Thanks for the good feedback ..... a bit of tinkering this afternoon as the sun was shining. Let me try to answer some of the questions from above:
- If I was to score the Toyo R888R I would give them a 7 or an 8 out of 10.
- I like that they have a pretty solid sidewall which helps reduce roll in hard cornering;
- I don't think they are particularly cheap or good value for money;
- They don't seem to react to change in tyre pressures (perhaps that's because the sidewall is pretty stiff?). To try to reduce understeer (in a hillclimb) I've run them at a range of pressures from 18 psi to 28 psi and couldn't tell the difference :-(
- Plenty available (some of the big national companies like Bathwick do them .... so includes 'free fitting, balancing and valves');
- They are ok in the wet - not good or brilliant but ok;
- They don't seem to wear very well - I have a fair bit of negative camber on the front and they seem to wear quite badly on the inside . I got through two front tyres in 3 hours at Llandow - but it was fun
- I used Toyo R888Rs because they are MSA list 1B approved for my class of motorsport ... my tyre of choice would be Kumho Ecsta V70a - available in 4 different compounds. They don't look sexy like you would expect competition tyres but they are damned good.
For 2017 and when this set of R888Rs wear out, I will try the Extreme VR2 (road legal - list 1b). Treadwear '80' so should be pretty soft and grippy -
Thanks ... you can't be far from Castle Hillclimb at Lostwithiel? Do call in and say 'hello' this summer.
@Brushwood69 will probably be there as well in his mega Audi TT.
Yes - I must change the gear lever / mechanism. As a temporary fix to stop my gloved hand slipping on the gear level I've put a knobbly cover over it.
Its a bit like one of them knobbly condoms - or so I've been told as I don't use them myself. In the pic above you can see how short the gear lever is :-(
I've just bought a new cam mount as well for the roll bar..... the mount from the Caterham didn't fit the bigger diameter tube of the Clio cage. Less than a fiver off E-Bay. It doesn't look very solid but at a fiver (post free) I though i'd give it a go.
If you look closely in the pic above you can see I've strengthened one of the spring loaded joints with a fillet of araldite.
