Brigsy's other cars - formerly kangoo 172 cup
Brigsy
  T.Turbo
Updates.
Extra van only moved once last year and has been laid up ever since. To recap it needed a bit of work doing, inlet gasket was leaking on cyl 1 causing a bit of noise on boost and a fuelly mix coating the inlet, and down on power but not by much. I had the parts in stock, but lacking motivation id failed to do anything. Not a massive amount of work, inlet, exhaust and turbo off, but if you cant be arsed its easier said than done.
I have Croft booked for Easter Friday and its looking likely the r26 will be in the bodyshop, so with 8 weeks to go ill see if i can get this ready.
Made a start.
45 mins later, inlet off and turbo moved out of the way.
1hr30 in, fully stripped. Its fiddly to work on but easy in some respects as its all done from the top.
On stripping the gasket off, noted cylinder 1 & 4 inlet ports had split the gasket and rippled the stainless side. All bolts were tight so it had not blown out due to lack of torque on the fixings. Never seen a c1j gasket fail like this, i assume its high egt, high emap (exhaust pressure) related and the cast manifold moves a bit.
Oem renault gasket not up to the job.
Interesting ripples on the stainless side due to movement, cracks visible.
Ive had these fail before but not like this. The new one has stainless plate both sides and supposed to be better. However might be time for a material change, i have a lead on a copper gasket.
Id noted the starter wiring was a bit tired last time id been underneath, heat had affected it and the plastic conduit was melted. The r5gtt runs a starter motor heatshield originally but they fall to bits and get binned, ive done thousands of miles in this without issues but the efi engine is a different animal and clearly needs some protection
With access good the heat damage was clearly visible, Not the best.
Touched it and everything fell to bits revealing 50mm or so of bare live wire. This has no fuse as standard, good job it never touched anything or could have been sketchy.
Heatshrink would not go over the angled connector to the starter + terminal so only option would be tape which is a bit bodgy. I need the angled connector and opted to splice a piece of new wire in. A quick rake about in the spare wiring and a bit of megane starter wiring found. Needed the angled connector for starter as access is tight, so crimped a straight joiner in, and chopped loom back which revealed an oem joint.
Hydraulic crimper gives solid joins.
Dual wall heatshrink x 2 layers.
Original loom cut and joined at oem joiner.
Dual wall heatshrink.
Fibreglass firesleeve added for heat protection.
Starter motor had seen a lot of heat. Ideally it needs a heatshield making but can wait to another day. Added some dei reflective tape i had spare.
Refitted. Added a heatproof ht lead cover over the firesleeve, should be adequate. Ill add a maxi fuse into the positive wire to batt to avoid any issues in the future.
With this done started cleaning up inlet. The fuel vapour is clearly visible with added bit of exhaust blow.
Quick once over with brake cleaner.
Ran out of time so will refit today.
Brigsy
  T.Turbo
Few hours on it today.
New gasket in situ, both sides metal so hopefully will last a bit longer.
Back together. Give it a wipe over to clean.
Battery back on, primed up fuel system with ign on and off a few times and good to go. laptop on to check sensors reading ok.
Primed oil system up by holding full throttle as the adaptronic has fuel and spark cut for flood clear, its a good feature. Oil pressure come up straight away, so went for a start and it fired straight up.
All seems to be good, engine idles better with no air leaks.
Mot pre checks next weekend then will get it booked in asap.
Thanks for reading!!
Brigsy
  T.Turbo
Updates.
Coated the bumpers and all plastic trims on the Extra. In the past i done them with bumper gel, it never lasts more than one wash though and the trims go back to looking s**t.
Ive tried most of the good ceramic bumper coatings and some are pretty crap durability wise, however had mega success with Cerakote ceramic trim coat wipes on the kangoo, so decided to do it properly.
Before
After
Its a bit glossy for some people, but personally i dont mind it. Goes off fast too, cured in an hr, prep is dead easy just scrub the plastics if necessary.
Got it out today for pre mot checks.
Plastics look mega.
Main reason for getting it out today was for mot pre checks. Being honest, it was checked after Csf in 2024 and its done hardly no miles since so didnt expect any issues, and all looks OK. Still solid in the right places for a 29year old van.
920kg and it flys up on the jack.
Side exit exhaust.
With mot pre checks done, i started doing some pre dyno checks. Its booked in Efi for a map tweak later this month. Been meaning to do it for 6 years but never get round to it.
Anyway quick smoke test on the boost cct, to confirm no more inlet leaks. All good, no leaks.
Will get some road miles on it this week after mot, then look at oil change and brake fluid flush.
Brigsy
  T.Turbo
Updates.
Extra van mot'd and taxed again yesterday.
Took it for a run out as weather was good, and done around 60 miles to whitby and back. All is good and working well. Nice to get it back out.
Brigsy
  T.Turbo
Shorts & gloves for life. Id have been wearing a gym vest if it was a few degrees warmer😄
Helmet is a good shout. The bosch 044 fuel pump is pure tinnitus, might drown that fcuker out. Ive worn earplugs on longer journeys but the mrs called me a fanny for it
Brigsy
  T.Turbo
Roll on tax and mot exempt. 12 years to go.
Its mad to think they produced these longer than the car.
Brigsy
  T.Turbo
Updates.
Extra van on the dyno at Efi last Sunday for map tweak.
Last time it was tuned, in 2020 was for max power. It was to see what the engine and turbo were capable of when pushed, it made good power 249hp at 27psi. The tune was very close to the edge being close to knock at high rpm, and egts around 1000deg peak. Basically every component in the engine was pushed to the limit with stock pistons, conrods and liners running double stock hp.
Its been super reliable using 12psi low boost for trackdays, and i ended up turning the high boost down to 24psi which was OK on short sprints and hillclimbs. High egt's were finding a few weak spots, wiring starting to melt with radiant heat off the manifold etc..
The goal for Sunday was not max power, but reliable power for hard sustained circuit use with plenty of safety, so essentially a detune in some respects from the previous dragstrip/max power tune. A nice high boost setup that would take lap after lap of abuse.
Chris worked his magic and all goals were achieved. The engine was run with no cooldown and long pulls on the dyno to get max heat in and simulate track use.
Boost pressure was kept at sensible levels 21psi on high boost, to allow more ignition timing to lower peak egt's which are now 880deg max. Fuelling richened up slightly to also help with cooling, and rev limiter kept at a more sensible 7200rpm.
Wastegate pressure 12psi/173hp.
High boost 21psi/226hp.
Its still as fast as f**k being honest, does not feel any slower on high boost. It drives lovely with flat torque curve on boost and no traction issues. Low boost feels the same as before but even safer.
Ready for a few trackdays this year with Croft booked on Good Friday. Cant wait, should be able to absolutely send it like the old days.
Brigsy
  T.Turbo
Great stuff Brigsy, thought about water injection when it's on track?
Not really thought about it tbh as i always considered it to be for iat's and the welly cooler i run works well, but from a quick google water/meth looks really good for lowering egts so could work well in this scenario, old high c/r 8v knock limited. One for the future maybe, with modern ecu.
I have a few bits lying about to build a spicey engine for it and a nice gtx turbo. 300hp would be nice.
Flob
Yes its one of those additions which add to safety rather than performance imo, sure you get a little more power and on track it keeps IAT's lower so you will be making more power but for me its more to do with lowering combustion temps and pushing you even further from knock limit without having to run silly rich. Lots of people try to add timing with it but I wouldn't.
If I supercharge the VX its what I'll end up doing. However I'll use water not water meth, water/meth is lots better but I don't want to set something up for it and then have to cart around a big bottle of methanol!
Combustion pressure above, Yellow trace is +3degs, Red trace is +6degs (from green base line). Blue trace is +6degs and water.
I know a guy who does sprints who uses it when high octane fuel isn't available too. I wouldn't buy a kit, they look very easy to diy!
MAXRUNDOWN
I ran pre-compressor water meth on my MR2 turbo and it made a big difference, especially as they're limited for options for decent intercooling without hacking out the boot floor. Had a nozzle holder water jetted out of ally to sit inside the silicone hose on the compressor housing with the nozzle pointed straight at the compressor wheel centre nut.
Brigsy
  T.Turbo
Definitely would only add on to current setup to add more safety. Agreed i wouldnt add timing, as rely on it. Any links to good diy setups?
I could have popped over if i knew you were there on Sunday.
Bet it's fun on high boost.
Ill be over again in the kangoo at some point, will give you a shout next time. Extra goes well on high boost. Id say even though detuned, its fast as it was years ago when it went 12.67 qtr on carb, but far better for drivability now.
Sounds decent that. My intercooling is good but definitely interested in giving it a go.
Brigsy
  T.Turbo
Updates.
More Croft prep yesterday. Started off with brakes.
Assume position. Half in garage as galeforce ten wind.
First job was to replace a bearing spacer on the stub axle. Id noticed that the one fitted was cracked when i changed the bearing ages ago.
This was not great as concerns about splaying out when torquing, or breaking. I made enquiries about buying new at Renault, not expecting much as most parts for these old relics are nla, was told backorder/no date. I considered getting one made up but actually got another 2nd hand beam to get one off and refurb.
Anyway several months later made some more enquiries at Renault and they said 2 week wait from france around £3 each. Ordered and actually arrived, bit of luck for once.
Fitted.
Onto the next job, brake fluid flush. Typ200 again as had it in stock, and it just works in this. Had issues getting rear n/s to bleed any fluid out, and turned out to be crud in the bleed nipple, strange one. Give it a good poking with the pick and resolved.
Next job was clutch stop. When i first fitted the ap 4 paddle clutch plate, with clutch down you could not get any gears as the pressure plate was over extending with clutch right down pushing the forks into the centre. The problem was the typical hole in the gtt carpet allowing the pedal to drop too far and slight centre differences on the paddle plate.
To resolve this i rammed an anti roll bar bush in the hole and duck tape over it. This was in 2010 iirc, 16 years ago, never gor round to it and done loads of miles/track use 😄
Decided to fit a pedal stop. Prob 16 years too late but whatever.
Attempt 1 - rubber stopper
This was s**t as too tall, the bite was too low on the pedal. Adjusted it and the contact area was too small and the pedal was sticking down.
Attempt 2, parts bin find
This was the right height and even filled the diameter of the hole. Good range on the clutch and no issues. Its off a clio2, ill let you guess what its off!
Give it a decent send to the gym and back lastnight. All good, brakes excellent and pedal stop good. Ready for Croft on Friday, weathers looking changeable so best get some rainx on the windscreen, as the wipers are w**k at speed.
Thanks for reading!
MAXRUNDOWN
This was my setup, memory was a bit hazy with it being 10 yrs ago, I remember making that nozzle holder now, before I had the ally one water jetted.
Looking back at an old build thread it was an AEM kit with 180cc nozzle pre compressor and a 760cc nozzle pre throttle body. TBH if I did it again these days I would use a PWR barrel charge cooler and run direct port meth nozzles with the kit controlled by the ECU (which a Power FC couldn't do)
Flob
Id s**t myself with that breaking up and going through the turbo!
I will either do this and lock wire the fitting:
Or use an Ali coupling like this
Depends a lot on where you want to inject, there are pro's and cons to different locations, on the Extra Id likely go post turbo/intercooler and just into the inlet.
Yarp
  182 Turbo, E46 M3
The boost pipes on the 182 came of a much spicer setup than mine and have a port for injection just before the throttle body.
I use it to hold a bolt in fresh air 👍
Brigsy
  T.Turbo
Ill admit the pre turbo nozzle gives me the fear. Ive used the silicone hose boss fittings before for sensors @Flob , work well enough.
Winter project maybe.
Brigsy
  T.Turbo
Croft done.
Weather a bit iffy in the morning..steady drive over approx 35mins. Unload the gear, and noise tested 101db @ 4500rpm.
Ready for sightseer laps.
This did not go too well. On the 2nd lap of the sightseer's i lose the clutch. The pedal was half functioning but soft as fcuk, to avoid embarassing tow of shame on the sightseer laps crash box it back to the pits and did not need to stop luckily.
Get it in the garage and whip cable off, and examine. It had not snapped but the inner sleeve had pulled through the bulkhead grommit. I had feared the clutch pedal ratchet had failed and it would be day over.
Clutch cable fail on these is common ish but does not happen too often when using oem cable, i carry a used oem cable in my trackday box for situations like this. Stuck the cable on and reset the clutch ratchet, fingers crossed and it was working ok again. Tbh, when i arrived at Croft i could barely get it in reverse to park up so should have clocked that something was wrong. Anyway, lost an hrs worth of track time, was raining heavy at that point so no real loss.
Now that it was working again, the plan was to send it. The weather conditions improved with rain stopping, and track drying out fast. The grip was good on damp circuit on Ar1/low boost settings, done a few laps and turned it up to high boost for a lap, to monitor egt and afr to make sure all good.
High boost was mega as it was the difference between pulling away slowly from some cars and then watching them go backwards in the mirror quite fast with extra 50hp on the button.
This was short lived however as 2nd session on track, clicked it onto high boost and it did not respond. So i was stuck on low boost of 12psi all day with a big fcuking turbo doing nothing, well 173hp but 50hp less.
Assuming mac valve, switch or wiring has failed. I really could not be arsed looking at it with the earlier repairs, so just drove it like i stole it on low boost and had loads of fun. In comparison to modern stuff its hard to drive, you have to let it slide a little and have confidence in the handling. So good letting it sing to 7600rpm.
Track was quiet at the end and hot lapped it for the last hour until the fuel gauge was saying 1ltr left, had to call it a day at that as had done around 60ltrs of fuel/150miles on circuit.
Tyres look a little battle scarred and ive melted more paint on the front wheels. Ive cooked the brake fluid as pedal is a bit longer, so that needs changing for something more suitable. Rad fan wiring failed on the way home, power wire snapped off at the alternator connection due to fatigue at a guess? Luckily does not run hot/did not hit traffic on way home.
Eventful but awesome day. Roll on the next one!
Thanks for reading!
Brigsy
  T.Turbo
Updates.
Fixed rad fan the other day. The +12v wire had snapped off at the ring terminal for some reason.
Repaired in 5 mins with new ring terminal and dual wall heatshrink.
The dual wall heatshrink should add some stability/strength at the joint as it glues when shrinking.
Also done some testing on the mac valve wiring. Wiring seems ok and tests fine, but no continuety through the valve. Seems like the coil has failed.
Ill get one ordered soon. Hopefully the boost curve will be very similar with the new one. Might mount in a different place as this is the 2nd one ive had fail, its bolted to the turbo compressor housing so poss vibration damaging it.
NorthloopCup
Ford cosworth Amal valve was by far the most reliable boost controller I used. Just different sized drillings for the insert into the valve needed. Bit trial and error at first, but never had one fail, and that was running 2bar+ boost lol
Flob
Can you still buy them?? They were hard to get 15years ago. Genuine ones must be loads of money now.
I've used Pierburg which is oem for lots of cars several times and not had one fail. But Amal/Pierburg would certainly need duty to be adjusted.
NorthloopCup
I’m fucked if I know 😂 , but I’m pretty sure I paid about £12 for the last one I bought lol
Djw John
Scotland - South
Am I remembering right that you use ATE TYP200 brake fluid?
I used to and cooked it at KH a few times, swapped to castrol super response which f**king hurt at checkout but I couldn't get it to overheat at all, amazing stuff
Brigsy
  T.Turbo
Ive actually got one in the garage that i used for a pikey high/low boost operated on the rear window wipe switch on my old white gtt. Might get it sold with the prices 😄
I think ive just been unlucky with the mac valves. The first one the centre unscrewed and fell out. The current one was off the Trophy years ago, i knew i should have bought new.
Yep on ate typ200 in this. In all fairness it didnt boil too bad, pedal got a little soft. I was being cheap and it was on the shelf. Defo going castrol srf next, save me changing it regularly.
Flob
Castrol SRF or Motul 700 has worked well for me, the Castrol has a really impressive wet boiling point (ie the boiling point when it isn't new) which in my head means it will be the longer lasting fluid if you also run it on the road for 6months and do a few TD's like me.
However Motul is a LOT cheaper.
Brigsy
  T.Turbo
I use rbf600 in my r26 and its good stuff, get 3 or so trackdays without a bleed. Always full of water according to the fluid tested.
Like you say, half the price of srf so prob worth spending more to extend intervals on this.
