That's when the rb track project will start!
Looks great on track. Love it on the Williams wheels.
Oh FFS! It was a double one, typical that it deleted the one that I left!
I removed the slam panel cos it was redundant with the aerocatches, it really helps access to the engine bay as well. Sorry, I forgot to re-measure the garage but I shall.
Things have taken a bit of a turn for the worse with this, I was basically 3 jobs away from having it MOT ready (rear brake line, bleed brakes, fit harness) when it really didn't want to start yesterday. It was popping and banging whilst turning over and then when it did eventually fire it ran terribly. Was able to identify that it was cylinder 3 that was being lazy, with having the 182 on the drive it does make parts fault finding easy at least, was able to rule out injectors, leads and coil pack which left the plug or the engine itself.
Removed the plugs and noticed that cylinder 3 one was noticeably looser than the other 3, now I know that it blew plug 3 out when I didn't own it but a new plug went in fine. Figured it made sense to compression test it when its all apart anyway and got the following results, 1-4: 110, 150, 170, 175 which obviously isn't great. I've managed to source a known good engine and box (from the old track car!) so I'm going to get that but for the sake of £20 I've got nowt to lose so may as well fire a helicoil in this one and see if it takes.
Annoyingly this all happened just after I ordered genuine Renault rear brake lines! Went for them since they've got the flexi sections in them (182 ones anyway) so will probably outlast this car! Part numbers are 8200113855 and 8200113856 for anyone wondering. Not cheap for brake lines but I don't have a flaring tool atm so it probably works out about the same on this occasion!
Optional extra IIRCI'm not sure that having a 3rd gear counts as an upgrade
I wasn't sure about the DS1.11 at first
Good night John, camera was in the garage unfortunately! wasn't really enjoying the night other than battle with you, up until the last 15mins where were we felt good in the car! Then the manafold cracked!! Wondering if that was the power problem earlier........???
