imprezaworks
Mk5 Golf GTI :)
The wheel is on a spline so can just be removed and refitted
:smile:.
Fatty all day long
Standard filter noise is zero. You would notice the difference immediately. Suprised you haven't got that set up tbh. The noise is great :smile:
@leeds2592 sounds standard low down the revs but as soon as you get above 3.5k revs or so it sounds brilliant, definitely worth the £30 or so.
Sounds like a ferrari in comparison!Thanks guys. Something else to go on my never ending list!
Are you sure your wheels are straight? If you look ill guarantee that your wheels are slightly facing right. You cant put the wheel on wrong.
The splines should have a groove on them so you know which is the top.
I reckon 5mm spacers will solve this
This might be the moment when you realise a smaller wheel should be on the list too.
You would notice a massive difference in how it drives
epic fail on the wheel...have fun getting it back off:laughing::laughing::laughing::laughing::laughing::laughing:
i did one that had been put on cockeyed, nightmare to get it back off. if you look there are three thick splines to locate the wheel straight. don't bother disconnecting the battery to unplug the airbag.
three splines are easy to spot when you look for them. wheel should come loose with a swift bang to each side so could of been on cockeyed to begin with.
i'e never bothered disconnecting the battery and never had a problem, plenty of people have said about how they always disconnect the battery for 30 minutes to let capacitors discharge yet when questioned not come across a single one who earths themselves to the vehicle. got more chance of setting one off with static.
Isn't that exactly where the gearbox refill/overflow is? So could just be oil from when it was filled? Mine is the same there.
Need a hand at all doing the wheel mate? Just shout if so.
Can't fathom how you have managed to end up with it like that though, as the steering wheel splines have a slight groove at 12 'o' clock so it can only go on one way. Unless by smashing it on you have managed to somehow do without the grooveI recently took my Snappy wheel off and refitted it same day (wrong boss arrived for aftermarket wheel but only noticed after taking wheel off) and it only required a bit of forceful wiggling to get it off/back on!
But yeah give us a shout if you want a hand.
Car ok?
Just buy it nice things, it's less likely to break then :wink:
