Looking stunning, we love seeing other peoples projects and this is really interesting! Silly question, is that our old front subframe being put to dam good use?
You have mentioned that you have the rear axle out. Make sure you weld some steel on to where the shocker bolts on, takes ten mins and will save you having to pull out of a rally. Also we made the front subframe stronger by welding 10mm box section down each side where the bottom wishbone fastens on, it meant drilling the spot welds out of the brackets, and then re weld them back on to the box but. I,m sure it has helped by making the car 20mm wider track. and the sadev drive shafts have handled it fine. Mined my shafts are from a 172 cup car where yours may be diff with being from a 16v. What front hubs are you using? as the 172 ones are very heavy I would be tempted to stick with 16v ones to save wait.
Looks good :lolup:
how did you get the old ones out? did you have a press?
i broke two vices LOL
making good progress!
are you going to compete with this car?
also what make are the coilovers?
what you doing with the mk1 you took the engine out of
will have to decide what to do when we see how much is left over after building this one.
Probably either sell it as a rolling shell or put an engine in it as a track car.
It's a pretty tidy shell, started life at Mark Fish's i think
^or look at the light lol u dont ant argon eyehow are you going to strengthen the front subframe (ie welding the galzinised steel)
Aslong as you dont breathe the fumes its not really a problem is it?
bodge it up use sockets and lump hammers lolhow did you get the old ones out? did you have a press?
Yeah used a press. Still not straightforward though as you needed to bodge up something to push the old ones out from the inside edge
you got anymore pics of it mate?is it a normal shell or a motorsport shell?
I can get some more pics no problem.
It's an ex clio cup shell from Mark Fish i think. Can dig out some paperwork probably
This is one great project.
I would love to do a bare shell Clio build. Built two kit cars and reshelled a Ford Puma before but dont have the space/garage anymore.
Are u having fixed/non-opening windows?
