UPDATE -
As the subframe had been dropped a few days ago i decided I would degrease it and paint it.
Pulled it out of the garage and started to degrease it
Took ages to degrease properly and i eventualy got bored so i have now decided to send a load of bits off to a powdercoaters.
So this is how the subframe looks atm should come back a bit brighter
I removed the wishbones and took them to a local garage for them to crack out the blow torche and remove the old bushes and metal sleves. They did it for free which was nice
So here are my wishbones with no bushes
I bought Powerflex bushes a while ago which were going to be for christmas but had to use them so i can get the wishbones powedercoated
I pushed the sleves in and test fitted it to the subframe
I then placed the bushes in to see how they sitted in. perfectly.
So i'm hopefully going to get the metal sleves tacked/welded inplace tomorrow at work.
Next job was to finish of spraying the ITB's so i can build them back up again
First gave them a rub down to get all the dust and loose grime off
Then I masked both ends and the injector holes
Then set took them outside to spray them
Now they are all sprayed
So just need to build them up and polish the trumpets up
I took an angle grinder to all the little sticking out bolts that are on the bulk head
and then sprayed it up so it looked a bit neater and stoped it rusting
Also sprayed some of the shell as it was black in some places. I didnt get a before pics up it did make a big difference.
Over all it looks much better
I also noticed that the pipe that goes from the ITB's to the Brake servo had a cut in it :S
This pipe
The cut
What does this pipe do and why do you need it?
More soon
