E36 3.0 ITB Race Build
Is 70deg coolant considered hot enough for the OEM ECU not to be richening it up a touch?
I wouldn't ask but I recently learned some OEM Ford stuff has like 3% extra fuel in right up to 80deg.
Maybe in stock form - most low temp thermostats for the 996/997 platform are 75C. I think OEM is 83C. The middle of the (highly inaccurate) gauge is 80C. Stock setup also use MAF sensor, I use MAP.
However it's not relevant in my case. I simply target a specific lambda on each bank in closed loop via WBO. Only fuel correction I use is warmup phase and if IAT goes through the roof
RustyMojo
Bon Jovi Officianado
For a basic start with the engine, I have:
- Millers 5w50
- 997 GT3 OIl Cooler
- Center/3rd Radiator
- Low Temperature Thermostat
- Mahle filter (spin on) with non-return valve (the original paper filter/housing does not have this).
- 997 Oil Return Pipes
- 2qt Deep Sump/Baffle (Takes around 10.5L now)
- Oil pressure sensor at the filter, and the head (furthest point).
- Oil temperature sensor at the filter, and in the sump (as per OEM).
- Stock new AOS, however proper pipework not the standard plastic crap.
- Non standard intake distributor (I use a 996/997), different link to the AOS.
At the moment I see no oil pressure issues, generally an average of 6.0-6.5 bar at the filter, 4.5-5.0 bar at the head. Temperatures remain stable around 75C coolant, 90-95C oil.
Other things I did as preventitive measures/things to consider:
- Removed the stock power steering, I use TRW pump up front. Not pumping fluid back and forth to the back.
- Swirl Pot - Under heavy braking at Croft I was getting fuel reserve light flicker on at half a tank. This dosent nessecarily mean I'd have a fuel pressure issue, but I fitted the parts from my E36 so I can forget about it long term.
- Lightweight flywheel (the DMF had done 85k)
- Got rid of the OEM Coilpacks
- Gripper LSD
That’s super interesting, thank you! Can I ask what deeper sump you purchased? There are loads of different options and wildly differing price points? Presuming you’re running proper track rubber as well? It’s reassuring to read this thread so thank you for sharing
I used a ROHLER kit, decent enough quality - it's not a difficult job, fine to do in-situ but it was easier with the engine out and upside down. Note the stock windage/baffle has its own 'trap' doors..
Yeah, tyres I run Nankang AR-1 in the dry, PS5 in damp/wet. Also consider this is on Nitrons, GT3 RS front ARB, Cayman R rear ARB, all black series bushes, cage, so considerably stiffer than most in regards to cornering forces
RustyMojo
Amazing cheers, I’d get my local specialist to fit it. I’m fed up of rolling around under this car. I fitted a Cayman R ARB recently and run Powerflex (purple) bushes elsewhere as well as semi solid engine mounts. Was planning on changing the front ARB at some point as mine is knackered and tiny. Just again mustering the energy to tackle knackered bolts and dropping the subframe.
Yeah. To be honest if none of that at the front has been touched before now, Its a huge job. This car has spent the past 10 years as a "weekend car", with enthusiast owners, however if its passed an MOT then nothing has been touched. The deeper I dug, the more I found. I always planned on taking it back to a shell anyway, and the coolant pipework had been previously done (main centers and link pipes), but everything on that front subframe was a "start from scratch" sort of job.
A front ARB swap (if you can find one, I had to buy new from Porsche) will turn into a lot more work, garage or otherwise. I wanted the GT3 RS as its 5 way adjustable from factory - I honestly don't understand why H&R/Eibach sell what they do - non adjustable front, what is that all about?!
I would say deeper sump at a minimum, and a good oil pressure gauge of some sort. Don't rely on the stock oil pressure sensor, if you see that come on... well it's already too late. At least with a gauge of some description, you can see how the pressure is as you build up pace and get an idea of what is going on 👍
RustyMojo
This is so so helpful thank you! It’s really made my day. Agree around the Eibach/HR ARB’s I looked at them and wondered why folk bought them. If you just want a thicker ARB you can look to 997 options as I see it and they can be found for less. GT3 would be overkill for my use which is fast road/road trip to ring and mild track duty. I’ll get onto the other bits and get the old girl fitted with a deeper sump and an oil pressure gauge. Thanks so much again.
Sorry, I started to reply then went out to fetch kid and posted without hitting refresh 🤦‍♂️
What other forum are you posting on Foxy? Would love to have read up of the rest of the project. PH?
At the moment, nowhere! When I get some time I'll start something (heading to Anglesey and Cadwell towards the back end of August). I'll update here when and wherever it may end up 👍
@Jamie86 @MarkCup @Matt Cup I can't reply in Marks thread, because cheapskate member, but I've done a few pairs of them now, both 5 speed and 6 speed. Dimensionally the cups are slightly different (on the CV end), but they use the same boot and shaft diameter, and it's a bit of work to strip/clean/assemble, but there was nothing wrong with the internals of the joints AT ALL. Terrible design, just like E36s really, however the Porsches (not just Cayman/Boxster) suffer with it badly in 996/997/981 era. I've had people ask me to sell them the file, but I've no interest, it's not rocket science. Just because someone on the internet says it's not servicable, dosen't mean it isnt......
Rob
I love that you’re still absolutely solving problems in the way you used to. ‘There must be a better solution than that’.
Awesome.
Awesome.
It's on a 10x higher level now in all honestly 😂 Im literally just waiting on some CNC stuff arriving from China for the Porsche.
I was going to do a thread, but I've spent the past few months since Oulton in November doing more major work to it and just not had the time. Everything is coming together now ready for this year. I'll make some time soon, as people do keep asking what I've been up to! But just concentrating on getting it 'right' before heading to Spa in a month at the moment 👌
Rob
Please do Jord, there’s LOADS of us that would love to read it. (When you get time)
Lots happened over winter, no original wiring left and it's pretty much at its 'lowest' weight now without getting stupid - around 1240kg.
Had a shakedown at Oulton on Saturday after all the changes...
It's much more fun having to work the little 2.7 hard, especially with the terribly long gearing they all seem to have.
Next stop, Spa in a few weeks. Then i'll make some time to write a thread up 👍
Rob
That looks like brilliant fun! As you say, the long gearing makes driving the 2.7 quite good fun, you really get to wring its neck. My mate that’s used to 4cyl turbos couldn’t believe the revvy-ness when he came out in mine last week.
I spent a while at the back end of last year getting/stripping VW/Audi transaxles (of the same gearbox code) in the hope 'the internet' was correct in the final drive/pinion being usable, but unfortunately nothing is compatible and the dimensions of the Porsche differentials are different to any of the VAG ones, even though the gearset and casings are the same. It does need to be shorter (by a long shot) and it would be quicker round a lap, but it just isn't possible if staying with these 012 boxes
Anything aftermarket (££££) for the gearing?
Not that I can find for the 5 speed. There used to be for the 6 speed, however was £2k+ for a ring and pinion - regardless, I wouldn't pay that anyway. They aren't worth the investment as can't handle the power of a 3.8/4.0 for example (not for track anyway).
My box is worth money 'as is' with the Gripper installed, for Caymans and Boxsters. I have a few ideas in mind, possibly retro-fitting a newer box (with better ratios) with an adaptor plate, which would also be suitable for a (newer) engine down the line, without the adaptor
