its just a friction fit isnt it?
difficult mate really could be a seized bottom end or as you say piston/valve contact..
i would remove the head at least to start if it was mine..then you can inspect it and see..that way at least you will have a better idea
why would you not take head off when it was on floor???
i would of taken head off done headgasket just for peace of mind
yeah true, suppose il get the engine back out over the next few days then.
Would it be possible to tell if a bottom end is siezed from looking at it with the sump off (already done previously), or is it a matter of taking the crank off completely?
I'd be very careful here, there is NO woodruff key, so you may well have lost cam timing now, as the pulley and thusly the belt is purely taper fit on the crank!!
Silly question, did you try turning it over with the V-belt off? I've known a seized alternator to stop an engine turning over
as maxi said, i was told the engine was fine and had been running etc, milage checked out and the cambelt/tensioners were not original, so it had been changed....
plus i didnt want to faff around with the timing on this one just yet, as ive no idea how to do it 'properly' so to speak, there seems to be allsorts mentioned in different places...suppose il have to now though
This is the F4Rs completely 'floating engine' setup or something isnt it. Piss poor design idea imoI'd be very careful here, there is NO woodruff key, so you may well have lost cam timing now, as the pulley and thusly the belt is purely taper fit on the crank!!
already snapped :clown:Is it possible to try turning engine over by hand using spanner on crank bolt?
thats what caused the bolt to shear off mate^
Hutchie, its not that far lol....i did 500 mile round trip for the engine itself
Sump off, take the con rods off the crank and turn the crank by itself? Just make sure you mark which journal fits which cylinder if it had to go back together again
I guess the engines coming back out then, head and sump off, and check if the crank spins, or if there are any bent valves.
Do the pistons have to come out if im removing the crank (if i need to), and if they have to come out, do they need new rings?
FFS....
Your middle name 'Lucky' by chance??
it wont be bent valves, would still turn over... it may lock going one way but you'd be able to turn it backwards free enough.
100% not that if it wont turn at all.
its pretty fecking seized if it snapped the crank bolt.
i think its spun a big end bearing, didnt the sump have a hole in it when you bought it?
theres your answer.. sellers lied to you mate.
went on the sellers word...suppose i never will againi dont beleive you have done all that painted it etc etc without even checking the thing turns though!!??
how can i put another bolt in? there is no thread left to do that, its snapped off half way in the cambelt bottom pulley?!?first steps getting the broken bolt out (which will be an arse as that will be impossible to drill its too hard) put another bolt in.
nah no timing pin mate, ive not touched the timing...then you want to take the sump off,, slacken each big end bolt a half a turn and see if it turns.
if it frees it up bin it,, crank will be knackered and not worth continuing.
sounds silly but you've not left the timing pin in it have you?
FFS!
