'91 1.4RT Bendix to RSi Lucas caliper swap - Help?
Car  1.6 Rotrex High Comp
I am in the process of swapping the above calipers, discs and pads but need information about the caliper mounting bolts...
My bendix (solid disc) calipers slide on the mounting bolts, and the lucas (vented disc) caliper carriers mount directly to the hub...
So my bolts won't do the job. Can I use my bendix sliders as spacers (presumably I'll have to cut them down a bit) or does anyone know the part number for the mounting bolts I need...
Renault Wigan are trying their best - but their technical knowledge is lacking to say the least...
Yes, geriatric mk1...
I was given the calipers and discs for free... Plus, I've only got little wheels...
hm still for the hassle of changing it you might as well get the proper job, doesn't cost much for valver brakes :p they fit behind 14inch RSI alloys!
I bet 4 bolts is cheaper than a whole new brake set up. Mind you, with Renault's pricing ;)
Can anyone give me any other options?
