Golf GTD Mk7
Wouldn't even matter if they were shorter - if you talk to anyone that understands the way bolts work - 90% of the stress is taken on the first 3 or 4 threads
If the bolts come out - it wasn't torqued up properly - simple as
Just like everything else on the initial build of this car - no detail to attention at all. I think that's fairly obvious just looking at the wiring loom lol
Not the same, but for example, my exhaust cam spun after a garage changed the belts. I had fitted CATCAM 421s which were used, and because the stud was had shrunk slightly, and even though the nut was torqued up correctly, it loosened off and spun
