Mondial 172 Cup OEM+ / Rolling Resto
MAXRUNDOWN
New dephaser pulley fitted today, timing belt re-fitted and the odd clicking noise is gone, thankfully!
Also got the cam pulley cover, lower inlet manifold, alt/pas brackets and new engine sensors fitted.
Annoyingly I've found that the alternator pivot bolt bracket it cracked
So that's going to have to come off to get welded up, unless I can find a good one that's not cracked. Or just bite the bullet and buy a billet one.
Polynesian
  Alpina B3, 172, 325i
Glad you solved the dephaser issue, s**t when it’s a new part! Hope you don’t get slowed down too much with the cracked bracket.
MAXRUNDOWN
Back home again and slow progress is better than no progress.. picked up the repaired bracket this morning.
I've got a couple of weeks leave coming up so hopefully I'll be able to get the front subframe, bottom arms, hubs etc off and away for powder coating before the bad weather sets in
MAXRUNDOWN
Bit of a quiet weekend, spent most of Saturday giving the garage a deep clean and a proper tidy and doing the brakes on the Mrs car, got time to do a couple of batches of plating, ran out of demin water so I built up my front calipers with new pistons and seals.
Forecast decent weather this week so hopefully be able to get some work done outside 👌
MAXRUNDOWN
Bit more progress today, got the engine bay loom out, exhaust manifold and cat out, engine bay cleaned and the subframe, rack, hubs etc off
My back is in bits now, if I can move tomorrow I'll strip the subframe down in the garage, then sort out powder coating. Still feels like I've got a mountain to climb. I really want the engine in before xmas, hopefully I can get some more leave in and the weather is kind.
Yarp
  182 Turbo, E46 M3
Looks epic so far to be fair.
Getting the subframe off as a 1 man job is no walk in the park either. I dropped mine with the hubs and disks still on and nearly killed myself when I tried to move it 🤣.
It’s not too bad once the rack, hubs and wishbones are off but I’m still not looking forward to trying to get it back on without it landing on my face
npt
  BMW 320d- 172 cup
Looks like it'll be nice once complete, only thing i would say is I'd avoid powder coating except the wheels, paint is far more durable with stone chips and the like, powder simply looks terrible and falls apart in a few years if the car is used in all weather's, I've learnt from my mistakes 😂 paint is by far the best for under carriage stuff 👍
MAXRUNDOWN
Thanks 👍, I'm surprised you've had a bad experience with powder coating, I've used the same place for mine for almost 20yrs and I've never had a part fail. I do agree you lose the fine detail in some parts with thick powder but going into winter it's too cold for me to spray 2k in the garage now.
npt
  BMW 320d- 172 cup
Powder coating just cant deal with stone chips, i used to use my cup all year, it was restored underneath and everything has held up well with it being waxoiled over the years, its all the powder coated items that now look in a sad state, rear axle was chipped to death within 18months after not to much miles, would never use it again on an everyday car
npt
  BMW 320d- 172 cup
Clio looks to be in a good shape to start with, is there any corrosion? Mine was good apart from a little under the rear axle mounts, nothing serious but guessing it would of got bad hadn't i seen to it then, was 10yrs ago now 😂 time to sell it i think ha
MAXRUNDOWN
The shell is really solid, when I removed the rear 1/4 panel trims to look down into the back of the sills there's a little bit of corrosion so I'll do the rear sills before it's painted. Jacking points/axle mounts etc are all good, thankfully
  • Like
Reactions: npt
MAXRUNDOWN
Dropped all of the parts I need powder coating off this morning, they reckon they should be able to turn them around in a week which is ideal.
Picked up some bits I'd had vapour blasted for plating on the way home, I'd had the guy blast the exhaust manifold too, as it looked a bit scruffy.
I Didn't want to leave it bare, so I've given it a few coats of VHT flameproof ceramic black, obviously it's not going to be as durable as Cerakote but it's also less than 1/10th of the price
I'm happy with how it's turned out, I'd considered wrapping it too but don't think I'll bother.
Yarp
  182 Turbo, E46 M3
That looks epic.
Who do you use for the blasting? I’ve got a few bits that could very much do with a proper clean
MAXRUNDOWN
That looks epic.
Durham vapourblast for vapour blasting and bead blasting small parts, Stella blast are doing the powder coating
MAXRUNDOWN
Had the call today that my parts are ready to collect from powder coating, so I'll go for them tomorrow.
In the meantime time I've been doing more bits of plating - ARB brackets, steering rack brackets etc.
Decided to give the rack a freshen up too, plated the pipes, stripped the paint off the rack and gave it a few coats of gloss black. Looks loads better now.
Tackled the wiring loom too.. other than being filthy, someone had previously replaced the crank sensor plug, but just used uninsulated crimps and some electrical tape to splice it in, which is obviously unsatisfactory. That was undone and re done with some adhesive lined solder sleeves.
The branch of the loom that comes along the front of the block with the alternator power cable, PAS sensor, oil pressure sensor and oil level sensor was in a bad way, corroded wires, crumbling insulation etc, so I've cut that right back to good wire, depinned the plugs and spliced in new wire with solder sleeves then new pins and re attached the plugs. Laid it out along the front of the motor, just needs some new conduit now.
Id like to have the subframe built up and fitted next week, if not the engine back in too
MAXRUNDOWN
Just got my bits home from the coaters, really happy with them, went for satin black so they look OEM.
They've done the subframe, subframe stiffening brackets, both hubs, bottom arms, gearbox end cover, ARB, ARB outer brackets, ECU mount brackets and a couple of other little bits... I was completely shocked with the price, they've only charged me £150 for the lot! I need to remove some of the coating where they've gone over the caliper mounting faces and the bottom ball joint taper, but for that price I don't care.
MAXRUNDOWN
Started building the subframe up this afternoon. Rack fitted with powerflex black bushes, new genuine Renault tie rods and Meyle track rod ends. ARB mounted with powerflex black bushes.
My uprights and bottom arms are with Frogjam to get the bearings, hubs and bushes pressed in so I should have them back in a few days. Once the bottom arms are back I can get them fitted along with the new bottom ball joints then just need to rope someone in to help me get the subframe back in without damaging the powder coating.
Yarp
  182 Turbo, E46 M3
View attachment 1765851View attachment 1765852View attachment 1765853View attachment 1765854
I’m in the office all next week other than Thursday so probably less than a mile away. As long as you give me notice the night before so I can bring some different clothes I’m more than happy to be a spare pair of hands.
MAXRUNDOWN
That would be amazing, thanks mate 👍
MAXRUNDOWN
Got the subframe in today, @Yarp dropped by to help manoeuvre it into place and get the bolts in which was massively appreciated. Feels like I've hit a big milestone starting to put the big bits back together.
I'd love to have the engine in before I go back to work on Sunday, weather forecast isn't looking favourable at the minute but I'll definitely have it off the stand and hanging on the engine crane so I can get the rear main seal in, flywheel on and gearbox on so it's ready to drop in.
Yarp
  182 Turbo, E46 M3
Great to meet you today and pleased to have been able to lend a hand. Subframe solo is one of those jobs that guarantees either ruining all the nice powder coated bits or having it slip and smash your teeth out 🤣.
The car looks absolutely fantastic, even in current spec. It’s going to be cracking once it’s all back together 😁
MAXRUNDOWN
Got the engine off the stand onto the crane this morning, rear main seal in, flywheel and clutch on then got the gearbox bolted up.
Need to torque the engine-box fasteners, fit the starter and give everything a final check over before dropping it in.. I could probably have it in tomorrow but I've had enough for this weekend, garage needs a proper tidy, got to dismantle the engine stand and do a tip run to get rid of loads of rubbish.
MAXRUNDOWN
Got the starter fitted and loom on the engine yesterday, plan was to drop it in this morning.
Ended up sleeping in so didn't get in the garage until 1030, I wanted to hang the exhaust and get the manifold bolted to the downpipe with the engine out. I pissed about for ages with this, the sealing ring that came with the new fitting kit seemed too big, there was no way I was getting the springs compressed enough to start the nuts.
Pulled a used, already compressed ring off the 182 manifold I've got in the garage rafters and the same issue. Went and checked the manifold against the OEM cat and the flare in the end of it is much bigger, the milltek DP has the flanges another 10mm or so apart so it's never going to work. I'll need to source a slimmer, probably graphite, sealing ring from somewhere.
With that time thoroughly wasted I thought I'd at least get the engine in the hole, but couldn't wiggle it into place between the chassis rails and operate the crane at the same time in the couple of attempts I had. Then I had to pull the plug and call it a day because I'd arranged to take my daughter to her sea cadets activities.
Tomorrow is a write off because I've got to take the kid to her remembrance day parade, so I'll have to have another go during the week.
Polynesian
Between weather, kids, rust, surprise old bodges and general stuff, things much less impressive than what you’re doing always take me 3 x the imagined time. Usually that means into a second or third day for me. What a pain in the arse! Good luck next time.
Digsey
  182FF
I'll second this, i bought my 182 about 2 years ago, apart from driving it about for the first year, i've never even managed to hoover it out due to kids, house maintenance, kids again, weather, etc etc etc! One day it'll get sorted :)
ash_89
  Clio Cup 172
I had the same issue with the exhaust fitting kit purchased for my 172 cup; the fitting kit was fine, but the conical seal was too big. I ended up fitting my old seal with some exhaust paste.
I messaged the company who supplied the kit to see what happened, and they now want me to measure the original seal.
Trouble is the old seal will obviously be crushed and isnt what it use to be.
Im not sure about yours @MAXRUNDOWN but the seal supplied to me was way off.
Yarp
  182 Turbo, E46 M3
I’ll just add in that I’ve never found something I hated doing more than fitting the downpipe to the rest of the system. Trying to do those stupid springy screws over the subframe is an impossible task. You need at least 4 arms and several sets of eyes to do it, it’s a properly s**t job.
I ended up using lengths of threaded bar instead of the bolts with the kit because I just couldn’t get them to go through and tighten.
And looking at all the above, I was probably another one in the boat of the seal being too big 🤦‍♂️.
MAXRUNDOWN
The issue was the 'cup' for the seal in the OEM cat/dp is much deeper than the flare on the milltek. I even tried compressing the springs in the vice and wire locking them compressed to get an extra few mm. I've ordered a graphite seal without the wire mesh, and a random Klarius fitting kit that comes with three different lengths of bolt.
Failing that it's getting some long M6 bolts fed through from the back and some cone nuts to sit in the cups on the manifold.. it's just frustrating at this point when you find an issue then need to wait a few days for bits to arrive
MAXRUNDOWN
Got the engine in by myself this afternoon, it went in first time. it's on all of its mounts which just needs a torque check, got the exhaust manifold on and I've just called it a day because it's getting dark.
Feels good to have it out of the garage, which needs a good tidy tomorrow. I'm waiting on a few bits turning up but it should be all back together by the end of the week, weather permitting.
MAXRUNDOWN
Decent progress made today, I've
  • Torque checked fasteners for the subframe, all front suspension & engine mounts
  • Fitted powerflex black top mount donuts
  • Fitted the new driveshafts, uprights, discs, caliper carriers, calipers (just finger tight because I need new pad slider shims before I can fit the pads), Hel braided hoses.
  • Fitted the fuse box and connected up the engine bay loom.
  • Filled the engine with sacrificial "first start' oil
  • Filled the gearbox with some Millers CRX oil
Plus a few other little bits, put some plugs in the engine, HT leads on.. I'm going to wait until the exhaust is on before I fit the inlet manifold, coil, throttle body etc just for ease of access to the DP flange.
If it's dry tomorrow I'll carry on, fit the coolant hoses, radiator etc.
MAXRUNDOWN
Got a little bit done today in-between rain showers
Brake shims turned up so I've got the front pads in, and new stainless bleed nipples in the calipers
These are apparently the replacement for mintex 1144 compound pads, so should be good for fast-ish road use.
Got the coolant hoses and radiator fitted
And removed the carbon canister and made up a resistor on a connector plug so it can be unplugged and reverted if needed.
I've also connected up the Advocult high pressure PAS hose properly, and fitted a rivnut into the subframe so it can be secured with a P clip to stop the braided hose flapping around
PerthRS
  Clio 182 CUP
Love the idea with the P clip. The advised retaining method of using a plastic cable tie gives me anxiety with it flapping about.
In regards to the carbon canister. What resistor did you end up using? I'll be fitting a catch can in the future which means something needs to happen with that circuit.
MAXRUNDOWN
This was the resistor I used
this has the correct female plug and pins for the male plug on the loom
