3,304 days ago since I owned a Renault ..
andybond
3,304 days ago I sold my fantastic glacier white r26.
My passat was starting to get a bit long in the tooth with multiple issues that were going to cost more than the car to fix. Wife Bond wouldnt drive the passat as she said it didnt feel safe but I thought otherwise.
The final nail in the coffin was the very helpful Paul from https://diamond-performance.co.uk/ changing over the coolant pump 2 and it making no difference. He spent hours searching for electrical faults but its in the loom somewhere. It just not worth fixing.
I didnt know , or want to replace it really so I had a look around and settled on a Ph1 Clio 172. Except I couldn't find any of perceived value. They were either shitboxes are £10k. Absolutely nothing inbetween.
So I purchased a Mondial blue 172 clio cup, blind.
As ever the car I want isnt in the village, or even county near me. Its the other side of the country. 3mi away from Coombe as it happens. I have been on 2 trains , 2 cancelled trains and 6hrs of sitting down patiently watching scenery go by.
The return leg was faster, but not by much as I got used to new noises , vibrations and feedback.
What exactly have I bought?
A Mondial blue 172 clio cup
123k
Belts and dephaser done 10months ago
Generally pretty sound
Almost standard - just an exhaust and springs
One light needs a buff to remove the hazing
slight rust bubble on bonnet
slight lacquer peel on nearside a pillar
Center dash LCD is U/S.
Idle hunts a little ( air leak? )
Driveshaft click when on full lock to the right
Going into 4th quickly when cold results in a shudder. Fine when warm
I have only been on motorways and the odd B road between the seller and my home. The car appears to pick up well , stop well and has average brake feel. Perhaps I have gotten used to the lotus?
I haven't pressed on really yet. This will be explored.
Few sellers pics attached and couple of mine :
Andy P
  Clio 172, i20N
Looks a nice base to work with.
The Lotus Cortina in the background needed more photos though.:)
The Cortina has been in that showroom for a few years now.
andybond
In my quest for Clio 172 cup perfection ( or just to go broke ) I have decided to start with the lumpy idle.
Not so sure it is lumpy now, Any pointers? Have checked the gaskets at the mating faces where the intake is with a spray of WD40 but no note detected :
Cold
Warmer
Rear End K-Tec stealth
I also noted the radio doesnt seem to do a great deal other than play static. However , someone installed a parrot not of the feathered / flying variety and I put in the default pin and what do you know? It works.
The standard systems is shocking bad , but it works!
Oh and the center radio / time / temperature clock thing doesnt work. I have a spare kindly donated by @paul b. I am just working out when I have time to remove the screws that hold the dash top in place and refit the dead one.
Matt Cup
  Leon Cupra
I don’t remember either of mine being particularly smooth (even after a fresh cambelt/dephaser) to be honest so sounds normal to me.
Brigsy
  T.Turbo
Any ways to tell if the timing is out other than on a RR / with locking tools?
Map sensor vac readings on idle are usually off if cam timing is out. Im sure mine was around 400mbar on idle when correct.
Its hard to tell in the vids but doesnt look too bad. F4r is not really refined
andybond
I am curious if its being amplified by the megaphone Ktec stealth exhaust?
andybond
I had a spare 30 minutes today so decided to hit some of the plastics with a bit of autofiness rejuvenate. I appreciate this wont last forever and Ill most likely remove the plastic and dust in a black rattle can but for now they came up ok
Before :
After :
I got a little carried away and attempted the wing mirror bits and wiper plastics.
