Big brakes using Renault parts?
I didn't have much luck wih Noos he was very helpful giving me info about buying the brackets from him, but then soon as I paid I got no feedback or replys for ages to say he had recieved my payment or to say how long it would take for me to get the brackets, I did get a refund in the end but it took ages. I got some brackets made up at a local place that do the job but I'd like the ones used on the twingo or from the other French lad, think I'll give him a PM see where I get. I'm also using the scenic 300mm/24 brembo discs.
Even with 16" wheels the calipers are very close with the 300mm discs.
Im using the genuine Renault caliper bolts & some 12.9 Allen bolts to mount the brackets.
  Mental 172 Cup
Where did you get your calipers refurbed? They look the dogs danglys.. How do people find the brake pedal is after fitting these? I heard a rumour about changing the master cylinder because the pedal would be too long to run a 1*2 master cylinder...
  172cup turbo & rx8
Does anyone know the difference between the R2 and 197 calipers?
Can you use the Rsport brackets with 197 calipers even tho 197s run larger disks?
  Cup In bits
I have just bought some calliper mounts for the standard disk size from Seiz over on clio rs concept & 197 Brembo's :cool:. Should know in a couple of weeks when Im home if they will fit under my speedline 2118's.
  Clio172cup rally car
do you think you could get anymore of these or even get them copied?? I would defiantly want a set
  Mental 172 Cup
I had a PM from Noos yesterday, the company who were making the brackets stopped for a while and he was sorting stuff out. But they will be producing more and they will be available in the next couple of months..
  Cup In bits
I too had a PM from Noos saying that some parts will be going into production again. I personally think he is selling Seiz's parts with a mark up on them and don't think they ever stopped production.
I have only heard bad word's about Noos's communication but It might change now.
I have bought the the brackets to suit standard 280mm disks, with machining to the caliper mounting face they should fit under most 15" wheels and then a set of 197 braided or even standard front brake flexi's and you have a complete kit (everything to be confirmed.
Just for reference I payed 145 for my mounts and Noos is selling for 220 so he has a fair mark up on them.
If I was to put these into production it would take a while of R&D and I don't know if I could match that price by Seiz, I would just have to suck it & see really.
Seiz offers lots of different arrangement's from standard 280mm disk's will need caliper modified upto 320mm floating disks with ally bells.
I think a cheap arrangement as far as I can tell would be the scenic 300mm solid disk paired with the right caliper mount and you would have a top kit to fit under 16" wheels.
Anyway I will know more when I mock up mine.
Here is Seiz's products from over on clio rs concept.
In French : http://www.cliors-concept.com/t23288...-plastique.htm
Translated to English : (pictures can be seen in above link ,they do not copy across with translater)
The topic that brings together all Creation SeizArt'S
All these parts are in limited quantities and craft.
I do not intend to trade but just help some of my creations / ideas.
No room is designed to be used on public roads. I accept no responsablity when the use made of these parts.
Next stop:
Cale adaptation for Brembo caliper Mégane RS / Clio Clio 3 Rs or 3 in R3 ASSEMBLY ON 300mm disc CLIO 2 RS TWINGO RS, Clio 16S Williams or MEGANE
DISPO
Photos:
Custom adapters for 300mm discs: 165 € TTC PAIR DELIVERED
Mounting screws: 4 screws M14x150 x80mm: 30 € (controllable with shims)
Other parts have to:
(Stirrups Clio 3 RS Cup 180 € Ht x2 PADS PROVIDED!!!)
(Discs Brembo 300mm classic: € 84 on Oscaro or disk Fiat Coupé to redo 300x28mm drilled in 4x100)
(Goodridge hoses aviation M2RS or C3RS available on ebay.co.uk)
(Screw M12x125 available at renault 40mm x4)
Complete kit (except vis M12x125)
Cale adaptation for Brembo caliper Mégane RS / Clio 3 RS (with machining height) or 3 Clio R3 Earth ASSEMBLY ON 280mm disc-CLIO 2 RS TWINGO RS, Clio 16S Williams or MEGANE (origin or other )
DISPO
Photo:
Adapatateurs tailored to 280mm discs: 175 € TTC delivered PAIR
Mounting screws (studs and nuts) = 20 €
(3 Stirrups Clio R3 Earth: 190 € x2 PADS INCLUDED!!!!)
ALSO POSSIBLE TWINGO or 2 (Gt) >>>> specify
Cale adaptation for Brembo caliper Mégane RS / Clio 3 RS (machined height) or 3 R3 Clio Earth in MOUNT 300mm disc
Photo:
Custom adapters for 300mm disc Bracket R3 Earth: 165 € TTC PAIR DELIVERED
Bowl aluminum track floating disc
DISPO
Photo:
Quality CNC
4x100 5x108 or hub spacing (please specify)
Spacing PCD177.6 12x; 10x PCD176mm; 8x PCD166; PCD150 8x (AP disc or Hi Spec)
210 € pair of aluminum bowl delivered or € 220 with hardware
Accuracy means of a 10aine of € more per pair, I can also include the production of mm thicker on the hub. In the end you can bowl combine + channel opener in one piece! On request.
NEW On request also: bowl aluminum disc Hi-Spec 150mm PCD so for 280mm and 285mm tracks!!
Hold for passage hard Mégane RS Clio 3RS 330mm (312mm origin)
Photos: Waiting room
Price: € 43 per pair delivered (hardware + 12 €)
Adapter for mounting rear hub 270mm disc 2 Scénic
Photos: coming soon
Rate to come.
Next train:
Ring type steering rack Clio Cup
DISPO
Photo:
Quality hard plastic. More durable than original rubber.
€ 47 delivered 4 rings.
Ring type steering rack Clio Cup and Clio 16S Williams
DISPO
Photo:
€ 55 delivered 4 rings.
Screws eccentric camber adjustment
On request
Photo:
Stainless steel screws and nuts original Renault.
Set the cam, 3.8mm for a large camber adjustment.
€ 85 complete set
Sloped wedges for adjusting rear Clio 2 (and RS) Clio 3 (not RS) and Twingo 2 (and RS)
AVAILABLE SEE WITH DéDé
Photos:
€ 30 the pair
Available in 1 or 30 '.
Thickness 4mm. Thus gives way to a 8mm pair mounted.
Sloped wedges for adjusting rear Clio 3 RS
Available soon
In 30 ° opening clip or
In 1 ° camber
Price of around € 45 the pair livvrée!
NEWS ball head kit for amorto before
Easy assembly with circlip like editing Cup.
Ball and provided in a standard size (non-English)
Internal and external circlip supplied
Price complete with ball and circlips: € 175 delivered
Available
In a second time and after study, we will provide a room to adapt the OMP bar on the head ball.
We also study the faisablité a bar-type Cup in direct control over the heads (not adjustable).
Conversion kit rear ball
Photos:
Price: € 79 delivered (ball included)
Availability: to order
Strut rear Clio 2 steel
Avail.
Cup machined and welded non-mechanical: 1544 Gr
Photos:
The very bottom (right) is welded to the SOA (Oxy-Acetylene torch) and is more "raw" than the other but flatter weld: MORE AVAILABLE
Others, arc welding or MIG: AVAILABLE
€ 65 delivered
Strut rear Clio 2 ALU
DISPO
Cup machined and welded non-mechanical: 636 Gr
Photos:
[Click for actual size]
€ 79 delivered
Strut rear Clio 3 steel
NOT AVAILABLE
Cup machined and fabricated soudée.Non not painted.
Photos:
€ 75 delivered
Strut rear Clio 3 ALU
DISPO
Cup machined and welded non-mechanical. Same model steel: 699 Gr
Photos:
€ 95 delivered
NEWS Expander rear 8mm or 12mm
Shims placed between the rocket and the'' axle.
8mm: No hardware required: € 29.25 the pair delivered Lettre Max S (€ 3.25 included)
8mm: supplied hardware (if you already dipping wedges): € 39.25 per pair delivered letter M Max (€ 4.25)
In 12mm: screws included: 41.25 € per pair delivered letter M Max (€ 4.25 included)
Other width: 4mm, 6mm, 10mm, 14mm, 16mm, 18mm and 20mm. On request.
DISPO
Side engine / box
Speed ​​selector rod short (short shift)
Photos:
Prices and available to come: on order only: € 49 delivered
Rigid plastic inserts for rod recovery torque RS1
Photos:
Price: 55 € the kit comes complete
With rod ready to ride: 70 € delivered on demand (currently not available)
Available
Rigid plastic inserts / semi-rigid rod torque recovery RS2
Rigid plastic inserts centering softer rubber (prevents premature wear). Guarantee rigidity and very little wear over time!
Photos:
Price: € 67 delivered the complete kit
With rod ready to ride: 85 € delivered on demand (currently not available)
In exchange standard (you with me back your old slip colissimo included): 80 €
Available
Tool valve timing Semi GrN
MORE AVAILABLE
Photos:
Price: € 52 delivered
Available
Tool valve timing GrN
DISPO
Photos:
Price: € 59 delivered
Available
  172cup turbo & rx8
swede - any chance you can pm me his email address as im after a set of mounts for 300mm discs?
  182 inferno
hi i have just bought some bermbo r26 brake calipers, just wondering where i can get the brackets for them to fit and what disks to use and what i will need to fit mJy clio 182 cheers david
  Cup In bits
It is all detailed in my above post, french guy over on clio rs concept sells the mounts & disks in various different sizes. Depends what size wheels you want to run as to which size of disk you can get away with.
You will need clio 197 front brake flexi's- Custom caliper mounts- disks depending on what size you want.
  172cup turbo & rx8
I'm struggling to get hold of Seiz on the French forum, sent a few pm's but still had no response?
Did you pay via PayPal?
  182 inferno
oh right cheers how do i get in to contact with this guy? im running 16" wheels so what disks will i get of with?
  172cup turbo & rx8
300mm under 16"s, various mk2 scenic's use these which are a direct fit however there only 24mm thick not 27mm like the 225's
im trying to contact the guy (Seiz) as im also after a set but he's not answering pm's, he may well be away tho
  Cup In bits
When I get my set fitted up and know more about the line ups etc, I would be tempted to produce a few sets of the 280mm kit i.e 15" wheels or larger if there was interest, maybe some 300mm mounts i.e 16" or larger depending on manufacture costs.
This is basically the kit I have, the caliper mounting face that touches the caliper carrier needs machining by a few mm to fit under most 15" wheels, as to how much im unsure yet but will know in the next week.
Brackets kit for set up keeping standard disk (280mm kit) (calliper will need to be modified) = 220 Pound
Option: brand new set of modified caliper (grey) = 470 Pound
Minimum offset is ET40
It will fit in some 15 inch Rims (400mm clearance on the inner wheel needed)
It comes with caliper mounting screws, I will provide Renault part number for bracket mounting screw ontu the hub
  Cup In bits
Had a little time to put my brake kit together with some spare wheels and hubs I had lying around. No disks were fitted so need to get them tested on the car.
Wheels- speedline 2118's in et 48.5 (cup racer fitment)
Caliper mounts- 280mm version ( mounts look ok, a little thin in places where the studs pass through for caliper, but I have been assured there safe after years of use on other cars)
Calipers- megane 225 calipers.
For people looking to fit 197/225 calipers under 2118's it is possible but you will need et38 wheels or spacers to suit your wheels and the caliper's will need machined by around 5mm on mounting face, its a really tight squeeze for these calepr's but look brilliant squeezed under 2118's.
I will be fitting to my car in the next few weeks and will know the exact amount of material that needs removed from where etc.
  Cup In bits
I might look into it once I have my car finished but at the minute I have far too much on my plate to be doing other bits.
The 300mm kit would be easier to copy as they use the original caliper & and mount bolts. not as much machining needed.
300mm is what I'm looking for really as I want to keep 16 inch wheels, ill try again with seiz but he is shocking at replying back
  2014 Clio 200t edc
In the evo mag this week, they featured a twingo rally car, which appeared to have the same calipers as 1*2 cars?
  Clio 182 FF
Yeah if I was to ever do it I'd be going 300mm too. Whilst expensive, those two piece floating discs that Rikus sold looked well nice!
  Trafic 140dci
I'd be interested in the 280mm kit if you do...
I've ordered the ap 300mm discs from the twingo r2 also managed to reserve some brackets from seiz, hopefully get them at the end of the month, if not I might just bite the bullet and get the r2 brackets too,
As soon as it all arrived ill get some pics up
  182 trackday racer
Looking forward to see this. Lets just hope the offset on Seiz adapters are the same as on the AP discs. I have been in contact with Seiz as well.
