Davys 172 Flamer!
I know it'll be early days but found any advantages from changing the filter from the panel filter to fattys?
Thinking about doing the same with mine and getting one of the battery covers in the 2nd GB.
Standard filter noise is zero. You would notice the difference immediately. Suprised you haven't got that set up tbh. The noise is great :)
Standard filter noise is zero. You would notice the difference immediately. Suprised you haven't got that set up tbh. The noise is great :smile:
@leeds2592 sounds standard low down the revs but as soon as you get above 3.5k revs or so it sounds brilliant, definitely worth the £30 or so.
Thanks guys. Something else to go on my never ending list!
Are you sure your wheels are straight? If you look ill guarantee that your wheels are slightly facing right. You cant put the wheel on wrong.
epic fail on the wheel...have fun getting it back off:laughing::laughing::laughing::laughing::laughing::laughing:
i did one that had been put on cockeyed, nightmare to get it back off. if you look there are three thick splines to locate the wheel straight. don't bother disconnecting the battery to unplug the airbag.
I struggled to get it off in the first place, had to hit a piece of wood behind the wheel for bloody ages. Was extremely hard getting it on too. Cant wait to remove it...
How come not disconnecting the airbag? Also.. regarding the 3splines, is it obvious how they locate it?
three splines are easy to spot when you look for them. wheel should come loose with a swift bang to each side so could of been on cockeyed to begin with.
i'e never bothered disconnecting the battery and never had a problem, plenty of people have said about how they always disconnect the battery for 30 minutes to let capacitors discharge yet when questioned not come across a single one who earths themselves to the vehicle. got more chance of setting one off with static.
Cheers mate, will give it a go at the weekend.
Isn't that exactly where the gearbox refill/overflow is? So could just be oil from when it was filled? Mine is the same there.
Need a hand at all doing the wheel mate? Just shout if so.
Can't fathom how you have managed to end up with it like that though, as the steering wheel splines have a slight groove at 12 'o' clock so it can only go on one way. Unless by smashing it on you have managed to somehow do without the groove 😂 I recently took my Snappy wheel off and refitted it same day (wrong boss arrived for aftermarket wheel but only noticed after taking wheel off) and it only required a bit of forceful wiggling to get it off/back on!
But yeah give us a shout if you want a hand.
Interesting to know, I'd installed a K&N panel filter as I didn't believe the hype but I'd love to hear how moving from the K&N panel filter to a fatty's works for you @leeds2592 .
Probably something I'll find myself doing at some point too.
Haha ive not a clue mate. It was seriously difficult to get off and put back on, so im wondering if it had been put on wrong in the past. I'll try again at the weekend mate and ill give you a message if I somehow fail again!!
@bloke @Ash J does this look better?
The big top centre one was miles to the right before..
Yep that is how it should be mate, that bigger centre spline at the top is the groove I was talking about which can only go on one way.
Glad you got it sorted.
