as the dash is on hold untill i can think of some way of sorting it out..i have decided to get the seat and harnesses fitted. afer much '*****ing' about, wev finally decided on the seating positions and height for both, we marked all 8 holes for the side mounts+after attempting to drill two of the holes using tintop HSS drillbits, each time the drill bit would melt as the steel is so thick so back to machine mart! Bought some stupidly expensive metal cutting bits, we then piloted each hole with a 6mm,and followed through with the 8.
We then replaced the side mounts onto the frames +secured with 12.9 m8 cap bolts, 8.8 m8 nyloc nuts,2x 12mm m8 spacers+then 2x 20mm m8 spacers per fixing.
Next up was to fit 2 lower eyelets on the under side of the lower sub frame, to do this we spaced two 10mm holes on the front lip, trimmed down the eyelet backing plates to fit in the frame, put the eyelet through the hole then secured to the backing plate, nipped them up nice+tight facing the right way.
We then fitted the 2 rear central eyelets from under the exhaust tunnel in the original seat frame mounting points.
We then secured the outer harness to the shell on the original seatbelt mounting using the original 10.9 cap bolt.
With all these in place, we placed each seat in its respective side mount +secured the seat with a 12.9 cap bolts and 20mm m8 spacers. All torqued up to 45nm
We then removed the rear harness mounting buckle from the strap, wrapped the strap around the rear of the role cage harness bar and relooped into the original buckle.
We then adjusted all the harnesses, ensuring that they were all equal+double checked all the torque settings.
Seating position which we have chosen is perfect imo, cant wait to get on the open road!
Also trial fitted the new omp wheel and boss.
