Golf 7.5R & Clio 200
Guys, I have a 30Ml sample of CarPro Hydr02 that has been sat with my stuff for a few months - Anyone used it before? Any good or should i just leave it there?
Scrooge used it and rates it IIRC
Thinking of topping up my cleaning box to add a few bits, what do you all think to this list, is there anything you would add or change?
All auto finesse,
Avalanche
Citrus power
Iron out
Tripple
Oblitarate
Clay bar
Glide
And possibly temptation (as a need a wax)
Can't go wrong with AF stuff. Would use a different wheel cleaner though, will get expensive!
All auto finesse,
Avalanche
Citrus power
Iron out
Tripple
Oblitarate
Clay bar
Glide
What do you all think of af tough coat?
it all depends on your belief of what a snow foam can do. many on DW confuse actual fact with persona opinion.
if you think its going tonbe a touchless wash you'll be dissapointed. use it as a tool to remove the worst of the grime as it will typically soften a lot more dirt than pressure rinse alone, but will alsways need a proper contact wash to come clean. think of it as nothing more than an aid to your main wash and you wont be dissapointed
avalanche seemed to worknas well as all the others, they all seem to perform to a similar level in my use, but depends if you want a thick dense foam that will cling for 30minutes, or happy with something that will start to run off after 5minutes, but it still softens grime just ad much as others
So tempted to try avalanche but it's so expensive for something that gets mixed reviews
Cheers, I have just diluted some 3-1 with distilled water to use as a QD. Doing to try this this weekend2 mf cloths is a lot easier mate.
Great idea mate, old C2 diluted worked really well even as a standalone sealant.
I can sort you out with a sample if you wish Jaff, I have 5L that has hardly been touched as I CBA getting my snow foam out!
Arrrrrr ok....even if not in a hard water area?
So should this be used all the time for best outcome?
I would use it all the time, its not hard to get some![]()
So you never use a hose pipe? Or jet wash?
Yes mate that would be great.
Tried the c2v3 on my white car, miles easier to use compared to using it on Black
What are people using for wheel brushes?
I need it to work on the standard 182 alloys and TD 1.2's specifically, and potentially Turinis in the future. Obviously this will have a bearing on width of the brush etc...
Don't mind having maybe 2 for different applications but don't want to go overboard
Budget of around £20 for both sufficient?
