my car is poorly sick - help!
  No more clio's for me!
Started her up this morning, and she sounds rougher than a bang of nails. Runny extremely lumpy, as if someone has come along and removed the complete exhaust system.
Its also smoking a little bot more than usual out the back, and it stinks! :(
Whats wrong with it??? :mad:
I think it could be the cat/exhaust, and from looking underneath the cat its jumping up and down at idol, like its lose or something :S
Dunno what to do really. :dapprove:
Would that make it run lumpy....it started ok. :S
It drove ok, just sound sh1te! and didn't have any response, almost like it was in ECU safe mode.
Da
  Less
if the coil pack has gone then yes it would run like shite because it wouldn't be firing on all cylinders :) I'm no mechanic so I could be wrong but just trying to help out mate :)
  Mondeo TDCI 130
Gaz's did this, and some how there was damp down the bloody plug holes! we had to take the top off the inlet and dry them out, it was fine one nite, missing its t*ts off the next day!
Gaz_
  Extreme mode
sounded mint though, popping and banging like a good un
Christopher
  Z4M
either coil pack (on the back of your inlet manifold) has packed up...excuse the pun. lol
or you have damp/moisture in the actual plug recesses.
take your IM off and whip the plugs out, give things a night indoors and try tomorrow. if it's still the same, it'll more than likely be the coil pack.
Ahh, the damp would explain it...rained here like fooking mental last night, and still is. :(
Can some give me a quick photo guide so i know what i'm looking at :)
Thanks for all your help guys...can always depend on you lot :D
I'll let you know how i get on. :)
Dan
  Leon Cupra R 225
print the diagram out and get out there with your umbrella lol! raining like a motherf****r out there
  DUB mk2 golf gti!
check your manifold ent cracked or needs tightning!makes um run s**t!
DID IT SOUND LIKE SCOOBY!?
I've taken the coil pack off...seems ok to me, no moisture or anything, like that. How easy is the inlet to remove??
Anyone local to malvern with some techy know how??
Dan
  CTR--VX220D
dispack is here:-
It does sound like its not fireing on all cylinders.
Its easy to take the inlet off... just a couple of bolts and some sensors that need unplugging.
lemonnobby
the manifold is easy mate, check ur leads as well they can rub on the back of the inlet manifold and arc out. manifold from the elbow from the throttle body, remove the coil pack there 2/4 10mm bolts under it or around there, remove the plug and breather from the thottle body dont think you need to disconnect from the inlet but if so it 4 10mm bolts and then the bolts along the front of the inlet disconnect the pressure sensor and anything else attached manifold off.
cheers mate :)
Right...got me mani off, checked the leads and the spark plug chamber/holes, nothing out of the ordinary. Gonna leave the mani and coil pack inside over night and see if it makes any difference??? :S
being an impatient sod, i decided to put my car back together...as all looked well and dry...still the same, so i'm guessing the coil pack is fcuked??
Is it ok to drive with the car is this condition, as i need to get it to the renault garage and thats about 7 miles away?? The car running really rich and producing a bit of smoke from the exhaust. :(
Hope its nothing more terminal??
One thing i can try is my mates clio, get his coil pack and try it in my clio, see if it makes any difference??
Other than that, i surpose i'd have to AA the car to the renault garage?
  DUB mk2 golf gti!
haha people will think your driving 1 of them 3 cylinder dihatsui's,until of corse they see the car!:D
lemonnobby
unless ur mates car is a 172/182 i wouldnt try it, i would AA to renault yes or just get the part and try it. what were the plugs like?
