i was ribbing back...........too dry?
Just a tad, but so long as theres no hard feelings bro :approve:
Spoke to Mark at length yesterday about the issue, and we could not come to any reasonable conclusion. It is certainly low on power, but maybe its our fault for not checking where it started off initially.
Even if the cam timing was off as standard, this would be rectified with the new cam installation. One thing mark did mention was that peak power started tailing off pretty early in the rpm range (circa 6200rpm he mentioned), but i have not seen the graph so i would not know apart from what has been relayed to myself.
I did offer him the opportunity for a leakdown and comp test, along with double checking the cam timing. I also offered him the option to try a wilder set of cams, if he felt this was the issue, with labour FOC.
Ideally I would like to get it on the rollers we use in this area which do our base runs on stock cars, so it would be a good place to start for comparison.
As i said on the day the temps were really getting up in the dyno room and the car was red hot after all the runs!
I think there is at least another 5hp+ in there.
It was a nice strong curve too, smooth torque from quite low down
The figures dont really mean too much if you are comparing to "my mate got 200hp" yes maybe but not on the same dyno. As you know DD are not ones for giving nice figures like some
Paul
Ok, a little proof in evidence to my lack of horsepower:
Tonight on my local circuit I took on a 182FF using a Viper induction kit with cold air feed, YozzaSport full system with deleted centre silencer, and YozzaSport de-cat (same as myself).
Both cars were neck and neck, no difference at all in accelerative terms.
This is HOW mine SHOULD go WITHOUT the addition of uprated cams and possibly the re-map.
Gutted considering the amount spent on this comparitively with mine.![]()
. Not pleased at all!
Will definately have a full check with Ben at Angelworks asap!
Mate, my 182 is a bit like yours, mine has put 140 hp whereas a total stock one made 141 that day. My car has inlets, remap and panel filter (mine should be up at least 5 hp me thinks). And other 182's are just as fast if not a tiny bit faster!!!
What could be the chance of a defective head? This would make flowing not spot on casuing loses, maybe a production variation that is affecting the car. Otherwise, I don't se why your car or mine are not performing as hard as others
To be honest mate, i'd seriously consider taking the risk and buying a new 182 engine from a breakers circa £350-400
Get your cams fitted and drop it in your shell....hope for almost 200
Sell old under performing engine on ebay for circa £350-400 and hopefully you'll be a happy chappy.
You will only be £200 out of pocket at a guess
I have very similar set up albeit on my 172 cup but with the 428' cams and oe cat and Ben uploaded the map there and then for me as i didnt see the point of paying more for a live map etc.
Results are soo much better then standard as for power trailing off at just over 6k no way hose these bad boys pull harder then a sex starved nun all the way to the limiter !
Yes i know this is more to do with the peaky nature of 428's but it pulls better from low down and is alot smoother then standard (apart from the nun part)
Sounds like something is a miss The Seer and you must be slightly gutted spending your hard earned and it not living up to your expectations !
No doubt Ben will do his best to id the problem.
Oh ! You could always sell yours and buy mine![]()
I'd heard the 428's didn't have more or less anything hence the reason I opted for 420's.
I'm suprised :S
2 weeks from now ,I'm gonna try the Piper cams on my 182 cup and hope being able to post the results then...
Current setup is a K&N panel,a Rossi cat(bought it from K-tec) inlet stage 1 from BenR and a reprogrammed ecu and car produced 186,1 hp at the crank and 22,1 kg of torgue.
Hope to see 190-193 bhp at the crank with those(and a good remmap as well)
The last thing would be a nice exhaust,but since I want a silenced one that would have some gains too cannot decide for which to go for...
I'm suprised :S
unless i just have a well rounded engine, who knows !
Hope you get to the bottom of this buddy
Yeah I've been reading the scorpion 192 - topic and I'll have it in my mind.Milltek would be also a solution and there are some others too.But first I'd like to finish the cam-issue.
The thing is that with a proper exhaust the car would be much better.Before some months I had a very nice backbox- hand made here in Athens from a well known Greek exhaust maker and it rocked !
190,9 hp at the dyno,car was better at entire rpm range,but had to take it off since it was really annoying and boomy.I'm 29 and getting old.
Sorry but what "tappy" means ?
