My French Clio 182 "White Pearl"....
  Clio RS 182
Why the fuk have I only just read through this thread.
Can't praise you enough for what you've done mate, I love the rear bumper and induction setup, looks so neat.
  2007 MK3 Clio
Can I please have your car?
This is amazing mate, couldn't praise you enough.
Think this is the best MK2 clio I've ever seen by a mile!
  RB One Eight Two
How have I never noticed this thread before?!!
This is an epic epic build. An absolutely stunning car, in a stunning colour, by far the best clio on this forum. Very well done!
  182 CUP
No No No No....Pierre!! where are you? Dont stop now, been reading your thread for the last 2 hours....MORE!!! We need video and i want to know how your intake system performs.
:approve:
C'est fantastique et incroyable!
  Clio 182 White CUP
News :
  Clio 182 White CUP
A little modification at engine / gearbox:
- Beam Engine lightweight jacket + new.
- Correction of inlet + exhaust cylinder head.
- Painting cache is tumbling + injector + RS + throttle tensioner alternator bracketin black high temperature.
- On the radiator fan forced water.
- Thermostat Clio RS 197.
- Water hoses reinforced and white SAMCO.
- Beams MAGNECOR Blue candles.
- Lightweight aluminum damper pulley TRI COMPETITION.
- Engine mounts reinforced K-TEC RACING.
- Anti-torque POWERFLEX (dogbones)
- Reprog Pouchelon bench.
- Couple 14x63 short.
- Clutch kit / disc / stop reinforced PERFORMANCE BLACK DIAMONDS.
- Keying the right sleeve (differential protection).​
  Clio 182 White CUP
were did you get those light from in your foot well ?? thanks and what an awsum project .
It is a montage that I made personally ...This is the lighting of Laguna that I adapted.
do you like taking photos ?P.s awesome, awesome motor!!!
Yes, I like taking pictures.
Here's more:
White Hoses K-Tec racing by SFS :
Personal stickers :
Test Brembo Megane III RS 250ch...
But it's too big and it does not ... Before :
  Clio 182 White CUP
Awesome car you have yourself! Did the brembo's not fit due to the size of the head on the bolt that goes through to the calliper mounting?
Thank you.
The Brembo caliper is too big to pass through the 16 "while keeping the brake discs of origin.
  Sandero R.S. / Clio
Awesome build, THE one I look up to when I'm doing my own project!
One thing that I'm finishing doing on my car (mainly because of the MS2R standalone ECU) that would be a great addition to this build would be a fully custom wiring harness with Helagaine braiding:
BTW the battery will go in the trunk.
  Clio 182 White CUP
Following: setting up of the engine block with the new gearbox.
There is also a new Clio RS2 ... Ex-Clio KTR I will change: moving the steering wheel left and prepared more sharp at the chassis and engine block. Reserved exclusively for the track.
[/quote]
  Clio 182 White CUP
Awesome project.
Simply... c'est beau!
Fantastic work!
love what you did with the rear bumper, seen it on a lot of saxo's but not on a clio.
thank you
:p
What is the switch in the coin tray for?
This is the interruteur to start the pump Ditection assisted, as on Clio CUP.
I love this thread. When did you get another white one? That's just greedy ;)
This is the Clio from a friend that I prepare for him!
Brilliant. Where do people put theyre battery when the airbox is mounted like that? Run it to the boot?
  Inferno 182 w/ Recaros ;)
That is absolutely incredible. Just spent the last hour reading this while watching Top Gear! Keep up the great work.
  Clio 182 White CUP
Thank you!
After a few miles, they attack again hostilities ...
198ch / 191ch gross, without reprogramming !
And news evolutions...
