I got back from Italy at 3:30 this morning, since I have an MOT booked in for 9am tomorrow I've needed to finish off a few jobs. No pictures unfortunately as my camera is still on holiday.
First job was to assemble the 172 CV onto the williams shaft. That all went ok, and fitted onto the car without drama. With the hub nut loose I pushed and pulled the CV to check the plunge, it felt OK, so I bolted everything up and topped up the gearbox oil.
With the car on stands I started the engine and dropped it into gear, this produced a horrible cyclic rubbing noise. My first though was that I'd dropped a clanger and that the driveshafts were rubbing on something. A quick check showed nothing obvious, so I turned the wheel by hand, listening and looking for anything odd. The inner end of the Williams driveshaft is moving eccentrically, the joint feels OK, so I think there's a reasonable possibility that the shaft is bent
. I didn't have time to strip everything down to be certain, and it'll be OK for getting an MOT.
I continued bolting the suspension together, and dropped it onto the floor. Moment of truth, I started it up and drove backwards and forwards on the drive. Tyrapped a few wires etc out of the way, fitted the missing headlight, checked it, wired the fan, and ran the engine to get it fully hot with the fan switching in and out.
I think the rideheight might need a tweek, the front looks too low to me (the suspension kit is for the 1.2L engine, so it's probably just the extra engine weight pulling it down) The rear looks a bit high, but I'm going to drive it to see how twitchy it feels, due to the lack of droop at the rear lowering will make it more stable.
I considered it washing it, but my one bucket technique requires me to have a bucket and sponge. It's so long since I've used either that I can't find them and have probably used the bucket for storing parts or draining oil...
