My valver/172 project
the connectors are different :p
ive not got any lambdas connected.. would that fox it?
surely you need to have a lambda connected as its an important sensors that measures oxygen in the exh then sends a signal to the ecu to help with fueling??? when i disconected mine it ran like a piece of s**t and would'nt idle/cut out etc....
oops, forgot to update this...
tensioner not done up correctly (Dan's fault)
cam cover off
bit of damage caused by the broken spring
head off
head bolts and followers
1 step forward, 8 steps backwards:
damage to piston 2 caused by a stuck valve
hence the poor idle
stuck valve:
running rich? :D
detting much?
parafin in the upturned head to do a cheap leak test :D
valve removed:
bent
valve spring mashed
retainer
valve stem seal
here is where it gets a little interesting...
anyone know what this is (or what it's from should I say):
it rattled out when i turned the head over
wonder if it was dropped in maliciously or not :S :S :dead:
I've gone and bought a new valve, new seal, new spring, new retainer, new collet etc... and have some spring compressors
Got renault to 'express' them so I picked them up this morning (instead of Tuesday!) except they only sent 1 single collect... which is useless, so i've gotta go back on tuesday anyway to pick up the other one.
Then it should be a case of putting it all back together, tightening and timing it up and it should run! (again)
Massive thanks to ben_p, BenR, stan*, ditz, mini-valver, Fred, bmh.01 (to name a few - sorry if I've missed someone :o) for helping em through it all! :D really appreciate it! :)
Sorry to hear you've had such a hard time with it mate, don't suppose you've heard from Dan since?
Still, at least it's getting there slowly... look forward to seeing it at July's airfield!
Dan's trying his best to avoid me - he didn't sound happy when I called him on his new number ;)
I see he is online on CS quite a bit (and on other sites) so he is out there
clio better be ready for the airfield! :D - reminds me I need to bug clarkie for a major service on the valver too :|
hows the golf treating you?
Thought it sounded like the tensioner problem we had with our old VTS, just we were luckier than you LOL. Any idea why your valve spring broke? Hope you have more luck with the engine this time, you know where we are should you think we can help. Keep us posted on your progress, we've both got our fingers crossed for you
The idea of stripping down a engine fills me with fear, fair play to you sir you really seem to know what you are doing.
Am going to have to rebuild my mini gearbox soon, not looking forward to it to be honest.
Cracking looking project!
rather rebuild an f4r to tell you the truth :rasp:
have fun with the flywheel
Most of the bolts are going to be rustier than a really really rusty thing! When ticking over in neutral you can heard something in the gearbox clicking and spinning away. Gunna have to open her up and see what i find, it's a straight cut drop gearbox so parts are gunna be hard to come by i think!
it's all a front! :D
I just bug everyone in the mechanical section :D :rasp:
the F4R seems really nice to work on tbh (and all my bolts are new, so that helps) - a lot easier than the F7P!!
only thing that's got me worried really is the timing :S
Had to help my mate with the timing on his MK1 Golf was ok but it took a while to get it spot on before starting her up again. Was a slight case of the blind leading the blind!
Glad you're making prgress fella! Putting the valve in and building everything back up is the easy part now. You've found the problem so *hopefully* it'll be ok over the rest of the engine! Good luck dude....
I only got 115psi on the other cylinders... dont know if this is a gauge problem, timing problem or if the valves havent been lapped (swapped around maybe?)
so I think I'll lap them all
little update :D
dismantled the head:
re-lapped all the valves whilst i was there and replaced the bent one
great fun ;)
cleaned up the BE:
completed head:
some things arrive:
my ghetto angle gauge (worked a treat!!)
the inlet camshaft dephaser thing turned out to be broken :(
new one ordered from renault, should be in tomorrow
soaking the hydraulic lifter thingys in diesel:
head on:
cams in:
cam cover tidied up:
fitted:
oil breather fitted:
and inlet on:
as you can see the cam pulleys arent on... thats tomorrows job... hopefully wont take too long to fit and time up the cambelt (tools are arriving tomorrow too, hopefully)
and then... dare I say it.. I can drive the damn thing!!
Engine is all together and timed up now
making good compression too (165-185) so happy with that! :)
just gotta figure out my wiring and see where my spark/fuel has gone! :(
Well done mate! Top work!
Satisfying doing it yourself isn't it?
Stoked for you mate, really am!
bit of a late update...
beautiful! :D :D :D :D
love how the mk2 starts so quickly!
mk1s took a bit more time :? (ignore the f****ed box)
until it came to giving it some beans :(
1st and 2nd... doesnt feel quick :(
bottom end still fooked.. great
so I ignored the engine for a while and tidied up my wiring a bit:
all sits neatly in the relaybox! :)
thought i'd clean her for once.. not done that since november and she was looking a little sorry for herself :(
then it was a nice day, so out with the engine.. again.. (many thanks to Justin and his mate for the crane! :D)
timed it at less than 1hr 30 to remove :cool:
sump off:
think I'm going to replace all the, frankly rediculous E8 head bolts with some nice 10mm head bolts!
got scoring:
some crappy night time shots (taken for Fred at 2:30am as he was bored and wanted to look/tell me how s**t my engine is :D)
mmmm spun bearing. great.
some sort of crank washer: *shrug*
the crank:
back to square 1:
atleast this way, i'll have built the entire engine by the book, so should know its condition and it should proove to be reliable!
the crank was shipped off to stan @ APD
he has since confirmed that Dan has not carried out the work he said he has (what, did he think i wasnt gonna notice??!?) but stan said the crank should be salvagable and I'm hoping to have it back in a few days...
then I'll just need to rebuild the engine and drop it back in... again and i'll be running!
not long till FCS! :o
Your right mate, Doesent seem as fast as it should be. Gutted for ya that it's a dodgy engine. It's nearly always a gamble buying engines.
Nice project.
I still have a massive blow on the exhaust were the manifold meets the downpipe, maybe that is sapping power...
What a total r****d the guy who built that engine is!
Mickey mouse could do a better job after a lunch time session down his local.
Your doing a great job Matt keep it up, the skills you are learnig will stay with you.
Don't think Danlp6 has ever seen the inside of an engine before :rasp:
cheers burp! :)
just can't wait to get it back up and running... i hope its fast :(
Has been a total shitter with all the extra work but at least your getting there now. I wouldn't decide on speed until you've got it all 100% a blow at the manifold isn't going to help it at all i'd say thats sapping some through lack of back pressure.
Looking good now anyway, can't wait to see the finished article if it makes it to FCS.
Like Burp said, anything you learn will be useful in the future and although it probably doesn't seem like it at the moment but it'll be more than wortrh it when it's finished lad. Chin up!
dont worry matteh you wont be disapointed theyrocket, put alot of big boys to shame. i heard dan ran a dizzy cap on his with megane stuff management dont know how true it is seen the thing on ebay looks dogish under the bonnet. keep it up tho you wont regret it. ps its sid_taylor from valver forum lol to tight to get my own log in cheers nick ;)
