Icemans Britcar Endurance project 182
Hi Guys
Things have already been going hot and fast, this is the list of whats remaining, some very nice parts in there even if I do say so myself. I shall post this in the for sale section also.
If you want somewthing PM me and then pay via PayPal. Shell will have to be collection.
The prices are more than fair and have been gone over by 3 other people to make sure. If you don't like the price you are free to buy the parts new.
Do NOT post offers in this thread, I will ignore them. If you would like to buy an item PM me and I will give you my paypal address, upon receipt of payment I will take the part off the list. I will ammend the list as I recieve payment and untill I recieve payment it's first come first served on everything.
ALL parts are collection from Peterborough or postage and you pay postage. If you want it posted then we will agree a price based on weight (I will weigh the item where I can) and then you can paypal the extra.
Happy browsing
Clio 182 flat boot Shell with FIA Custom Cages cage, plus all the pages of FIA paperwork, painted white inside
The shell also comes with the following:
A FULL motorsport interior wiring loom and floor mounted wiring station with relays, fuses etc
A custom made switch panel with starter button etc (can be seen in my build thread)
A custom made ally unique switch panel housing (can be seen in my build thread)
Carbon wrapped roof and tailgate
Both front lightened doors
Lightened Tailgate
New windscreen
OMP FIA cage padding fitted drivers side
Lowered ally floor drivers side with ally foot rest
Front subframe with Pure motorsport wishbones with solid bearingsa and stiffeing plates fitted
Rear beam with pure motorsport solid bearings and custom made 10mm spacers on hubs
Two camber shims for rear
Powerflex ARB bushes on ARB
Dog Bone (twisted) with powerflex bushes x 2 sets
Cartech solid state battery isolator (with exterior and interior buttons)
Plastic gutter covers
Washer bottle on drivers side with pump (wired to stalks)
Flocked dash
Ceramic Heater to windscreen
New Steering column (lowered)
The interior Loom goes to standard Renault stalks which are on the steering column
Cartech rear LED rain light (wired into fog light stalk)
Front xenon headlights
Headlight blanking plates
Cup brake servo with pedals and rear bias valve
Cup master cylinder
All brake pipes in situ (new)
Rear braided brake hoses
Handbrake and cable
Fuel tank with new pump
Carbon tank cover inside
Front and rear tow eyes in Orange
Rear Bumper
Front bumper (Bit cracked and scuffed)
Brake cooling kit
£4750
Race Engine Complete done 3 hours total running:
Honed Bores
New Rings
ARP Crank stud kit
ARP head stud kit
New sump
New oil pump and chain and guides
Crank polished and balanced
New main bearings
New big end bearings
New thrust bearings
ARP rod bolts
Head skimmed
Valves re cut and seated
ARP valve springs
Cat cams 421 Cams
Cat Cams solid vernier pulleys
Ally main pulley
New timing belt
New timing belt pulleys (all of them)
Some Spare gaskets
Makes 210 at flywheel
£2,500
Ultraleggera Wheels in Silver 15 x 7 (small scuffs) £350
Ultraleggera Wheels in black (mint) with brand new Dunlop Direzza 205/50/15 Tires £900
Helix Paddle Clutch Kit £400
Lightened flywheel 210mm plate size £200
Lightened flywheel 200mm plate size £200
Standard flywheel £50
Carbon Bonnet with vents £200
Polo radiators x 2 (one new) £35
Race Technology Video 4, 2 normal cameras, 1 HD camera, 3 stack mounts, 1 custom mount, 4 very high speed CF cards £1,300
Race Technology DL1 data logger £400
Willwood Front Brake Calipers plus hoses plus two sets of half worn Mintex F4R pads £400
Brembo Front brake discs £100
Renault Rear brake calipers £125
Brembo Rear brake discs x 2 £100
Brembo Rear brake discs (new) x 2 £125
Rebuilt Gearbox with Gripper 10% shorter final drive kit and Gripper plate differential £1,650
Rebuilt standard 182 Gearbox £300
Ktech Exhaust with decat pipe £250
Prima racing rear exhaust mounts x 2 £50
Wrapped 182 exhaust manifold £100
lambda sensor £25
Alloy Bailey header tank £70
Blue Alloy catch tank plus samco hose £35
Samco Blue Hoses £125
Plastic windows with sliders with black borders x 2 front doors moulded x 2 rear quarters moulded x 1 rear moulded screen £350
Oreca Door cards and rear quarters £125
Drive shaft wet side (new) £125
Drive shaft dry side (new) £125
OMP Strut Brace £75
Storm single Wiper Kit with wash jets and blade £50
Wiper Motor £35
Wiper Motor £35
Rear wiper plus motor £50
Vibrotechnic Engine mounts £140
Starter Motor £85
Starter Motor £85
Cup air con delete kit with cup alternator £250
ABS system pump plus pipes £125
ABS new front sensors x 2 £50
Front hub with new bearing and bottom ball joint £75
Plug leads x 4 in blue £45
Plug leads x 4 in blue (new in box) £70
Race Plugs x 4 £25
Race Plugs x 4 £25
Carbon interior door handles £50
Renault steering boss £40
Sparco blue door net with quick release kit £100
Power Steering rack with new track rod ends, bushes and gaitors £125
Saxo power steering electric pump and pipes £175
Yanoo short shift kit and renault gear stick with MoMo leather gear knob £75
Front metal ring cup tow eye £25
Eibach 25mm front spacers £80
PRICE CHANGES
Clio 182 flat boot Shell with FIA Multi Point Custom Cages cage, plus FIA paperwork, painted white inside, Plus Log Book
Lightened Tailgate
New windscreen
Front subframe with Pure motorsport wishbones with solid bearings with stiffenig plates fitted
Flocked dash
Rear Bumper
Brake cooling kit
£2500
Honed Bores
New Rings
ARP Crank stud kit
ARP head stud kit
New sump
New main bearings
New thrust bearings
ARP rod bolts
Head skimmed
ARP valve springs
Cat cams 421 Cams
Ally main pulley
New timing belt
Some Spare gaskets
£1750
Eibach front 25mm spacers £100
OMP Strut Brace £75
Wiper Motor £35
Wiper Motor £35
Starter Motor £85
Starter Motor £85
Race Plugs x 4 £25
Race Plugs x 4 £25
Renault gear stick with MoMo leather gear knob £75
LATEST LIST
PRICE CHANGES
Clio 182 flat boot Shell with FIA Custom Cages cage, plus FIA paperwork, painted white inside
Lightened Tailgate
New windscreen
Front subframe with Pure motorsport wishbones with solid bearings and stiffeing plates fitted
Flocked dash
Rear Bumper
Brake cooling kit
£2500
Ultraleggera Wheels in black (mint) with brand new Dunlop Direzza 205/50/15 Tires £800
Standard flywheel £40
Carbon Bonnet with vents £180
Polo radiators x 1 used £25
Race Technology Video 4, 2 normal cameras, 1 HD camera, 3 stack mounts, 1 custom mount, 4 very high speed CF cards and widescreen license £1,200
Brembo Front brake discs £80
Renault Rear brake calipers £100
Standard 182 Gearbox £275
Ktech twin pipe Exhaust with decat pipe £250
Wrapped 182 exhaust manifold £90
OMP Strut Brace £75
Wiper Motor £35
Wiper Motor £35
Starter Motor £75
Starter Motor £75
Cup air con delete kit with cup alternator £225
ABS system pump plus pipes £120
Race Plugs x 4 £25
Race Plugs x 4 £25
Sparco blue door net with quick release kit £75
I have also asked the series organisers if I can run a 197 with a Turbo Megane engine in it. It does not specifically dissalow this in the regs and with a lifeline ECU with switchable traction control and automatic launch that would be rather epic I wager.
Yes, the 197 should be next.:approve:
As sad as I actually am now in hindsight to see my Clio gone I am happy to say I now have an Audi S3 Turbo quattro and am going to start posting in here tomorrow all about it as I know youre eager for another one of my OCD builds LOL. This ones a beast!!
So here we go to get you started :) My new Audi S3 ex time attack car. Makes 500bhp with the large turbo on but is tatty and needs my analness on it toot sweet!
Question????
I will be painting the interior of this car white as currently it is black. So I have bought a nice white with the hardner from the automotice suppliers here and a compressor and HVLP gun etc. So how much prep do I have to do on the current cage as it is already very smooth being black and fo course there is no rust? Do I just use the degreaser I also bought on it with the scotchbrite? This left a white haze all over it by the way. Do you wipe that off with a soft cloth?
Arite Mark fair beasty you have got.
Just scotbright for a key and rub down any rough bits then degrease it and paint.
Make sure the degreaser is paint friendly so it sticks. Tack cloths are good for picking up bits of dust from the rubbing down.
Im sure it must be as I bought it from the same place but i will check. I just wondered with it as it does leave a haze on everything.
Doubt it. HVLP and airless spraying are totally different so not sure how this does both.
Might be ok for interior spraying if you're not looking for anything special.
Have you got a compressor? All you would need is a second hand devilbiss HVLP gun with gravity cup.
So you get a better finish from a compressor then, thought so. Is gravity cup better than suction fed? How do you do the roof with a gravity cup?
Strip started.. Yes it was under a pine tree for a while LOL
A very nice Spec R condensator unit and catch tank
So messy and tatty but not for long
Very nice AP water cooled 6 pots and rather large discs
So what have I found out so far?
The engine is.
Audi AXX S3 block with
Lightened and balanced crank
Forged ARM rods
Forged Pistons
Custom sump
on top of this is a Golf gti 16 valve head with cam to valve direct buckets
Race cams
Lightened valves
Race springs
Custom rocker cover by Spec R
Revs to 9200 if asked Oerrr
Spec R Intercooler
Spec R Rocker Cover
Spec R radiator
I have 3 garret turbos with it one of which is huge, the smallest one is fitted for obvious power reasons
Turbosmart gate 50 to totally custom 70mm downpipe and exhaust
Tubular exhaust manifold
The engine is mounted solid as is the dogbone
The rear of the car is all Golf Mk5 suspension
The haldex is switchable on or off
This all sits on AST suspension
Not a bad spec methinks.
Wow! That looks like you have got a fun road ahead of you Mark lol :) look forward to seeing you put your touch on it! What are the plans for it? General tart and tidy up or full rebuild, refresh engine etc?
Better atomising with a compressor. As long as you have enough paint in the cup you should be ok on the roof.
Really smart car you have there!
AXX is an early Mk5 Golf GTI block, not an S3 one S3 would be BHZ,BHC or CDLA. There's soooo little S3 left in that :o.
Learning all the time. Amazes me how much VAG stuff is interchangeable
You shouldn't be they are all the same cars and it his how they make so much money, they have amazing economies of scale. I think they have the record for the most cars off the same platform!!
tatty? that's being kind! Looks like its been banger racing through a forest! It was a bit rough when i saw it at silverstone last! I'm sure you'll work your magic though (try and keep this one a bit longer!) Sam has a NEW gearbox for one of these with a drexler diff going spare (irecall it had some box issues before!)
Drexler Fred? Is that gripper for the Audi world?
Question? paint spraying
1. Mini gravity fed gun
2. Larger gravity fed gun
3. Suction gun
4. Paint pressure pot?
which is best?
I worry with the gravity fed gun you wont get an angle for the roof?
Mark.
PS
My comp puts out 14.4 CFM by the way.
Have a look at 3M PPS system, gravity fed but the cups basically colapse in on themselves as the paint is drawn from them so they dont die out on you.
You will probably need a mini gravity fed gun too, certain bits you will struggle with no matter what you use.
Going from black to white will be quite hard to do, any areas that are a bit shy with paint will stand out a mile.
Once you've prepped it, use some 400grit on any areas that need it, otherwise a red scotchbrite should be fine. I would mix up some of the paint in a wee pot, no thinners and allow it to start curing, ie once it's starting to go quite thick, probably need to leave it an hour or two depending on temp. Use some half decent artist brushes, about 1/2" wide but quite thin/flat and get some paint onto the back side of the hard to reach tubes, if you lay it on smooth enough, once it dries you'll not know it was brushed on, especially being white. Once it's fully cured, you could flatten it back a little with some 600 if you want.
When you come to spray the rest, you'll hopefully cover most of it but if you dont, at least its white and wont be so obvious.
Thanks kenny all ordered now and on its way. Big week this week.
Block
Head
Crank
Come back from the machinists
Big box of parts comes back from the powder coaters and I can start painting everything white.
