Diff seal? Ph1 172
  172
My clio is leaking oil it looks to be coming from the Diff/box seal on the O/S as best i can tell leaking from the rubber seal between the diff and the driveshaft extender thingy (Can't remember its proper name), Its not a drip either but not spewing out assuming it is the diff seal is it a easy job?
Did a quick search but could not find much most leaks were the input shaft etc although my searching skills are not great :eek:
  172
Cheers Fred much appreciated,
So remove Shaft, Drain box oil and swap seal over?
Anyone know the correct name / part number looks like i need to ring Renault
Need a bit more advice,
Before ordering the bits i removed the drip tray and cleaned everything up oil defiantely looked to be coming from diff seal so whilst i was under there i pushed the drive shaft in and out pushed the seal etc and as result its no longer leaking :S Been on a few drives and had it on off ramps double checking not a drop.
Is it possible it was not sat in right i changed the springs last month so could have disturbed it then.
I've got a genuine Renault seal spare I can send it today, £7.50 recorded 1st class :)
Can i let you know in a day or two? Don't fancy stripping it down if its fixed itself :)
