I'm amazed people aren't having issues with boiling brake fluid it's so close. Knew it was going to be a tight fit before I started but never imagined there'd be so little clearanceWill be keeping an eye on the pedal box you've ordered, i've been playing with the idea of fitting one as the downpipe sits so close to the master cylinder. But will have to wait until I decide to do the vag or r26 gearbox conversion.
Looking forward to updates.
At the moment that's my intention. The Megane throttle uses a linkage to operate the position sensor so hoping to attach the pedal box throttle with a linkage as well. Just been and picked the pedal box and other parts up so will have a look tonight if I get back from work early enoughAre you still going to use the drive by wire throttle body with the pedal box?
I've got zero clearance between the downpipe and the master cylinder so can't even relocate the reservoir like you've done. Anyway got the pedal box now and that's excitingI know its so close, I relocated the brake fluid reservoir to behind the bulkhead, and used some heat shield to protect the brake lines and master cylinder, not boiled my fluid as of yet but its always in the back of my mind.
Yeah we were at oulton in April, car was red then though instead of rattle can primer greySure I seen you at Aintree a few months ago and Oulton in April? This will be a beast when finished!!!
Looks amazing that's why dude. Constantly watching this thread mate.Stuck at work waiting for some things to finish so won't get to do anything tonight. On the plus side put the pedal box together
For some reason I think it's the coolest part I've bought
Looking forward to the pedal box install. This is something I want to do to mine.
I've got zero clearance between the downpipe and the master cylinder so can't even relocate the reservoir like you've done. Anyway got the pedal box now and that's exciting :smiley: Because Racecar :smiley:
Out of interest, how come you've got no clearance whereas Rob does?
Nice to see that the engine mounts all line up afterall, what about the dogbone?
You mean manifold and downpipe for a turbo conversion? No, didn't consider that, what diameter are they?Getting a little nervous reading this, sounds like you should make it in time!
I also just in the process of converting my car to 225 - did you think about using a 172 cup turbo mani and and downpipe?
Although i think ill be going for the meg mani and just getting a downpipe made :smile:
Sent from my SM-G935F using Tapatalk
So what's left on the 'to do' list?
Progress looks epic!
2.5" thats the way im going, means it bolts straight into a 172 exhaust aswell
Would it maybe not be a case of joining some wires on the left over epas plug then?Think I know why the bloody dash cluster doesn't work. Below is the Megane car network - item 9 is the instrument cluster which runs through number 8 which isn't connected as it's the EPAS ecu I sold. FFS. Need to find one and hopefully the instruments will magically spring to life...View attachment 162482
Good idea. Wonder if the manual has the pin outs for the EPAS. Has everything elseWould it maybe not be a case of joining some wires on the left over epas plug then?
Get a spare bit of wire and start poking aroundGood idea. Wonder if the manual has the pin outs for the EPAS. Has everything else
Get a spare bit of wire and start poking around :wink:
Good stuff mate, dont suppose you have the pin out for the 225 throttle body? Need to wire the 172 loom into it!Found it. Looks like bridge pins 4&5 and 6&7 of the EPAS ecu plug. Will try it tonight.
