T. Turbo is back
Update.
Taxed the Trophy at start of month as planned on taking it to Oulton Park for Autos De France.
Best get some miles on it as only been for mot this year and its a long trip.
Done 20 mile trip to see my mate and mcdonalds (well im getting fat again now diets over :LOL:)
No issues good to go. Sat in garage until last Friday. Out early doors 7 am to clean before temp got up.
Fuelled up and ready for journey.
Typically mad hot day around 29-30degrees which doesnt bother the engine as it runs cool in the low 80deg coolant range on the move. Driver proper overheating however with no ac!!
165 miles done to the airbnb. Big posh digs.
Up early doors to get to Oulton.
No more pics of it as i was too busy catching up with everyone. Travelled back home after the show, pissed down late afternoon so it needs cleaning again. Apart from that all good no issues to report. Had boost wound up to 14psi on way back and its mega. Squats and goes on 4th gear roll!
Worked out real time mpg and its averaged 35mpg. Thats with giving it some on the way back and stuck in loads of traffic on the way there. The bosch 980cc injectors are great with good mapping from Chris @ Efi.
Will be time to fit new clutch soon. Over and out for now!
Updates.
Sometimes i forget ive got this as it barely moves out of the garage. Took it off the road last September and its not moved from its spot since.
Connected up battery, and primed oil system as its been laid up for ages. Unplugged coilpacks and injectors and cranked on starter - oil pressure flew up on the gauge straight away. Connected everything up and started instantly on the 9 month old fuel and ran like it was used yesterday, no rust on the brakes or nothing.
Backed it out of garage and ran it up to temp.
Cleaned the dust off ready for maiden voyage to mot station tomorrow.
Really need to pull my finger out and get the twin plate clutch in and back for high boost map this year.
Thanks for reading!!
Well nothing happened to T trophy last year apart from 8 mile round trip for mot. It needs using this year and its time to sort out the last few issues.
Ive booked a few days off work before easter to fit the twin plate clutch, new gear cables etc. All the other service items ready for a light recomission for some use this summer.
Made a small start on it today. The optima red top battery had seen better days and it cranked slow last time it was started so it had to go. Ordered a new one and fitted it today.
Small steps eh.
Update.
Done 20 mile trip to see my mate and mcdonalds (well im getting fat again now diets over :LOL:)View attachment 1652083View attachment 1652084
View attachment 1652085View attachment 1652086View attachment 1652087View attachment 1652093View attachment 1652088
Fuelled up and ready for journey.View attachment 1652089Typically mad hot day around 29-30degrees which doesnt bother the engine as it runs cool in the low 80deg coolant range on the move. Driver proper overheating however with no ac!!
165 miles done to the airbnb. Big posh digs.View attachment 1652091
Up early doors to get to Oulton.View attachment 1652092
Great stuff! Can I ask what is the boot storage/organiser part/model that you use? Thanks!
God I love this car.
Does the pump in the boot annoy you?
Drives me insane, i need to do a soundproofed cover. Its not as bad as the 044 in the extra though, that is pure tinitus :LOL:
This aint no volvo so i have to run one :LOL: pistons send me a love letter under half a tank
Storage tray is oem renault. No idea on part number sorry, very hard to find now.
Storage tray is oem renault. No idea on part number sorry, very hard to find now........I got through 2 pumps in the boot, supplied by a well known tuner,, you needed earplugs because of the noise, turns out they were cheap fakes. I now run a silent Sytech, sheer bliss.
Solid 4 hours done today.
Engine and box dropped straight down and gearbox off.
No oil leaks suprisingly
Ttv smf with twin organic plate fitted using a cut off ndo spline to line up both plates.
Flywheel lock in place whilst torquing all bolts.
New luk concentric slave fitted.
New bushes fitted to gear selector as it was a bit tight. The new bushes were even tighter than the ones i removed so sent the 10.5mm reamer through. All good now.
Back in the hole.
Bled the clutch up to check it was all working as intended before refitting more parts. I pre filled the concentric slave before fitting to save lots of hassle when bleeding as these mk2 meg setups can be a pig to do. This worked excellent and had a good pedal straight away with minimal hassle. The clutch feels much better than the old helix, its heavier than stock but not knee breaker.
Also flushed all the brake fluid for fresh rbf600 whilst there, as well overdue.
Back on it tomorrow.
Another 4 hours done today.
As everybody whos owned a megane knows the gearchange on the ndo gearbox is not great at the best of times, and this was pretty s**t by my standards, vague and did not self centre. Had to be careful changing gear fast as it was all over the place. This was a ongoing issue when Haswell owned it and had carried over even with parts changed. It needed to be resolved to make the car more enjoyable to drive.
As per last post to resolve this, i renewed and reamed the selector bush and purchased a new set of oem r26 gear cables to get it as best as i could.
Heatshields off and exhaust dropped, centre console out and shifter out. I noted with cables removed the shifter was also quite stiff so added fresh grease.
New cables. Old ones were not too bad but a bit bent which could be causing the issues.
Fitted.
Got them fitted up and the adjuster set for side to side setting. On testing in the car i was dissapointed to see that it was not much better. Main issue was no resistance/spring when moving across the gate to 5-6 gear making it crap.
This would not do, when moving selector by hand in the engine bay you could see it did not spring up great so decided to have a look at what was going on. I supported the gearbox and took the gearbox mount off so i could remove the selector.
Upon removal i noted this was a ph1 selector with single spring only. Renault changed the design on ph2 so dual spring, i guess to resolve this issue.
Pic off google showing ph1 on left and ph2 on right.
Luckily i have a big stock of megane parts including a few ndo gearboxes so pulled one out and swapped the alloy quickshift over. Fitted the selector, and noted shifter now self centres fine and gears 1-6 are much better/positive. At this point i select reverse and it barely goes in. Ph2 selector must be slightly different and it hits the gearbox mount carrier.
Reverse/selector interface.
This was a simple fix. Took carrier off and die grinded adequate clearance.
Sorted. Reverse in with a positive clunk now.
Couple of hours work but overall, good improvement. Its still an ndo so not fantastic but well acceptable, but if im not happy with this on the street ill stick a zpo shifter in as im not investing any more time in the stock megane setup.
R26 gearknob fits well with the interior.
With that done, got starter motor on and wired, egt sensors reconnected, wiring reconnected and fuel system plumbed back in. Small jobs taking ages as all bits fit in one place.
Egt per cyl.
Coming together.
Still plenty to do. No rush though.
Fantastic build, can’t say I’ve ever seen a 6 speed in a Clio before. Is it an entire Megane swap?
Was t.trophy the previous owner/builder or did you just change username?
Cheers mate. Its megane based engine and box (250 block/197 head).
T.trophy was the username of the previous owner (Haswell). He done the legwork on the meg conversion around 2012 iirc so probably one of the first 6 speed conversions.
I got it in 2020 in a million pieces, no wiring etc. I had to semi rebuild it in Haswell's garage to get it rolling as he said take it as it is or dont bother :LOL:
This is a pic after i had started bolting parts on to move it.
After that spent a couple of years getting it back together and road legal.
Updates.
Another 5 hours today, the small bits take ages to bolt on.
Turbo and wastegates refitted and exhaust which is a royal pain in the arse to do even though its on vbands as it goes above the subframe instead of under. Routed heater hoses, oil lines to turbo.
It gets busy once the turbo is back on.
With this done i moved onto refitting the subframe. It was running a stock 182 looped steering rack which i didnt really like, as it had a dull spot in the middle with the torsion bar on the hpas rack. Also hate the crap bushes that hold the rack in place, had powerflex black fitted but prefer solid mounted steering rack.
Had 2x options in stock. Modded Twingo Rs rack and 1.5dci. I stuck the dci rack on as i know they work and it was a simple plug and play, changing the tie rods to the 182 ones.
Give the subframe a clean up whilst off. Its all powdercoated black and comes up well considering it was done years ago.
Dci rack.
The subframe has a few mods done. It has been stitch welded on the joints and reinforcing plates fitted to the tca mounts, pms plates on the track control arms etc. Haswell said it made a fair difference at 440hp/400ft/lb.
With that done i got it back on the car. Well i had it on and off twice as the new gear cables were fouling the arb so had to reroute them which was a right ballache but have achieved a decent route now.
With that done finally back on and bolts torqued. Refitted custom dogbone for ndo box and a few other bits and had to call it a day.
Its a ballache to work on and the last few bits are taking ages. Also noticed one of my roll correction spherical bearings is worn on n/s balljoint so need to get that changed.
Goal is to get it back together and in for mot in next 2 weeks if all goes well.
Updates.
Had a few hours on it this week. Progress pretty slow but moving.
N/s roll correction spherical bearing replaced due to a little bit of play.
Intercooler given a quick coat of vht. The intercooler is genuine garrett bar and plate core rated to 500hp. Works surprisingly well.
Back in one piece. Fresh millers 10/50 and coolant filled with type d.
No spilling here. The sealey filler is awesome.
Aqua blasted parts cleaned and protected with Acf50 and the rest has had a wipe down.
Still a couple of jobs to do before fire up, mainly refit passenger side driveshaft, fill with gear oil, refit the Roll correction lower bearing etc.
Also noted the N/S lower wishbone front powerflex purple bush outer casing was slightly bent as its the crap old type with the thin casing (torque - it breaks stuff!?). Haswell said he had issues with these in the the past and he had the casings spot welded and i noted this one one has broke loose from the wishbone. There is no play or nothing so most people would write this off as a non issue but whilst there i will sort it to save future spannering.
Luckily i have a mint set of reinforced/powdercoated 182 cup wishbones in stock with powerflex black bushes fitted so i can swap the full arms over and its done.
A few more pics that might be of interest.
The older purple powerflex bushes and damaged casing/spot welds broken.
New lower arms with newer style Powerflex black bushes that have a shoulder to stop movement/washers to keep them tight.
NDO gearbox in situ, knacker tight. The gap between subframe brace is not very big, engine and box more or less solid mounted on vibratechnics mounts and solid dogbone.
Ac delete on traffic alternator mount for subframe clearance. I planned on changing this for a clio mk3 rs cup racer ac delete but it barely fitted so has to stay as is. Current setup seems OK.
Hot side boost pipe to throttle body. Tight but does not touch rad. Its bumper and boost hose off to change oil filter.
Air temp sensor is a right carry on to access.
The joys of a megane engine and box rammed in the engine bay.
Sat update.
Started with changing the lower wishbones. Whipped them off and the powerflex bushes were in a lot worse condition than expected.
Fcuked
This beauty was not visible until removed as hidden behind the reinforcing plate on the subframe.
Pretty bad, the thin outer casing on the early powerflex not fit for purpose. Im suprised it did not pull all over on the road but suprisingly little play considering. Stuck the new arms on with the new style powerflex black bushes with thick outer casing, and the washers that keep them tight.
Problem solved.
With this done i cleaned the heavy brake dust off the wilwood calipers and reyland discs. Everything has had a lick of Acf50 for future protection.
Wilwood, ds1.11 and reyland 2 piece discs.
Next job was filling gear box up with fresh Elf NFX. First time ive used nfx and it doesnt smell of piss like nfj? Anyway with that done i got the laptop out and connected to the ecu to attempt fire up.
Ecumaster.
I unclipped the coil plugs and injector plugs, cranking the engine over until oil pressure registered on the gauge to prime the oil system. The pressure came up fast and the engine was cranking strong with the new optima redtop. Checked for any oil system leaks and fuel leaks, all good. Laptop was showing rpm and all other sensors were reading ok, it looked like it was good to go.
Reconnected injectors and coils and cranked it over. Did not attempt to fire. 2nd attempt cranked no fire. Ecu was priming the fuel pump, I then looked at the laptop and it had disconnected and would not reconnect. This was a bit of an oh s**t moment as i feared the software had gone corrupt on the ecu for some unknown reason. Had a quick look in the fusebox and reseated the ecu fuse/injection relay, reseated fuel pressure sensor plug, disconnected laptop. Give it another crank and fires straight up with no issues, laptop connects to ecu. Tested clutch, gears, all working fine. Clutch making the typical twin plate noise when depressed. Ran up to temp fully, thermostat opened and coolant levels settled.
That offbeat noise as manifold is not equal length.
I have an onboard logger and had a look through the logs on the non starts. I believe it was one of two things. 1 - a power issue on the injection relay as it was not seated fully when fusebox lid was removed, no rpm registered due to volts going too low when cranking. 2- fuel system had been drained with fuel lines off and fuel pressure did look a bit low initially as stuck at 1.63bar but this could be default readings due to bad connection on plug to sensor. I removed and reseated the plug for the fuel pressure sensor as id removed it when taking the fpr off.
Bit of a mystery but its started every time since. Seems to run absolutely normal, considering the fuel is from July 2023 according to receipt in the glove boxo_O
With that done next job was to build an extender loom for the knock sensor for mapping purposes. This has 2x knock sensors fitted, one for the ecu and another on the next hole along the block for the mapper to use with det cans. Unfortunately with the nortech plenum it is ridiculously hard to access either knock sensor unless bumper is removed, so to make life easier i made this extender loom that can stay fitted.
Knock sensor loom.
Knock sensor location, hard to access.
Tucks away under fuel rail, ready for fast connection of det cans.
With that done i refitted the bumper, arch liners and wheels on.
Almost done.
Geo looks a bit on the piss due to dci rack change and the rack needs the column re centering so equal lock to lock both sides as it is now slightly off.
Called it a day at 1pm as my lower back was killing me due to twisting and pulling something early on in the day. Ill sort the rack in the morning, torque hub nuts and wheel bolts and then its test drive. Prob get a can of fresh fuel first as its now on reserve.
Finished off last few jobs on the Trophy on Sunday morning and test driven a few laps of the block.
All went well, new clutch is quite snappy but a decent improvement over the old helix/less of a knee breaker. Gear change is improved too much better than last setup, shift feels quite positive compared to the old vague feel. The steering is also much better with the dci rack compared with the old looped 182 rack that had a deadspot due to the torsion bar. Geo is a bit on the piss at the moment but will get sorted asap.
Meta view on test drive.
Twin plate clutch is noisy when pressed as expected.
Had a bit of spare time today so give it a clean up to get the dust and crap off.
Bh autofoam.
Muck dripping off.
Contact wash, rinsed with filtered water and blow dried.
3 years since gtechniq ceramic coating and it still beads up class. Took 30 mins to do its super easy to clean.
Mot booked for tomorrow so if all goes well it should be road legal by the end of the week.
Sorry, but I’m going to say it. You may already have said it was on the list of jobs earlier on and I can’t remember but I would love you to upgrade that steering wheel. Really need it with this and then that cabin is spot on also.
Bloody love this Clio, your work, and sharing it. Legendary
