Big_Steve_T
I wanna know what you blurred![]()
Especially the radio bit!![]()
All will be revealed... when we come to the full interior section
DrilldoI wanna know what you blurred![]()
Did you buy new window seals for this?
Fantastic.Thank you @cliocollins [emoji106][emoji106]
Yes I did buy new window seals for this car. I managed to get hold of one brand new seal off eBay, and then had to buy the other side from my local stealership..
Near/Passenger Side: 77 01 207 588
Off/Drivers Side: 77 01 207 589
Where you getting your paints mixed mate?Now the fuel filler neck is cleaned up, the fuel flap is the part that looks gritty...View attachment 1466530
Knowing I will be using a pair of M6 Flanged stainless bolts to hold it back onto the car, I don’t need the previous moulded-in bolt head securing pockets, so I carefully cut the buggers off with a junior hacksaw:
They came off really cleanly with a new blade:
To dress it up, I masked out the hinge area:
and painted it:
Let’s see how that turns out...?
Thanks for reading![]()
Paint mixing shopWhere you getting your paints mixed mate?
What is the trick if you don't mind sharing as I was wondering about that![]()
Just got some, cheers! I used to buy it from someone else on ebay but they stopped listing it.I bought a tin of pre-mixed paint from Paints4u off eBay and the colour match is terrific!!!
RENAULT J45 Car Paint Spray 400ml Body Shop Aerosol BLUE DYNAMO | eBay
Find many great new & used options and get the best deals for RENAULT J45 Car Paint Spray 400ml Body Shop Aerosol BLUE DYNAMO at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
Dare I ask how much these were? I’m sitting down..Thank you @cliocollins
Thanks fella. Glad I was sitting down!This gives you an idea.
7701207588
7701207589
But I didn't pay that, I've got a "good" relationship with my local Renault Dealership.
I'm sure the chaps at Renault Parts Direct will give you a better price.
Had a look at them before, they're more expensive when you add in shipping and also not open at the moment! Cheers thoughFor future reference autopaint st helens will do it for half the price, I've had artic & monaco colours off them both decent matches.
The best way I can describe it is with a crappy iPhone drawing below:
if the edge of the part you want to paint is the black part, and the right angle is the edge you are trying to mask. Typically you would mask the part to the edge with the masking tape (The red line).
However To feather the edge, if you put the masking tape on the part, but go past the edge you want to mask off, the paint will stick to that high edge of the masking tape, and not the edge of the part being painted, thus you feather the edge.
Ah I think I see what you mean looking at your action pictures with the tape as well.
To add to your awesome drawing, the spray direction is the blue arrow and because the tape does not end ON the paintwork you won't get the build up at the green dot (left picture) but it'll spread evenly like the small green dots (right picture).
...now to find some rattle cans that sort of match Petrol Blue!
Do you finish it with a clearcoat of some sort?
I got hold of a pair of OE Grey Insert Hella Headlights and I called on the support of my best man and detailing king Jez to see how good he can polish them up...
Wow @RustyMojo thats looks fabulous sir!!! Great inspiration to keep up the grind (literally) on mine!!
It’s amazing how crusty they get isn’t it!??
I like your axle stands!
Was there much rust underneath it?
Thanks, i usually use regular stands, but as I want the car higher in the air whilst I'm groping around underneath, I called the old blocks of wood into action. They're great!
Surprisingly no, behind the tank was fairly good. The worst areas where the fuel & brake line clip locations, and the rear "chassis rails" (not sure what to call them..)
Well that sounds like a right pain in the arse, the OE bushes are quite expensive too?
Sure it will be fine but if you end up having to change, the Whiteline ones are nice and good value!
