Mk1 F4R/172'd Track Car Project [Year 3 - Engine and Chassis Rebuild]
Re: Mk1 Hybrid Project
It sounds a bit like a proportioning valve, but I didn't know roadcars even had them. If that's what it is it'll be somewhere on the rear brake line and I assume he means it will be completely blocking the brake fluid from getting past, rather than restricting it. There's a good chance Daz is talking about something completely different though.
the mk1s do have them.. it's linked to the rear beam so can adjust the braking force based on the height of the beam (ie if the back is high it assumes youre braking heavily and reduces braking effort at the back...
dont see how it could've failed though :(
my valver failed MOT the other day because of no brake pressure at the back.... could be same problem.
cars looking mean as f**k, wheels look sweet too.
apparently you were talking to my mate the other day at some meet? (black fez zetec s on black pro race wheels, cage & buckets)
^^^ dude I just spent a whole hour readong f0xy.net - b*****d!
Didn't realise how much s**t its gone through!
How much was the new 172 coolant tank by the way? did the willy cap screw straight on? are they the same pressures?
yeah, iirc f0xy.net is only upto day 160 odd, im nearly past day 200 now lol, gotta update it when i can be arsed...
172 coolant tank is 30 quid, wont run on a williams though, different pipe setup
Aye but this is for my 172 - but I fancy using the willy tank cap so I can fit my hill power covers, power steerings the same fitment but the 172s cap is different - if they both have the same pressure rating then I'll use the willy cap
Not read everyones posts so this might've been covered already but when we tried bleeding up the brakes on our valver it'd gone completely bone dry and it just wasn't getting through by pumping the pedal in the end we went down halfords and got a gunson easy bleed and that did the trick nicely forcing the fluid through until it was all perfect.
They're only about 15quid too
The cutting out problem, sure thats not just a duff battery? Swap them over between cars and see.
with the other battery on, it started and ran fine, but was only showing 12v at the battery when running, so alternator is broke by the looks of things...
just been to pick one up from winston, will try tommorow
bit of win, rev counter now works perfect...
new alternator also fitted, runs nice.
your cup car already has the mod ;)
i beg your pardon :eek:
whats that then?
tbh i keep finding 'mods' on it
looks like the steering column has been repositioned for the best seating position, its got metal guards bolted underneath to protect fuel lines (these guards have clearly seen alot of kerb action on track!!) so god knows what else im gonna find
that it?! its the wire that comes off the speedo cable isnt it? cant remember what you said now lol
so whats this mod then, or is it hush hush?
Dude I love where you've wired the started button up to - thats something I would do lol - so of course I like it :)
Re: Mk1 172 Hybrid Track Car Project
Thanks for the comments everyone.
I now only have one switch inside, hazards.
Rear fogs are turned on in via the rear wiper position on the stalk, as i no longer have a rear wiper. Rear wiper on = means rear fogs are on, rear wiper off...fogs off :)
Few other touches to the wiring, but more on that in the next few days....
yeah, position 2, and 'start' position are now redundant...
basically, key in, position 1, press the button...
had to move the wires round on the key barrel, but basically position 2 is now position 1 :)
Nice one jordan, car's mint shame you didnt but the turbines onto it they look so much better !! .. also why do all your cars sound like tractors!!!
another 6 hours on the wiring today....slowly getting there, all the front lights now working...
Inside a bit tidier too...
Looking good man... The wiring is quite tedious, but therapeutic?! I spent 30hrs chopping, taping and cutting out all the unnecessary crap !
