Trying to unlock the GOL Magnum currently but I'm having so bloody luck.
Also noticed a few maps in the server options that I've never seen before.
Given up with it. @Scutch is the same IIRC.
If it went back to how it was in Bad Company 2 I wouldn't be unhappy.
^exactly this, I always said a similar thing about bf3 too. Stop pushing the sale of premium and other bulls**t and fix it properly.
They don't make money from fixing it though. People will still buy add-on's for faulty products, and while they do, Dice/EA have no problems taking it.
There will be more maps to buy before the game is anywhere near fixed.
I'm looking forward to the naval assault maps - also had a look and some good unlocks too. There's a very interesting new LMG which I have my eye on (the AWS), as well as a rather fetching new camo which is black and bright orange.
My favourite gun by far is the ACE52 carbine with suppressor, holo scope and tri beam laser.
I can't get on with assault rifles, at all.
The ACE 23 is dope if you can be bothered to work for it. I just used the AK12 to get it, took a while but was worth it!
Generally though I like using the carbines, although want to have one good gun in each class. Level 67 now and probably only used about 7 or 8 guns 'properly'.
I've maxed out carbines now, so need to work on unlocking some shotguns (not unlocked one yet!) and a few more assault rifles.
Agreed about getting a good setup in each class - only level 46 myself.
Do you have the Naval Strike already then?? It's not out on 360 yet
Im premium but cant see the NS maps yet. Says I havent downloaded the DLC. Its not in the store.
FFS.
Be really looking forward to titan mode.I Played it like a boss on 2142 . When the enemy shield goes down and you had a few silos and didn't manage to destroy the 2 m com the missiles will eventually destroy the titan. You had a upper and lower deck on the rear for landing aircraft. 2 entry points on the rear 1 upper and one lower. Plus you had a little bit where you could fire AA guns from inside for defence you had 4 of them covering 360 degrees of the titan
Still one of the best game modes in online FPS that I've ever played. Not quite sure how well it will translate into a modern-day setting with carriers, etc. After all, half of the fun on 2142 was sneaking in an APC underneath a Titan, then guiding your drop-pod in with precision and wiping out the defenders.
Those were the days
D.
