'92 172, Lotus Elise
yeh geesus
the project is starting to get to me now
got the deadline looming and it still needs so many more bits to get it running
Reckon I still need:
172 downpipe - hopefully getting this tomorrow (and hopefully it'll include the lambdas!! but knowing how much i seem to have been stitched up on parts, it wont
idle control valve
crank position sensor (bought, but not sure when it will arrive)
vacuum tube for fuel rail
bracket made up to support the mk1 fuel rail
coolant temp sensor!! (why is this missing?!)
bit of pipe for one of the breathers (I think)
roll pin for the driveshaft (gave my last one away, I'm too kind
2x adapters for the heater matrix (after the pipes were chopped, they're too small)
then I need to wire up the mk1 fan and get a fuel pump relay (it works atm, but on a constant live only)
I need to get my alternator charge light to work too
then things like guages etc would be nice
I need to find out why my aux belt is jumping 1 tooth towards the engine too
and ofcourse I need to see if this engine will actually work (or else Dan if you're reading this, I know where you live!!)
idle control valve
