Jekyll
		Thought I'd stick my nose in here after the chat in the ph1 appreciation thread.
The car looks very nice and clean mate, good effort so far and I bet it stops nicely too. Ph1's are win :wink:.
Haha, i didnt think you'd stay out for long. Thanks for the comment mate :smile: It does stop ok but im only on a EBC road pad so next year i will get a better pad. Probably DS2500 as i liked them in my old Wilwood kit or maybe try the Mintex1144's. I believe the pads are actually a Volvo 240 pad that fit in my Hi-Spec's.
Decided to do a little winter overhaul on the Ph1 before it starts getting too cold. Bought a few things that needed replacing:
New Elf evo oil
Oil filter and washer
Fuel filter
New wiper blades
New headlight bulbs
Screen wash
Coolant change to Type D
Boot panel clips
I decided i wanted to remove the 5k HID's as they flicker when first lit up and and i have to change the pins everytime i get new bulbs for them so after a few read ups i got the Osram Nightbreakers Unlimited. The colour is more yellow than the blue 5k's but changing a bulb will be easier and there's less clutter in the bay. Think of all that weight saving!
HID's on the left, Nightbreakers on the right.
Next up was a idea that i got from @dmallett that he did on one of he's many cars. I cant even remember which one!
Basically my jacking sill were non existent. It really bugged me the way the was all bent in so i decided to cut up some box section at work and weld them on for strength. I sandblasted them as i wanted to paint them before i undeseal them.
I bent them as straight as i could then a i got a chap at work to weld them on the car.
All welded.
Ive given them a coat of silver Hammerite that i had for now but i'll give them another coat before i underseal the car. Should be stronger now. Thanks Charlie :smile:
Next up was to change the coolant which @AlexW gave me a hand with.
Old.
New.
Changed the wiper blades.
Old.
New.
I removed the taxdisc holder too. I was attending the EoE so i gave the car a quick wash. Checked the torque on the spacers bolts which were fine and gave the coilovers and brakes a clean. They both still look like new :smile:
When me and Alex had the bonnet open we noticed that the dephaser pulley sounded a little bit dodgy. I was planning on getting the belts done by him next year but i will bring this forward now. We are aiming to do it hopefully this month. I checked my paperwork on he car today and the cambelt was last done in 2010 and the aux belt in 2012. My gearbox crunches in 3rd on quick changes so while the belts are being done it will be perfect timing to get the gearbox rebuilt by agency. I didnt do the oil change so we will do it when the belts get done. Here's a list of parts that will be getting done:
Cambelt
Depahser
Aux belt
Cam seals
Crank bolt
Water pump
Coolant
Clutch
Gearbox oil
PAS oil
Rack bushes
Spark plugs
While the box and block are out im going to remove all covers etc and get them painted and paint the box and block when it comes back from the refurb. Alex thinks the timings out so it should be running like a dream in a few weeks time :smile:
