‘Claud’ The RB 182
Advikaz
Also worth noting, genuine Renault valeo clutches have thicker straps on them compared to the ‘oem’ valeo that you can get from the likes of ECP and GSF. The straps on those ones are noticeably less substantial.
Food for thought then on an ‘upgraded’ option perhaps …?
Advikaz
On a different note
After my gearbox spilt its gutts, the Marshalls told me I was just about to be black flagged for noise
8db over apparently …. Silencers have moved so hoping it’s just a leak
Mr Underhill
On a different note
What are the limits at Brands?
Pure Motorsport exhausts with sports cat and centre silencers are between 89-92 dB on stock engines.
My new car has consistently been 97db with the same system and that ridiculously loud engine.
Advikaz
105 static and 92 flyby.
I was 94 static, but apparently 100 on the fly which seems unrealistic to me…
That’s why I’m wondering if the exhaust shifting has caused an issue
Decatted Milltek non res
JamesBryan
Never had a problem with the exact same setup on mine. Although I never did Brands.
Same noise limits as everywhere else though.
Mr Underhill
Hmmm I’ve never been to a track for a while that uses flyby so I’m not sure what mine would be. Make the journey North.
Clart
Not seen anyone get done for noise at donnington and there was some very loud cars there.
Advikaz
Cracking view
Advikaz
Whose going to fix it mate? Its nigh on the perfect RB tae👌🏼
Thanks for the nice comments mate.
I’m sourcing a second box hopefully from @Udder Nonce , will be sending it to Mark @NorthloopCup to check over and refresh where necessary.
Plan is to replace anything on the second box that is even remotely worn and do the seals and syncro’s etc for peace of mind because I cannot be assed putting another box in to find more issues/have another drive related problem within a short time period and have to drag the b*****d back out again.
Then fit a diff and a new clutch as well as potentially, the drive shafts also.
Advikaz
No half measures with you my guy, fair play Sir👌🏼
My bank account doesn’t enjoy this.
My background is racing though, and I’ve spent too much time over the years re fixing other peoples bodge jobs and half jobs. Nothing worse than getting to track and spending all that money and then having a mechanical that, within reason, could be avoided x
Advikaz
Finally got round to cleaning the clio. Had pretty much been left since the box (now suspected diff) crapped itself. So looked a bit sorry for itself, dirty, oily and covered in brake dust.
Took a while to get all the oil off, but has appeased my ocd making it atleast look good again despite the hole in the gearbox 😂
Missing being able to use it already
Advikaz
Things have got further out of hand since we last spoke.
I ordered all of the above…. As well as,
I’ve got a new box inbound that’s being refreshed by mark.
Refurbed arms with new poly bushes and pure plates.
Oem clutch tube.
Lemforder New track rod ends.
Lemforder New ball joints.
Refurbed hubs with snr bearings.
Complete subframe refurb and arb etc.
New drive shafts.
Make. It. Stop.
