amazing how clean a new screen makes a car look!
Amazing work as always mate. I very rarely venture into the projects section, but always like to have a gander at this.
Looks brilliant![]()
pfft it'll be ready when its ready lolSo are you expecting to get it out on track this year?
Someone was selling a burpspeed llandow place IIRC, thats near end of september. Or is it going to be another year again?
Yay, its still progressing![]()
The closer the injectors are the better at low rpm, and the further they are the better at high rpm, so there is no single correct answer.
Mounted in the base manifold works well generally speaking as a compromise, hence most setups are done that way.
The more inlet length the better with these engines really, especially if you are on standard rod bolts?
[/TD]
8 injectors ftw.
First time i see your project on here mate!
Looking sexy as always!
If he had an ecu that can handle it, that's a good way to get the best of both worlds.
Dash looks brilliant. But I can't help but think the twin binacle shape won't look as right with the dash2 as a ph1 single binacle shape does?
Rest of it looks way better though, so modern compared to the hateful mk1 rubbish![]()
