How much downforce does the 197 diffuser give?
  RS RIP
A couple of months back i spend the afternoon in the workshop of a race team (they used to be racing the 172/182's , now the 197)
They started to experiment with diffusers on the back for more stick and yep ; got better laptimes. Mind you , the diffusers they made up and stuck on there looked like poo but proved to be functional
Every little bit helps i guess
ForceIndia
  Gentlemans spec 200
A diffuser needs fast, smooth air travelling from the front of the car in order to be effective. Slow turbulent air (ie no flat underbody, or as flat as possible) stops a diffuser from working effectively.
A diffuser works with other components. Without the other parts, it's basically cosmetic.
  White clique
just another example of how fantastic the 197 and how its a great evolutionary development from the 172 and 182.
All this talk about it being marketing only, what piss, as if the any other Clio hasn't had its share of marketing gimmicks (along with all other sports cars)
ForceIndia
  Gentlemans spec 200
Exactly. It's marketing, and there's nothing wrong with it.
realnumber 1
To be a great evolutionary development over the 1*2's I would expect it to be substantially quicker and more efficient. It's not though!
  White clique
Not at all.
A car that evolves does not automatically have to be faster, look back over 10 years or so and most sports models today across manufacturers are by and large the same sort of speed. In terms of efficiency, yes that would be lovely and my BMW is nice and efficient and fast, more efficient than the BMW of 10 years ago - but you dont buy sports cars for efficient and the manufacturers know it! Any efficiency gain is a bonus, not a given!
Warren - in your own words tell me why a 197 would have a diffuser that was like a bit of decoration and that doesn't add any functional use if Renault have a development team available who would probably spend no more of their budget on designing and making one that is functional?
ForceIndia
  Gentlemans spec 200
Erm, the marketing dept perchance? The same marketing dept that fed us the horseshit about special tyres for the 182 cup pack?
A diffuser needs a smooth, quick airflow to have a noticeable effect, if this weren't true why would Ferrari go to the expense of a flat underbody (a clearly non-cosmetic part)? Designing a diffuser for marketing purposes is far easier and cheaper than designing a flat underbody and the associated issues that come with it.
  Clio 1970000000
Didn't realise I was going to start a fire here;)
Everything I have read about the 197 has said that the diffuser is functional. If you look at the diffuser on the Corsa VXR you can tell that is a gimmick!!!!
BTW, I am well aware that the diffuser does not produce downforce, it does the opposite of 'sucking' (if you have a better word then change it, don't flame me) the car to the ground by reducing drag undeneath the car.
  Clio 1970000000
This has something to do with the price they can charge for the car. You can't have a flat underbody and a cheap car. The Ferrari will produce more downforce than the Clio. That doesn't mean that the Clio does not produce any.
  White clique
May also have been a vain effort to improve the 197's woeful mpg;)
i've never said the MPG on the 197 was good, it was one of the reasons i got shot of mine, not because i was appalled buy it, but because i get the same MPG now out of a 3.0!
But then again 29mpg from mine wasnt too bad, unlike some of the figures people on here quote they get from theirs!
ForceIndia
  Gentlemans spec 200
But to say the diffuser produces 40kg of downforce is completely incorrect! The Clio was designed as a normal car, where factors like mpg and low drag take priority. I'd be massively surprised given the shape of the car, the ride height and the diffuser if there's 40kg of downforce. If it were such a critical performance part on the 197, why on earth would renault completely compromise the design of the diffuser on the 200????
ForceIndia
  Gentlemans spec 200
Can someone please explain to me why the Corsa diffuser is a gimmick, and the 197's isn't?
  Clio 1970000000
Agreed. The diffuser looks less effective on the 200 than the 197. I have to admit that 40KG seems alot, but I am still in the honeymoon period of having just bought the car:cool:
  White clique
yet again you are getting all anxious and are looking at the negatives.
The Renault development team know a damn site more about airflow and design than you do, so why wouldnt they be able to acheive this?
Perhaps you should apply for a job and tell them how its really done?
  Clio 1970000000
Hopefully the picture of a Corsa VXR is here. You can tell that this is purely a cosmetic part of the bumper whereas the Clio diffuser goes about 3 feet under the car.
BTW How do you include a full picture in the thread?
ForceIndia
  Gentlemans spec 200
Oh dear, you seem to be getting all hurt and personal. I'm very sorry for 'offending' a car you don't own.
Calm down Priscilla, no need to get anxious.
  White clique
yes, because the Corsa has a roof spoiler and the clio doesnt.
Plus your fave mag reckons it does produce downforce on the corsa...
http://www.evo.co.uk/news/evonews/204589/vauxhall_vxr.html
'There’s a prominent roof spoiler, a fat centre-exit exhaust, and a very bold diffuser arrangement. ‘The car has obviously been wind tunnel tested,’ explains Harris, ‘and it generated a surprising amount of downforce. You can really feel its effects on the faster parts of the Nürburgring.’
  Clio 1970000000
LOL
ForceIndia
  Gentlemans spec 200
OMFG. Here lie's a fundamental misunderstanding on diffusers. The diffuser slows the airflow exiting the rear of the car, reducing turbulence, reducing lift. It will help the function of a spolier. Cars like the F430 don't require big spoilers etc as it has a flat underbody (which creates low pressure and a suction effect).
  White clique
hence the reason the diffuser is about 3 foot long on the 197.
Just throw in the towel, admit the diffuser has SOME effect on the 197. No one is saying it glues it to the floor and makes it as good as the Ferrari.
corsa diffuser reaches about |-----------| that far under the car. a 197 diffuser does go at least someway to producing a flat bottomed car by being far reaching under the car.
Warren, out of interest and not a intended to be snide etc, but have you looked under a 197?
ForceIndia
  Gentlemans spec 200
Had a good nose around a few, and the albi 200 that Renault Brum had in a couple of weeks ago. Glad you can discuss the matter sensibly!
I don't full understand how the length of the diffuser affects things, but from what I understand it's the angle of the diffuser that is most important (7-10 degrees being optimum).
ForceIndia
  Gentlemans spec 200
It does. It looks awesome.
My point is that although its not a completely flat bottomed car, that because the diffuser goes back so far, the under tray at the front and the fact the underside of the car is not a complete mess that, although not perfect, its going to be a lot better than it only going back 3 inches.
Just helps to make it MORE flat than it otherwise would be
realnumber 1
Not at all.
Oh right is that why most manufactures are heading towards smaller engines with turbo's and/or super chargers then?
So you call that great evolution when I can happily see 35-45mpg on my 172 (depending on type of journey).
The only thing I can see the diffuser doing is reducing the drag a little and aiding high speed stability. Not a chance it produces 40kg of down force at 70 mph lol.
  tiTTy & SV650
If you hung 40kgs off the back bumper it would fall off, especially being a Renault. Its only clipped in with, iirc a few of 10mms near the rear beam
Think about it ;)
PMSL!
Its more a case of putting 40kg in the boot, think about it ;)
ForceIndia
  Gentlemans spec 200
PMSL!
If it produces 40kg of downforce, the force exerted downwards on the diffuser would be 40kg. What he's saying that if you hang 40kg off the diffuser, would it stay on?
  fiesta 1.25
LOL at people quoting the brochure,yes it might help a little but not 40kg its mostly for looks.
I also dont understand why you would need a rear diffuser in a slow FWD car?
