Headlight bulb removal Ph1 172
Car  182
Help! This is proving to be a right pain the arse! For some reason I just cant get the bulb out, ive managed to unscrew the bulb from the rubber dust cover thingy so I can see the whole bulb. But I'm not sure how to get the bulb out the holder now? Flat head screw driver under the metal sill type thing?
I know im a tard! But this is pissing me right off now! Also is the bulb H7 or HB3? Cheers!
You turn it through about 90 degrees then pull it out IIRC. Screwdriver ?! You'll f**k something up...
Is this the 'normal' one or the one with the plastic L bend on it ?
Ahhhhhhh I just thought your not trying to separate the bulb from the 'L' bend are you if so don't! And that's a hb3 bulb the clip should come off pretty easy though
