Lawro's Super Clean Titanium 182 - Progress Thread
Car  E46 M3 & UR Quattro
Having now owned my 182 for a year I thought it was about time I treated it to a bit of a refresh and a few new toys so I thought i would start a progress tread with where I am to date and my future progress with the car. All of the below has happened since April 2013.
I purchased the car from a forum member after looking at several other 182’s, which didn’t quite hit the mark. I haven’t had much use out of it since purchasing it due to being unable to drive for over 6 months and came very close to selling it. Its taken me a while to bond with the car but now I’m back to full fitness its time to start enjoying RS ownership.
Few photos of it from the previous owner..
Clio 182 by Lawro1988, on Flickr
The car had covered just over 65,000 miles at this point and was to date pretty much standard so I thought I would start with a full suspension refresh to keep things tight.
The car was fitted with both cup packs from factory and after toying with the idea of coilovers I decided I would prefer something a little less harsh on the road so opted for the spring and cup shock combo.
Being friends with Josh from Cooksport he mentioned he was producing some springs for the clio so we came to an agreement and my car was fitted with the first set to trial them for him. I then decided to replace the front and rear shocks with genuine cup items along with new Lemforder ball joints and track rod ends, powerflex wishbone bushes and genuine inner & outer anti-roll bar bushes, steering rack bushes and inner tie rods. I also opted for a set of the lovely Pure Motorsport Solid Top Mounts over the standard items.
Suspension by Lawro1988, on Flickr
Cup Shocks by Lawro1988, on Flickr
PMS Top Mounts by Lawro1988, on Flickr
I decided to couple this set-up with a Whiteline rear anti-roll which I purchased from Demon Tweeks taking advantage of their price match offer and some Eibach camber bolts.
RARB by Lawro1988, on Flickr
Before fitting, I had the Whiteline RARB sprayed in Titanium Silver and gave it a few coats of wax in order to try and prevent corrosion that the standard powdercoat seems to suffer from.
Painted RARB by Lawro1988, on Flickr
Brakes were next on the list. With the car currently being fitted with EBC Green Stuff pads by the previous owner, its safe to say they’re horrific!
After a bit of research I decided on Brembo HC front discs along with Ferodo DS2500 front pads, these were purchased from G172 and genuine rear discs and pads from Adam @ Wolverhampton Renault. I finished the brakes off with a set of Goodridge braided lines and a brake fluid flush with ATE SuperBlue.
Brakes by Lawro1988, on Flickr
The brake discs were coated in satin black to try and prevent the corrosion of the hub area. Quality looks brilliant.
Powdercoated Discs by Lawro1988, on Flickr
The exhaust was replaced with a Scorpion RS192 system that was beginning to look a little droopy on the current mounts, so I took the liberty of purchasing a full set of genuine rear and centre exhaust mounts. I also decided to purchase a Scorpion decat too as I fancied a little more noise from the system.
Exhaust Mounts by Lawro1988, on Flickr
Having already purchased the powerflex wishbone bushes I decided to replace the dogbone mount as it was beginning to wear so ordered a powerflex bush for that from a forum member.
Powerflex Dogbone by Lawro1988, on Flickr
With the Cooksport’s fitted it was immediately noticeable how lost the cup wheels looked in the arches, especially with a touch of camber on the front end. After a fair bit of research I decided on some 15mm bolt to hub spacers for the rear and 20mm hubcentric spacers for the front. These were purchased from Dan at M.A.D, really pleased with the quality.
Hubcentric Front Spacers by Lawro1988, on Flickr
Rear Hub Spacers by Lawro1988, on Flickr
Finally a good service. I purchased some Elf Evolution 5w40 for the engine and Elf Tranself NFP 75w-80 for the gearbox along with some new spark plugs, oil filter & sump washer again from Adam @ Wolverhampton Renault.
182 Service by Lawro1988, on Flickr
With all the parts together I dropped the car off to Leighton @ Pro Garage to have everything fitted along with a fresh MOT.
Parts by Lawro1988, on Flickr
Pro-Garage by Lawro1988, on Flickr
The car flew through the MOT with the exception of the emissions. After a bit of investigation work it pointed to the lambda sensors so both were replaced with new Bosch units and after a thorough check over the car came back with a clean bill of health other than a split steering rack boot which were replaced with genuine items on both sides.
With all the parts fitted the car went next door to James @ Restomod for some cosmetic TLC. I have used this guy for many years and his work is always second to none, so the car was in safe hands.
Cosmetically the car is very tidy for the age with the exception of a few stone chips, and a few small dents.
The rear bumper looked like it had been painted previously as there were some slight imperfections on the N/S edge, I had always intended to have that re-sprayed.
I decided whilst I was at it to have the front end re-sprayed so the front end had the same treatment to get rid of those horrid stone chips and some small marks.
Chips by Lawro1988, on Flickr
After searching for months I finally got my hands on a set of cup washer blanks from Bobby so they were given to James to be sprayed and fitted in place along with a new set of fog lights from Luke. as one of mine had cracked over the winter.
Having had the front bumper re-sprayed I purchased a set of bumper inserts from Simon @ Sprayshack to replace the original items and a new genuine cup splitter as mine was beginning to show its age. Again, purchased from Adam @ Wolverhampton Renault.
Replacement parts by Lawro1988, on Flickr
The car was fitted with some anthracite coloured bullets which were looking very tired and weren’t the best colour match so I purchased some of Sprayshack’s smoothed bullets in cup ‘205-110’ anthracite with Titanium Silver lettering.
SprayShack Bullets by Lawro1988, on Flickr
Before they were fitted the standard bump strips were removed and re-sprayed by James to get rid of a few marks from car doors etc.
With all the bodywork complete, the car underwent a full de-dent. I managed to count around 5-6 small parking dents in the doors and rear quarter panels and 1 in the bottom of the drivers side door.
Finally the wheels.. After months of debating on whether to keep the cup
wheels or purchase something different I decided to keep the cup wheels and have them refurbished as they were beginning to look a little tired from stone chips and bedded brake dust. I had them blasted and fully refurbished inside and out in standard cup ‘205-110’ anthracite.
Cup Wheels by Lawro1988, on Flickr
Had them refitted with some new Continental Sport Contact 3’s.
With the car collected from James @ Restomod I gave the headlights a full correction using the 3M Headlight Restoration kit, replaced the rear number plate light with a new unit along with an LED Bulb and replaced the side repeaters along with some silvertec bulbs.
Headlights previously by Lawro1988, on Flickr
Taped up by Lawro1988, on Flickr
During Restoration by Lawro1988, on Flickr
Completed by Lawro1988, on Flickr
Side Repeaters by Lawro1988, on Flickr
Numberplate Light by Lawro1988, on Flickr
A few photos of the car on a drive out after collecting it:
Evening Hoon by Lawro1988, on Flickr
Over the next few days I got the car up in the air and spent a fair amount of time cleaning and tidying up the arches and underside of the car. Cleaned with G101, treated the plastics with 303 Aerospace and exhaust with Auto Finesse Mercury.
The front and rear calipers were painted with VHT Silver paint to tidy them up and replaced a few clips on the arch liners that were damaged or missing.
Front Arches by Lawro1988, on Flickr
CookSport Springs by Lawro1988, on Flickr
Rear Arches by Lawro1988, on Flickr
Underside by Lawro1988, on Flickr
Scorpion RS192 Cleaned by Lawro1988, on Flickr
A few weeks later I had a moment of madness and after paying £240 on a wheel refurb I decided to fork out on a brand new set of Speedline Turini's along with a set of TPI polarised wheel bolts.
Speedline Turini by Lawro1988, on Flickr
TPI Polarised Bolts by Lawro1988, on Flickr
Gave them a coat of G-Techniq C5 Sealant and fitted up with a set of Continental Sport Contact 3's.
Speedline Turini's fitted by Lawro1988, on Flickr
I then decided to clean up the engine bay as it was really letting the car down. Unfortunately I don't have any photos of it before, safe to say it was awful! The previous owner painted the inlets with tipex or similar and it was just generally a mess.
I started off with the inlets and got myself some 519 Automotive matched inlets from a forum member. Coated those in Silver along with the fuel rail guard, throttle body and engine mount bracket.
I replaced the JMS V6 style airbox that came on the car for a standard tidy 182 airbox as I think they look a lot better. Replaced the hose with a Silicone item and the filter with an ITG panel.
Powdercoated Inlets by Lawro1988, on Flickr
I then decided to replace all the bolts with stainless items. I replaced the slam panel, headlight and wing bolts with stainless black items and the airbox, fuel rail and engine cover with stainless steel bolts.
Stainless Airbox bolts by Lawro1988, on Flickr
Stainless Engine bolts by Lawro1988, on Flickr
Headlight/Slampanel bolts by Lawro1988, on Flickr
Before:
Before by Lawro1988, on Flickr
After:
After by Lawro1988, on Flickr
Before:
After:
Complete:
Complete by Lawro1988, on Flickr
Before:
After:
Engine Cover by Lawro1988, on Flickr
I then purchased a powdercoated black battery cover from Dan @ M.A.D, again lovely quality and some nice T-bolt stainless hose clamps to replace the jubilee clips.
Battery Cover by Lawro1988, on Flickr
Finally, the expansion tank was replaced with a nice new item from Adam at Wolverhampton Renault along with some Type-D coolant and replaced the grill and scuttle panel clips.
Expansion tank by Lawro1988, on Flickr
Clips by Lawro1988, on Flickr
Fitted by Lawro1988, on Flickr
I then gave the engine bay a good clean, polished the air con pipes with Auto Finesse Mercury, treated the plastics with 303 Aerospace and deep cleaned the bay with G101 and some Swissvax fabric cleaner.
A few photos of how it currently stands after a quick detail this weekend:
Thanks for reading, More to come.. Lawro :cool:
Having seen this at Combe this weekend I can vouch for how immaculate it is, it's a testament to your efforts, Lawro, great work!
However, do you have any plans for the centre caps, as for me they attract unnecessary attention and stand out like a sore thumb.
That looks immaculate! All the subtle changes bring the whole car together perfectly.
Hats off to you.
Thanks Tim, appreciate the comments.
I was originally planning to purchase some trophy turini's but I preferred the offset of the Speedline ones. The centre caps are something I have considered but the colour difference between the caps and wheels would annoy me even more I think lol!
Ive definitely seen you about!!!
Looks really good mate.
Thanks buddy! Give me a shout when you see me next time. :)
I recognise the plate. Do you drive up Anchor Road? Swear I saw you at the roundabout of Jacobs Well Road (Oryx roundabout).
I've given up on waving at people when I'm not in the Clio. I get dirty looks like they just saw me jizz on a granny.
For you - I'll make an exception.
Hats off to you.
Thanks mate!
Minty mint mint, mint!
Keep up the good work.
Cheers Bobby, some of your old 182 have made her how she is! If it hadn't bled me dry I would have hit you up to a deal on that 197. Good luck with the sale mate, be good to have you back in a MK2.
Lol! I live in the ghetto (Redfield) I'm not over that way much but occasionally go up to the downs so it is possible. I work in the city centre but I don't drive in very often.
I don't like taking her out in the rain lol!
Brilliant work!
I take it the satin black on the disks just rubs off?
Brilliant work!
Thanks! Yeah, the coating will be worn off the faces pretty quickly and just leaves the hub and outer edges of the discs protected against corrosion. Nothing worse than rusty discs ;)
Shed. Actual shed. Who are you though? Been a while stranger ;)
Who did you suck off to get back on here? Lol! Yeah it's been ages mate, we will have to arrange a KK meet soon!
love THIS car :approve: saw it at FCS must say thou looked MUCH better on 182 wheels IMO
Thanks mate, I was awaiting this comment lol! Yeah I do love the 182 wheels but I fancied a change.
looking good, you have gone to some effort to get it up to scratch..what other plans do you have?
Thanks, yeah it's been a labour of love and my bank balance has been heavily hit lol!
Loads of plans still, Interior is next on the list - Recaros, retrimmed steering wheel and a few other bits. A House is on the horizon so with that out of the way I will look at GT cams, RSTuning remap etc.
No one.....
Yes sort a meet out. Back to regular Sunday night meets ftw!
Best car on the forum mate :) Absolutely MINT!
I cant wait until i get my front end sorted now, its really annoying me :(
I didnt get the chance to ring the bodyshop today.
I'm not sure about the best on the forum but that means a lot, thanks mate!
Yeah I bet, it's just frustrating when you keep your car really tidy and then you notice a mark that wasn't there the last time you washed it. It's impossible to have a completely mint car if it's used daily anyway.
Wow! What a car :) See this at SRR earlier in the year but didnt realise it was this clean!!
Thanks buddy, means a lot coming from you as I love your car! SRR? I'm either being stupid or that wasn't mine lol!
Stunning - very envious :)
Cheers :)
Thats a minter. Great attention to detail too.
Cheers fella, the little things make the car IMO!
Probably one of my favourite cars on the forum! love the engine bay... I have the same car in the same colour and would love it to be like this
Real tidy car mate, lots of hours spent no doubt.
Out if interest, I like the idea of coating the discs, what type of satin paint did you use, VHT?
stunning car, love all the attention to detail. I really like this
Nothing short of incredible, love the shots up at Cheddar gorge!
Wow, really good progress. Stunning results!
Thanks guys, really appreciate the comments!
No I'm getting confused! Regardless it looks super clean, hats off to you :)
Lol, I was trying to think where I had been this year. Thanks buddy!
That looks bloody awesome. Great work and love the attention to detail with the freshen up!
Absoultely perfect. Spot on!
Cheers chaps!
Thanks mate, yeah lots of man hours involved but it's worth it in the long run.
I had mine powdercoated in Satin Black but I couldn't see any real issue with painting them with VHT paint, how long it would last though I'm not sure.
Love that, amazing all the wee details make such a big diffrence
Great work on the arches too
What's planned next?
I want to finish off the engine bay first, powdercoat the cambelt cover in silver and replace the engine mounts. Undecided on whether to replace with OEM parts or solid mounts though.
Also want to do something with the PAS resevouir as I think it really lets down the engine bay, I have seen a few people have sprayed them black so that's an option.
I have considered having the engine cover sprayed anthracite, not sure whether to or just leave it silver..
Stunning condition mate, needs Renault centre caps to make it look standard though.
I love doing this to my cars I plan to keep, you know everything is as it should be but it don't get much time for this now unfortunately.
