Re: Mk1 Hybrid Project
Day 169
Got a few bits and bobs sorted over the last few days, blanked the heater matrix hole up with some sheet metal and welder...The welder I had lent didnt want to play nice, wire kept sticking then had no gas...so the welds took some tidying up. After that sealed it with black sealant for now so it dosent rust...
Also blanked up the hole for the blower unit inside the scuttle area, more on that next few days...
Anyway, painted the arches (inside and out) and the slam panel, underneath the bulkhead, chassis rails, and a few more 'out of sight' areas today, with hammerite. Alot of the parts had surface rust and marks, so decided to prep it then hammerite over it to protect it. Ive left the suspension turrets and bulkhead for now, as Im not sure if to do them black, or body-colored....They need doing as they are marked, and considering ive done half of the bay, why not go the whole way...
Finished the last bits that needed painting too...Top half of the 'slam panel', wishbones, a fresh coat on the driveshafts, and the one remaining caliper...
Gearbox now finished also, just needs the brackets fitting and putting onto the engine now...
			Day 169
