAgYDTzXc5eZ9PttIwKGGnBUcfhPH6zBJPDWpwANYouWt0VDrW54dbnvg==|tkp:Bk9SR9iPieO4Zg
Awesome, thanks. Was this the company on Ebay for the inner sills? https://www.ebay.co.uk/itm/334376215479?
You thought about just selling it as is and buying a minter to enjoy, let someone else waste their time chasing rot! both will be the same cost the time your finished, thats what id be doing anyway, resell or move it on
.. the trouble with that excellent plan is when you buy a 'minter' and it turns out to be rotten as a peach. These cars hide their rust away.
Yeah you'd need to be vigilant spending decent money on any old French shyte
This. If the car holds no sentimental value, move it on for a good useable one and let somebody else endure months of pain sorting the rust out.
I hadn't really thought about selling it, I'll consider it though.
Is it better the devil you know though?
Sometimes its just better off buying one and driving now instead of suffering months of pain sorting out rust. Anything mechanical is faily painless to sort.
Veban motorsport have just got a few shells if thats any interest to you
I've had a think, and you're probably right.
But I'll keep it and try to fix it. It's probably the wrong decision but I'm properly attached to the car.
Pulling back the carpet.... and there's more rust!
Does anyone know if there's anyone who sells floor pans? I haven't been able to find any at all...
Yeah that's pretty rotten.. realistically not financially viable for someone who can't do all of the work themselves.
I don't think moving it on is a bad idea tbh
That's going to need a donor shell to sort that but I'm more shocked by the fact someone has attempted to weld it up before
Yeah it's had some proper dodgy welding. The drivers side footwell tells the same patchwork story...
A little late to the party here but have you tried Restorics out Yeovil ways?
I did some of his branding and internal design work and he's a bit of a voodoo magician with bodywork. He took on a completely toast (like frame separating toast) Subaru Brat a little while back and did everything down to custom tubs off a Mk4 Transit for it.
If you still need someone, hit Mark up and tell him Olly from Kamikaze Design House sent you, here's his website. https://restorics.com/
Thanks for the recommendation, I appreciate it.
I've found a friend of a friend who's a competent welder, so he's going to give me a hand with it. If that doesn't pan out, it'll probably have to go for parts.
