This is my Dash 2 loom if it is of any interest (un shrouded). It retains all the signal leads, Analogue inputs, switch & switch common lines and its own earth and switched power supply. Terminated with a ITT Neptune 19/19 connector. The harnesses in the car are entirely modular so this is an example of that approach - they all terminate at the fuse box. I have included all of the above (less some of the signal wires such as RPM / wheel speed) for future proofing, but I will send oil temp / pressure directly to the dash as I don't see the value of it logging wise - the oil pressure performance can monitored ok through alarms in my opinion but can see the value of logging if you can support it. Other ECU data such as RPM/wheel speed is sent via the CANbus - (although technically the screen is not true CAN as it only displays recieved messages via addresses.)
The second connector in the harnesses it the switch panel breakout (for dash buttons.)
