Mk1 F4R/172'd Track Car Project [Year 3 - Engine and Chassis Rebuild]
Re: Mk1 Hybrid Project
just stripped the head down, cams and tappets out.....all the valves look the same height, none lower than others, dont know if i would notice that like.....anyway....
i need to do a compression test again i guess, is it ok to turn over on the key? or not... i tried turning over by hand with the gauge on and all the cylinders showed zero?
iirc you are supposed to turn by hand when compression testing? Never had to do it myself
I think you should do a leak-down (if you can bring yourself to pull the head off ;)) like mini-valver said.
yeah i have decided to, just to be safe loll.....head bolts are out, just waiting for someone to come down to lift it off with me....head and both manifolds still attached, f**k dropping it after coming this far!
its alright lol, will get it off and give it a test, replace what needs to be, then i definately know all the valves are good, then drop it back in, shouldnt take too long i guess!
Quick question for you mate. After you wrapped the manifold did you paint it? With the high temperature stuff you used before you wrapped it? Thanks
Yeah, thats why it's black ;)
Jord, better to do it all again from scratch like you are, than do a Ryan and piss around for days on end to find it was exactly what was said in the first place. lol.
Your suppse to do a compression test with starter motor not by hand. If your losiing compression on one cyclinder try putting a tea spoon of oil in there, that will tell you if its piston rings. Prob a bent val thou :-( Sting.
ok, the head is off, the valves look ok.....just uploading pics now....gona do the petrol test in a minute....
What a waste of time and money.
I don't mean that in a harsh way, and i hope i'm not offending you f0xy, but that car is a pile of crap.
pfft. he's having fun leave him alone :rasp:
It's a great project with ups and downs.....this is a down.
I know what you mean mate, and i really don't want to sound negative, but every single update reads :something broken/won't fit/fell off etc and I can't really see a light at the end of the tunnel.
Im sure youll get it sorted out Jord, good things come to those who wait and all that lol
Wish i had the knowledge to go this far into a car !
I understand the point Dan is making, just as long as Jord is enjoying the project and not letting it get on top of him. Plus Jord aint no quitter! Im sure 90% of people now would have given up long ago! lol
Im sure when this is running Jord will have a big sense of achievment and also a Hybrid weapon :-p
Jords project is very insteresting and he isn't trying to cowboy it etc he is just doing a project himself and learning about it etc. He can already do more than 95% of people on here etc.
Imo there is too much of abusing peoples project thread on this forum. I think if you haven't got any constructive comments then don't comment atall as naith says above.
Hope its good new on the project btw.
foxy shame about the problems you've having dude, but consider it extra learning as you go along.
And chill ladies, dans apologised for coming across wrong, be man enough to accept it or just leave it as tbh drunkenmunkey your dick is up foxys arse currently, i think he can look after his self, judging by the thread.
I can imagnine Jord fixing his car in all weather conditions tbh!
New Post Title: "Engine Won't Start, Snow Inside Engine!"
lmfbo @ the last couple of pages....
Dan - it did come across as a bit of a nasty post fella... But you dont learn anything if you do not do stuff like this yourself.
I've been chatting to jord most evenings about this engine and f**k me its just pure bad luck tbh. If the timing marks were correctly done this wouldnt of happend. But, im sure it isnt the first time nor the last time sombody will do this lol.
It seems he's had some 33mm valves IE megane f7r valves which would of caused a problem. Not sure if hes updated since that...
I say get stuck in fella like i did at your age, its the best way to learn... ive never understood paying garage prices. :D
DIY engine building FTW :D
Lets all bloiw jord a kissy kiss.... Mwahhhhhh
Jord just sent me a quick picture explaining what happened when he turned the key about 10 minutes ago....
LOL at whats been happening while ive been outside, oh well....here goes, its all good news btw :)
Started by removing the head from the block, to see only two cylinders had been firing...
Then upon closer inspection it seemed the exhaust valves had touched at one point...
Maybe was caused when the timing was originally out.... Anyway....
Checked the pistons, they looked ok...
On closer inspection, they have been touched slightly...
Nothing to worry about really....
Anyway went on to checking out the head, I was getting good compression from cylinders 1 and 3, and bad from 2 and 4. When looking at 2 and 4, you could see the light through the block!!
Anyway, whipped the valves out, and compared them with the williams ones that were originally in the head when I got it. It seems the 'new' ones i got, were a tiny bit larger...which would obviously cause problems. This also tallied up with there being gaps in the seat, either due to me not lapping them correctly, or them being the wrong valves, or a bit of both....
Megane inlets are 33mm, Williams are 32mm....probably could be the cause of many of my problems....Thankfully the exhaust valves are the same.
Re-lapped the williams valves that came with the head, and fitted them....
Then fitted the cams back onto the head...
Once they were both fitted, put the head back onto the block in the car...
And left it at that for today.... :)
Checked the inlet and exhaust valves before refitting, and they were sealed properly this time, no light could be seen through either, so hopefully it will be all good and run nice!
AFPSML at this thread tonight, god it's funny when people argue.
:DAnd I love it when we all make up :D
Excellent work Jord! I didn't know that about megane valves, oh well live and learn. I'm sure she'll run a treat tommorrow. :)
PLEASE tell me you did a leak down before you put it back on dude?
So after all that the cause of it was meggy valves! f**ksake!! what a ball ache.
This is the sort of person Jord bought them from, with the shouting to women, "Trudy, whats the quickest way to get to Morrisons" God i love Yorkshire folk
[youtube]oMGJrMFgkfc[/youtube]
nice to see the trusty haynes manual! and good to hear its good news.
fingers crossed for tomorrow.
Hope you get it going after doing them valves lol thank fook we found that out.
