My ECU has it but it's pretty useless so I (also Tony and Jay) just use the launch control rev limit and that does the job perfectlyI think I could work out a way to have a pit limiter on a switch. It's not a feature, but I have an idea of how to adapt one of the outputs
Also it gives people poking there heads in the car walking through the pits\track days something to look at.
That looks beautiful Pete. I need a holiday like that right now.
Stunning pictures.
I can't see any cake anywhere. Looks nice Pete.
Looks perfect Holiday Pete! Last boat i went on was on the norfolk broads, not quite as classy!
pulled the head off the short lived hero engine. 8 bent valves......and a secret history revealed
looks like it's dropped a valve head and someone has fixed it, but left one piston that had a BIG dent in it. Would explain why it leaked so much from the rocker cover when it was in Adams ph1 anyway,
I would imagine the exhaust cam has a higher lift Pete.
Luck of the draw. I could have told you if more if the cams hadn't been removed before I got it back
How come only one side touched (exhaust side)?
Because only one valve went, its not that the cam timing has slipped, the mark is in slightly the wrong place, looks like like the valve stuck in the guide and the contact happened while it was a lot further open, hence the damage is towards the middle of the piston more rather than at the cutout like if the timing had just slipped slightly.
Another option is the valve fell in half and jammed there, but unless it stopped the engine dead (ie happened when the car wasnt in gear) then there would be mutliple marks in my experience.
On just one valve out of the 8? lol
I dont think you have thought that one through enough
The dropped valve an old issue, can see the exhaust valves have made nice shinny areas on the pistons...I did that.
So many racer build threads which are now race reports too lol. We need a clio racers section lol
