I heard you've got some new wheels, must've been jealous of the refurb when niall sent you the photos
Realised I said alright many times in that post.Took it for a drive and it feels alright. My ghetto vernier measured alignment also feels alright surprisingly.
Brembos are much firmer now after a good bleed and the bite of the brembo pads is still alright. I can live with the reduction in performance just because they're now silent.
I Range rover reversed into the front wheel at about 2mph. Luckily no real damage other than a slight scratch and the banana track rod, I had to cut it to get the best tool in the world on.Jeez, what happened to that TRE in pic?
Who sells the abs brackets ?Decided my cable ties maybe werent a permanent fix so bought some new arb brackets. These were the last ones kam had in stock and they're now discontinued by renault...
Strange how both old ones snapped in the exact same place. It's clearly the stiffness of the arb combined with the black series polybushes which causes this issue.
Slathered in some copper slips to ease with fitment.
Whilst I was there I fitted my stainless abs brackets. I didn't clean anything else, obviously.
Job jobbed.
Kam racingWho sells the abs brackets ?
Isn't he expensive 🤣Can get them through Cfab too
I read this as arb. Sorry yeah Dave is right, they were from ebay.Who sells the abs brackets ?
Literally was reading your project then it popped up on next page 🤣🤣I read this as arb. Sorry yeah Dave is right, they were from ebay.
No idea, just remember considering some and then realising my gaz's don't have anywhere for the brackets anyway so never botheredIsn't he expensive 🤣
So priced higher than the eBay ones then🤣
Not as bad as expected based on comments on some other products
Was probably mates ratesNot as bad as expected based on comments on some other products
I was in @Cookson's gardenNice prison view
Driving home from work on Wednesday night and shifting into 2nd my foot went straight to the floor and this clutch cable snapped.That time again when the cars due a service, first one since the refreshed gearbox went in so treated it to the same MTL as before.
Moved onto the new Castrol oils after using the ELF for the last 4 years. Engine will probably blow up next week now 😂 Relatively painless job apart from the oil filter being properly stuck on! No idea why as I'd not done it tight the year before.
Mileage shot, nearly at the big 150k.
A job I've been putting off is replacing the clutch cable. Noticed when swapping the gearbox it was looking a little worse for wear.
This job wasnt as easy as servicing the car... Theres a small clip under the pedals which needs prizing off however I was unsure how much force it could take before snapping. Didnt actually have to worry as it was surprisingly strong and popped off with a screwdriver and a pair of pliers. Tied some string around the old cable and pulled it out.
Bagged a new genuine item from RPD and it's obviously the newer style with a heavier weight along its length. You can also see on the old that its perished on the end and the internal lining was moving within the sheath.
Refitting wasnt quite as easy and removing as you had to guide the line around tbe back of the sound deadening. Such a faff and my arms got absolutely ruined by the back of the deadening. All clipped in and refitted anyway!
View attachment 1545387View attachment 1545386View attachment 1545391
Took the car for a drive today and it does feel better but not by a huge margin. Definitely worth changing due to the above issues but definitely not a hugely noticeable difference in the shift unfortunately. I'm going to disconnect it from the clutch and reset the mech just to see if that adds any improvement.
If you plan on doing this yourself just dont be shy on the clip by the pedals and use a strong bit of string on the old cable.
159,999. Might treat it to an back sack and crack wash this week.How many with the eml on?
What did he charge you mate?As an upstanding member of society, i decided to have a 400 cell sports cat section made up. I'm told this will pass an MOT, and isn't for track use only 👺👹
I was also wanted to be able to easily swap over my exhaust from cat to decat (when in Mexico 👁👄👁) so had a vband flange welded in to replace the existing slip joint on the milltek system.
Took the car to Powerflow Halifax and James did a fantastic job for a reasonable price. Some pics below of before and after. Can see the original vband flange I had done at CSK on the decat to manifold joint;
View attachment 1631095View attachment 1631096View attachment 1631097View attachment 1631098View attachment 1631099View attachment 1631100View attachment 1631101View attachment 1631102View attachment 1631103View attachment 1631104
What was forgotten was a boss for the lambda, so he took the cat back and will weld this in for me. I read to fresh air currently but would rather not have an EML lit up.
Hopefully a cat thief will be able to tell this isn't genuine and will rob the cat off the nearest jazz instead.
I was charged £365 for;What did he charge you mate?
You've a flexi manifold youMine was £350 ish 3 years ago, they did weld it wonky though.
Mine gaeve the emissions of a vauxhal astra 10 years younger then the Clio. Bloody amazing thing!we should have a sports cat challenge… see who has the best one… best will defined by me after the test 🤣
looks smart, reasonable price as well really
This should pass fine, expecially being 400cell. It was my only requirement tbh 🤣we should have a sports cat challenge… see who has the best one… best will defined by me after the test 🤣
