Restoring Little Bluey - my 182 FF ClioSport in Racing Blue
Mr Underhill
Well due a refresh, look at how scruffy that engine bag looks.. 😂
Mr Underhill
Spring, my arse. It started bloody raining on the one day I began working on my car. 😤
Still, I managed to get the bumper off - I hate doing this on my own - and the radiator, condenser, and dryer. The ECU is out, and I removed some inner liners to check for corrosion.
Everything looks dandy, with only the odd bit of surface rust on some bolts, clips, and around where the slam panel secures. These are easy fixes. It’s all just very dusty, primarily from where I store it.
I’m quite relieved to see no oil on the sump guard—again, just dusty. The underneath is also still nice, dry, and rust-free.
I’m pretty pleased and relieved at the same time. It’s not a show car by any stretch, but it’s a solid, rust-free little car and should last a few more years yet.
Having a cuppa and waiting for the rain to do one.
Steering Colin
  172 Cup
Lovely well looked after car Jon!
You'll have those airbox torx screws back to new in no time.
Are you going back to a black for the ECU bracket / airbox bracket?
Do you have a replacement lower fuse box housing - that clip always breaks 😢
Easter Monday = It was always gonna rain...lol
Mr Underhill
Thanks Colin.
Yeah those are soaking in some DEOX-C right now and will be getting the Gun Oil treatment..again!
Yes, both repainted Black.
I snapped it a few months back and was proper peeved off. I’ve broken 3 now in 7 years. It’s not bothering me too much at the moment, but if you come across any good ones, please let me know.
Typical!
Mr Underhill
The rain hasn’t stopped, so I did some work in the garage. I bought a load of new bolts and clips to attach the new condenser to the new radiator and then to the fan shroud. As usual, the missus has been messing about in there and thrown her stuff everywhere, so I couldn’t find them.
Being an impatient old git, I reused the old ones—thank God I’d soaked them in Deox-C three years ago, so they didn’t put up a fight.
Old condenser, dryer and Radiator
New condenser, dryer, radiator and seal kit.
A bit of a story behind the condenser and seal kit, as I’d bought them many years ago for my old Black Gold 182. When I sold it on here, I gave them away with the car for free, then ended up buying them back like the bloody idiot I am. 🤣
Anyway, that’s as far as I got. Going to have a cuppa, hot bath and another go tomorrow. Thank you for reading.
Brigsy
  T.Turbo
Looks spot on John, its held out great considering a few years since the refresh.
Keep an eye on coolant temps with new rad on as the core is a different design to oem. I have tried similar new style core on my meg and it was getting hot as fcuk so changed back to used oem and its been fine since.
Mr Underhill
I fitted one of these on my Black Gold track car and it was spot on Jon. It looks identical but I’ll keep an eye on it.
Mr Underhill
Early start to put it all back together.
No dramas - everything went according to plan. I spent most of the time going over everything and cleaning up as I went.
New ECU bracket installed—thanks, @Colin-S . The old one had caused a few scratch marks due to some movement, so I touched those up.
I got the airbox and screws back to black again.
I took my time refilling and bleeding the system. I let it run hot, and the thermostat is all good, with the fans kicking in.
I had a good look at the steering knuckles and hubs, and they’re still in amazing condition, so I’ve decided to leave them alone. The geometry is set up perfectly on this car; it’s so smooth and straight. With the MOT just a few weeks away, the last thing I want to do is mess around trying to find a competent garage to set it up properly again. As the old saying goes, “If it ain’t broke, don’t fix it.”
I have a few small jobs to do and it needs a proper clean, then I’ll give it a good run out tomorrow. Thank you for reading.
Mr Underhill
Managed to get booked into Kwik Fit this morning to sort the Aircon - cheers @Brigsy
The chap who did the work also supplied my tyres and is an all-round good egg and a proper petrol-head. I also discovered, he’s at the Nurburgring at the same time as I am, so that should be cool.
Took about an hour and nice to have cool air again ❄️
I also picked up this really mint condition Stereo from @avstar1 last year.
My other stereo is fine, but when I cleaned the sticky goo off, I damaged the stickers.
The small details always bugged me, and they’re what matter most.
The last job was to attach some rather cool top mount covers. A chap I follow on Instagram has a set on his Racing Blue 182, and they look just the trick. They’ll also prevent the top nut from rusting or collecting dirt.
For anybody interested in a set, I got them from Diamond Performance
Overall, it’s been a pretty productive few days off, and the car is finally getting to the condition I wanted. Just a few missing grommets now, but that’s part of the fun of trying to get it back to factory. Thank you for reading.
Mr Underhill
That stereo looks mint!
I've had a think about buying those top mount covers a few times - do they just push on? no chance they could come off?
A lot of jobs ticked off the list - well done.
There’s a few bits of sticky tape inside so I imagine it would become unsticky if you were removing them regularly. But no, once you push them in, they’re solid. Really nice idea and design.
Mr Underhill
My last day off, so I thought I’d tackle the exterior black plastics.
I bought some C4 Permanent Trim Restorer after reading good reviews. While ACF-50 works well, its effects aren’t long-lasting.
For £22, I expected 5 litres, so I was a bit miffed when this arrived. 🤣 There’s one born every minute, I guess.
Being me, I decided to strip certain parts off the car and mask around the rest. Not sure if it’s necessary, but there you go. I gave all the plastics a good wipe-down with Bilt Hamber Surfex HD.
Before jumping in, I remembered I’d bought new connectors, particularly the two for the washer motors. While the scuttle panel was off, it seemed like a good time to replace them.
Continued….
Mr Underhill
The old connectors have a bit of corrosion, understandable giving their position next to a washer bottle.
The new ones.
I dug my old block of wood out to help me solder. As I’m on my own, I solder each wire and then tape them down to avoid movement.
It’s a while since I soldered, so it’s a bit chicken s**t, but solid.
I then finished them off with heat wraps and some conduit.
Job done.
Now back to the cleaning.
Mr Underhill
It didn’t take long to apply, and I used nearly the entire bottle.
I wouldn’t say I was bowled over, as the results are similar to ACF-50. However, if it lasts as long as the reviews claim, it’ll save me a lot of hassle.
Just need to give the rest of the car a wax polish.
Steering Colin
  172 Cup
I've used C4 and C5 on my alloys and plastic parts - you really only need a few drops but it's very hard to get just get a few drops from the bottle. It works better on some plastics than others but they have come up a treat.
I've also used it on my headlights after using the 3m headlight restoring kit - and it usually protects them for just under 2 years before they start going cloudy / yellow.
Cars looking amazing now Jon- only thing left to do is enjoy it :)
Mr Underhill
I’ve never really been one for detailing or cleaning products. I like to keep my cars smelling nice and vacuumed, and that’s pretty much it. I rarely wash them during the winter; instead, I leave them filthy until spring. I seem to prefer rolling around underneath them. I’m going to drive them more over the summer because I’ve found that short journeys or storing them away doesn’t do them any good.
Brigsy
  T.Turbo
Looks spot on mate. C5 is decent stuff and usually lasts.
If it doesnt last too long try the ceracote trim wipes. They are awesome, ive done my kangoo with them and the finish/durability is next level.
Mr Underhill
Yeah, wipes seem more practical Jon. I found it all a bit pretentious to be honest 🤣 Little bottle, gloves and those tiny little applicators. Like rocking up to a restaurant expecting a Sunday dinner and you end up with Nouvelle Cuisine. I’ll check those out.
Brigsy
  T.Turbo
Its a right carry on to be fair. Clean and prep and then get it on fast and panic if applying outside if it clouds over as rain ruins it before it goes off :LOL:
The wipes need the same prep - apc scrub etc but the finish is fully cured in an hr. I done my front composite door on my house due to fading and it still looks amazing a few months on.
Steering Colin
  172 Cup
Headlight covers used as top mount covers - I didn't know this was a thing.
Mr Underhill
Biggish service on the car today.
I was going to get work to do it, but then I remember how they hate working on these old cars. So, I’ll just let them do an oil service when it’s due later in the year.
It’s been three years and 6,000 miles since the spark plugs were changed, so I figured I might as well replace those and the ignition coils and plug leads while the manifold is off.
Reached out to @FrogJam Motorsport who sorted me with new ignition coils. Still loving the Freddo and pot of jam - nice touch!
I had some OEM oil filters and sump washers on hand, so I ordered oil to go with new upper manifold gaskets and NGK spark plugs, sourced directly - not Amazon.
I’d also picked up a cheap 5Nm - 25Nm torque wrench a while back, perfect for these kind of jobs.
I also picked up a genuine Renault expansion tank cap, as the previous one was leaking. I bought that one from Renault too, but it’s never sealed properly.
Cap on.
With that done, I took a close look at the back and top of the cylinder head, as well as the brake fluid reservoir. Some might recall my oil filler cap popping off and oil spilling everywhere.
I was expecting plenty of grime and dirt, but was surprised to find it relatively clean. I gave it a degrease and a coat of silver VHT paint to keep everything looking tidy.
Finally, with the new coil and plug leads on, I gave the throttle body and manifold a clean up. Then changed the oil.
Purrs like a kitten.
MOT due next, then I should be good to go for my trip to Germany 🇩🇪 🤞🏻
Klumpy Dumpy
😂 Germany, mate? You inviting me to the clique’s sacred pilgrimage or just taking the piss? 😜
Taking the piss mate, you're not allowed to mention a trip to the ring on this forum because people seem to get pissy
But then they're the first people to say "oh I don't actually want to come"🤦🏻‍♂️🤣
Louis
I Love Ed Sheeran
Now now
Mr Underhill
🤣 The drama hasn’t gone unnoticed 👀, and I didn’t for a moment think the clique would lower its drawbridge for a peasant like me! 🤣 Just a few lads from work, but it sounds like my car’s more likely to make it than yours. If the clique ever wants a race to Germany, it can be arranged! 🚙💨💥
Klumpy Dumpy
I just can't believe you haven't invited half the internet along mate, poor form that Jon🤣
Mr Underhill
It’s been a glorious start to the summer, and I was looking forward to so many things with this little car. Sadly, she’s coming off the road until I can address this oil issue.
If anybody has a decent, working 182 engine that I can switch over while I get this engine off for a refresh, please drop me a message.
Brigsy
  T.Turbo
Run it for summer and pull the engine in winter. No need to panic with it mate.
Mr Underhill
Lovely jubbly!
It's always nice to have a former Renault Master Technician checking over your cars as well.
On the engine front, I’ve been running some 10W-40 oil - cheers @NorthloopCup - and it’s definitely improved oil consumption to the point where it’s now negligible. It seems the valve stem oil seals in cylinders 4 and 2 are showing signs of degradation, potentially hardening from sitting around — these cars are getting old now.
Only 6,829 miles in the four years I’ve owned it, so it’s back on the road again and ready to clock up the miles. Happy days.
