You should get all the bolts you need with the spacers so no need to cut them ones down, or have I missed something?
Oh I'm with you now, do they still bottom out with 20mm spacers then? I thought it was 15mm's and under.
Was busy playing GTA hence not replying to you buddy!
The noises it makes are extreamly weird. I'd expect some noise however due to the dogbone, but wasn't the squeak there before?
I also now wonder if the manifold is catching the subframe just slighty... Can move the drivers side engine mount forwards to test that though. Had forgotten about that.
Id say it could be the joint between the exhaust manifold and the cat, its held with bolts but is only tension with springs.
No worries buddy. Yeah the noise was doing it slightly before but not as bad, the same with the movement. It's gotten worse over the last few weeks, but luckily I've been using Emily's car. I drove it today into Harlow and it was doing it then![]()
I shall have a look mate when I jack the car up next. Unfortunately the weather is sh*tIs it common for them to go then and to make engine movement? It also knocks when on/off the throttle too :S
Thanks TomEmily thinks its sad that I take pics of everything but its good to record it all, for my benifit and for future buyers.
I was an itch that needed scratching tbh Kyle. I loved the BG but keeping a black car clean was a nightmareI do love the Ph1 though, plus there was only 90 something of them done in iceberg on the Ph1's so its nice to have a fairly rare colour. Just gotta see what power it makes now
Haha I no the feeling mate my BG was a nightmare to keep clean lol. Im looking forward to the RR day![]()
When and where is the rolling road day? I wanna come![]()
Coming along nicely Mark
I need to have a listen to your stealth exhaust at the RR day![]()
nice updates mark. the whiteline was new and probably only covered circa 2000 miles if that. i will be interested to see what power it makes too. felt a strong one to me.
nice progress chap![]()
which parcels that chap?
yeah will be good to see how it compares to other clios on the rollers, and see if those matched inlets have helped it breathe a bit better.
That's ridiculous mate, can't believe that but at least you got a full refund.
Oh and il take the spacers if you no likely![]()
That is proper s**t mate, only good thing is that you got the 25mm spacers for free.
Tbh Mark you dont need the new bolts that they supply as the ones on the car are plenty long enough.
