Hoofy
Chase Racing Clio
Pete. I'd really look at changing that camera position.... with the dark interior, the contrast is quite a lot and you can't see much of what's going on outside of the car. With our white interior, it's not a hell of a lot better tbh, but under most levels of light you can make the track out and see where the car is. If you move the camera to the top of the dash, you get a bit of a better appreciation of the speed too!
We're in the process of a bit of a refurb (update to be done soon) and I'm going to move the camera positions around. I'm gonna make a permanent one on top of the dash which will be the main shot and then scatter a couple of mounts around the car for alternative angles (ie driver, rear and pedals). The main shot will be with the GoPro and the little shots I'm going to get some of those little 20 quid micro cameras.
Also, wire in a usb plug and get an open case.... you'll never have to worry about battery life ever again! It's sooo much better. We're going to integrate a little usb socket thing in to our central dash panel which we'll pick off power for the camera and the data logger.
