Daily dci
Brigsy
  T.Turbo
Cheers @Une_Baguette thats a good help. I was just winging it the other night and disconnecting things on a whim. Didnt even consider throttle pedal! Did see fault change when rail sensor was unplugged so poss that.
Currently been dying from man flu for a couple of days so not looked at it yet. Rail sensor has turned up today so will have a look at it over the weekend.
Brigsy
  T.Turbo
Updates.
Blue dci is running again. Plugged in the new fuel rail pressure sensor which cleared the df127 and live data showed correct readings with engine off. Also ac pressure registers 3.5bar again now the sensor is receiving correct voltage.
Changing the rail sensor looked to be easy and i was expecting it to be a 10 min job. I managed to remove the old sensor in situ which was easy enough but could not get the new one to start in the threads and couldnt even get the old one to go back in. I ended up unding the diesel pipes and taking the fuel rail off to do on the bench. No pics but rust had wicked up the threads in the fuel rail causing the first few threads to gall slightly on removal. I was quite suprised to see this as it had came out quite easy. The thread is not standard, looks like an thread or similar and you cant get any swarf in so retapping is a no go really. With this in mind i got the old sensor and got it started in the thread, working it forward and backwards which recut the leading threads letting the sensor wind in easy. Had to be careful keeping everything very clean as these delphi setups s**t themselves at any dirt ingress.
New sensor went straight in and refitted the rail/fuel lines. After an extended crank of the starter to prime the system it fired up sounding absolutely normal.
Logged rail pressure on a couple of starts and all good. Ive noticed with engine off, ign on the new rail sensor reads 0bar where the old sensor would linger between 12-30 bar for whatever reason (doubt this was correct as never any residual pressure in system) so might have been on its way for a while.
Anyway test drive went fine, goes normal no issues. Ive started it up a load of times and it runs much better, no low idle or surging on idle so do wonder if the rail sensor was contributing to all of this with iffy readings as never managed to log the fault with it been intermittent.
Orange clio has a full tank of diesel in so will be using that up before the blue one is back in daily use.
Thanks for reading!!
Brigsy
  T.Turbo
Updates.
Blue clio back in daily use. Its been running great, no starting issues and none of the low idle carry on, 100% confident that its sorted.
A few posts back i touched upon spinning the egr to essentially blank it off whilst eliminating things causing low idle. You can only get one bolt in the top and pikey one bolt to the underside of the egr when its 180deg out. I thought this would be ok/sealed but after looking oil had started to spray out of the top and bottom, not loads but not great either. This also highlighted the turbo was getting pretty tired and blowing oil out of the compressor side seal, which is not ideal on a diesel, if it suddenly got worse it could be a runaway situation. Id noted oil when cleaning egr and it looked like it was getting worse so time to change the turbo.
Experimental spaced out egr solenoid which did not work and put it into limp.
I got the turbo for free off a breaker kangoo when i first got the car and its done 90k in my use so its done well. I went through the turbo collection in the lockup and dug outa dci80 yellow plate turbo with no play in the shaft/no sign of oil on inlet or exhaust so deemed good enough. Decent weather and a spare few hours so set about changing it yesterday.
Usual position
Spoolie boi missing.
Old turbo off and new one on in 2 hours, replaced oil drain seal for new whilst on with it. Checked wastegate with mityvac and set at 1.1bar so all good. Smoke tested for leaks.
Smokin
EGR put back to standard to eliminate leaks. Still leaks very slightly on smoke check but not bad so thats as good as it gets i guess, rest of pipework ok. Anyway test run and all good, performance good, done ten mile or so and removed egr to check for oil and all dry so id say thats job jobbed.
Dirty d back in one piece.
Now its back to good running order its upgrade time. The original wheels were in poor shape, lots of corrosion and needed a refurb as the bead area was in poor condition. Did consider refurb but if spending money might aswell get something different as not really keen on the originals. Have been looking for a while at various sets of wheels and had agreed to buy a set of comp mo5 but deal fell through at last minute.
Looking through fb marketplace i noticed lad i know was selling a set of mk1 clio 16v steel spare wheels. I dont mind the look of them and fired a message over, next thing im on a roadtrip to Lincoln last week to collect.
R26 on wheel collection duties.
1x set of et35 15x6.5j valver spares powdercoated in matt black. 2x new uniroyals & 2 knackered uniroyals. My current michelin crossclimates are around 4-5mm so got them swapped over off the original wheels and fitted today.
Steelie crew.
Much better than the corroded originals. Et36 also sits a bit better.
Stuck a bid in for a private reg JB03JON on ebay and ended up winning too so stuck that on.
MLB
I just love that you have apparently have a collection of spare old turbos to go through in case one of the fails 😍
Brigsy
  T.Turbo
Im a bit of a parts hoarder but pays off sometimes. Lockup needs a big clearout can barely get in:LOL:
  • Haha
Reactions: MLB
Brigsy
  T.Turbo
Updates.
Blue dci running great. Has not missed a beat and around 198,500 miles now as had a few site visits at work.
When i repaired the xenons on the blue clio, i stripped the ns light down, and whilst it was apart i cleaned the dome of the xenon projector. It was covered in filth and looked milky like a cateract and simply needed a wipe over revealing a really clear projector, simple job as headlamp front was off. I didnt do the drivers side as i couldnt be bothered splitting the light and in use the light output was s**t in comparison, and quite obvious when driving at night.
Had a spare hour yesterday so whipped headlamp out to see if it was possible to remove the xenon dome without splitting the headlamp. Its not possible to remove it fully as access hole is too small, but i managed to rotate it 180 to be able to clean the front and the back of the projector..check out the filth causing crap light output and pattern and the clear projector where i rubbed the dirt.
Filthy.
Forgot to take a pic of it before refitting but its same as passenger side now and looks really clear/great light output. Highly recommended if your xenons are not great at night.
Cateract gone.
Also give it a wash as wanted to try out my new resin watsr filter. No drying needed and no water marks, well happy.
Clean.
Brigsy
  T.Turbo
Update.
Been using the orange dci this week. Was sat there with half a tank of fuel and not moved for a few weeks so seemed sensible to get it used. Started up as normal no dramas, however when driving noted a bit of vibration/pulsing from o/s wheel when braking. Discs had a bit of rust on so give the brakes a high speed clean up. It mostly cleared but still noted a bit of rumbling fron higher speed braking.
Had a spare hour today so pulled wheel off the o/s to have a look. First thing i inspected were the discs and pads, pads moving fine and overall no issues as only renewed in December. Had the bar out checking for play in suspension components and noted bottom balljoint had quite a bit of play. Changed it for a new one i had in stock that @Krarl kindly donated a while back.
Clio life.
Bolts put up a bit of a fight so got the grinder on the case.
Done in an hr, no play again. Checked n/s and all good no play in any components so expected it to be resolved.
On test drive noted same issue from higher speeds, no difference. I get the feeling an abs ring may be cracked/on its way so will check that next.
Brigsy
  T.Turbo
Update.
Boot lock solenoid failed to commence on the orange dci. After several replacements in the past its a ten min job to swap.
Trim off.
Offending locking solenoid, one torx screw and out
When it failed last time i bought a chinese spec solenoid off ebay. Fitted that and remembered why i did not use it as the motor makes an awful noise. Looked at original to see if i could repair, and the gears were jammed as a rubber part had deteriorated stopping the mech from moving. Cleaned the rubber and old grease out, bit of silicone grease and working fine again.
Chinese spec top, oem bottom
With repair, working as intended again in 20 mins.
Brigsy
  T.Turbo
Orange dci update.
Used orange dci all last week. Had a couple of start up/conk out then start up ok on 2nd attempt chucking eml on briefly. Assumed fuel system issues and scanned with clip to diagnose.
Can clip diagnostics
A few faults stored but no fuel related codes. Digging a bit deeper reveals
DF023 Flywheel signal sensor circuit - 2 def tooth signal missing - crank sensor related
DF125 Main relay - 1 def relay cut too early so relay poss on its way
DF048 Fan - Be relay or wiring at a guess
DF037 Stop switch - 1 def coherence - fcuk knows, it done the immob red flashy a while back.
Deleted them and DF048 fan comes straight back, and fan does not trigger on actuator test. Open fusebox to look at relay and bit of corrosion/relay not fully inserted as top of fusebox knocks it when refitting as crap fit.
Corrosion visible.
Clean up the corrosion, fault clears and fan working on actuator test. Refitted fusebox carefully to ensure relay stays seated.
I then pulled the main/locking relay out and checked for corrosion. Was ok, so changed relay for a good used spare.
I then removed the crank sensor to have a look to see if end was covered in s**t. Noted the end has rotted to a point - that is clearly the issue. Actually resistance checked ok.
Id say thats about knackered.
I briefly cleaned and refitted this as no spares and it did not fail to start again so prob could have limped on a bit. Ordered a new aftermarket sensor and it arrived and fitted today in ten mins.
Super easy to change with long 1/4drive extension.
Fired up straight away and faster than usual. Logged fuel pressure on clip and flys up to over 230bar so assume still OK. No fault codes returned since so id say its job done.
Blue clio update.
Running absolutely fine. Went to Doorslammers/Santa pod in it last weekend 450ish miles, 69.3mpg. Its getting close to the 200k now.
214 miles to go.
@Martin_172 kindly donated some van spares for it, rear trims, spare window blanks and floor panel. I was missing the upper rear plastic trims and had cut down car trims which didnt fit great but were passable with carpet bridging the gap. With the vans being rare ish id not seen another set for sale.
Had a spare hour today so stuck them on. Looks much better with it all fitted and no gaps.
Van upper plastics in situ.
Ive got a week or so in the big smoke coming up with work so should see 200thou soon.
Brigsy
  T.Turbo
Used the orange dci today.
First run out after new crank sensor. Its made a massive improvement to starting and idling from cold. All the time ive ran it (around 45k miles) its started quite harsh jumping into life, then idled fairly rough from cold but fine when up to operating temp. This was quite annoying on short journeys with engine bouncing at traffic lights etc, i assumed this was an injector on its way and expected it to fail at some point so left it before it got expensive chasing the issue.
Noted today that it started faster from cold and smoother start without the engine giving a kick when it fires. Cold idle is now smooth and no more bouncing your tits off. Never thought crank sensor would be the cure, the sensor resistance was a mile out when checked and rotten point on it, i guess its not been reading the flywheel as good as it should and coming into somewhere near spec when hot.
Needs a good clean up at some point. Ill do it soon.
Brigsy
  T.Turbo
Updates.
Quick clean up for both dci's on Sunday.
Blue one got a hoover too as doing a load of miles this week, working in Hackney for a few days.
270 miles today as had to make a detour to Peterborough en route. Ive parked it at the hotel and on foot/uber for site visits as the roads are pisstake around here 20mph speed limits and cameras every 200 yards and permit parking everywhere. Cant wait to go back oop north :LOL:
Brigsy
  T.Turbo
Updates.
Done loads of miles in the blue dci lately and around 203k now. It was due an oil and filter change so done it last Sunday.
Sealey vac pump to drain.
Valvoline synthpower 5/40and purflux filter.
Done until 210k.
Nice and simple 20min job.
Ive moved a few sets of 18" wheels about in it recently. Fit better in this than the megane!
Flob
Its a cheap car, use cheap oil they say..... 203k miles with proper servicing says different!
What do you think of the sealey vac pump mate? I have an electric one but its a bit of a faff.
Brigsy
  T.Turbo
Was always told that buying decent oil is cheaper than a new engine, and its served me well.
See so many people chucking asda's finest cheap oil in half decent motors these days.
Sealey vac pump works great. Ive had this one for 15 years maybe longer, its had loads of use. Pump up and give it ten mins and your done, no messing about with batterys etc. Pipe is like air line, stiff but flexible enough to get to the bottom of the sump easy.
Brigsy
  T.Turbo
Updates
Changed pollen filter in blue dci last week. I always forget to do this and god knows when i changed it last, so was pretty grim as expected.
Insurance is up on both dci's. For some reason these have always been a bit dear to insure for what they are and always around mid to high £500 to insure. Ive shopped around and never seem to get it any cheaper so have been with elephant for years.
Renewal came through for me and the mrs on both at £319..ill take that!
Brigsy
  T.Turbo
Took the orange dci out yesterday as i had to move it off the drive to get the blue 225 out of the garage.
Not used it for ages as it needed fuel and couldnt be arsed to fill it, but had a bit of spare time yesterday so stuck some in. Bit of agressive braking soon de rusted the discs. Flys along as usual.
Out of all the cars i own this is still a great car to drive. Corners really tight and you can just drive it flat out everywhere.
Headlamps need a once over and a coat of something on the paint before winter. Will get a half day on it at some point.
Brigsy
  T.Turbo
Update.
Give the scuttle panel on the blue dci the ceracote ceramic trim wipe treatment. Fiddly to do in situ without removing wipers etc but managed it.
Before, faded to fcuk.
After.
Night and day difference. Should last ages too as the bits i done on the kangoo are still spot on 12months later.
Brigsy
  T.Turbo
Updates.
Snapped the original dipstick ages ago on the blue dci when i was doing a leakoff test. After buying several aftermarket shite ones listed with correct part number that were either incorrect length, incorrect fitment, crap quality or all 3, i finally found an oem ren one for sale (or thought id found one!?).
Hit buy it now on ebay, first one fails to arrive and seller says no problem ill send another. It turns up and looks like aftermarket to me, looks like seller had dressed it up in an oem bag but mine turned up without a bag conveniently.
Anyway it seems to be better quailty than the plastic aftermarket one i was using that was loose as fcuk/like a floppy c**k, oil level marks are in the correct position and its metal so it will do.
Dipstick saga, why so many different ones
That will do i guess. Should have just tried to order from dealers orignally.
After this i give the orange dci headlamps a polish as they were looking a bit crap.
Usual faded clio2 headlights.
Ive done several headlamp restores on these and i normally wetsand but skipped that stage. This time i just ran a heavy cutting compound with a medium pad and finished with a final polish/finishing pad. Literally ten mins and done. All yellowing gone, headlamps are not perfect but decent improvement
Much better.
I then give the headlamps a go over with a ceracote trim wipe. Also panel wiped all the plastics down and done them too.
Ceracoated trims ftw.
Hours worth of work and its transformed, as faded plastics always make a car look old/s**t.
Ive tried loads of permanent trim restorer ceramics over the years and the ceracote ones win hands down. Honestly wont get a better lasting product as its been tried and tested on my kangoo and no fade, and ideal for using outside as goes off in an hr. Not expensive too, absolutely recommended.
Klumpy Dumpy
I had the same f**k about with the dipstick for my Megane
Every single one that arrived the cap was either wrong, the stick wasn't long enough or it didn't seal. In the end I bastardised the original lid onto a decent stick and it was fine after that
MLB
Those wipes do look like they work wonders. Where's the best place to get them from?
Can they be used on headlights as well?
Brigsy
  T.Turbo
Painful experience aint it, why renault designed about ten different dipstick types for k9k is beyond me. Had same saga with megane f4rt, all different.
I got last box from Amazon in link below.
They looked like a cheap thing but when tried absolutely amazing. Ive used them on headlamps on both dci's and the r26 and appear to have lasted well. I think they do a headlamp kit too but prob the same thing.
I even done my composite front door with one and it restored it, leaving it gloss finish looking like new.
Before vs After. Still looks the same gloss finish 1 year on with sun on it all year.
MLB
Wow that is seriously impressive! And they work on headlights as well? That's great, Clio could do with a refresh of the headlights!
Brigsy
  T.Turbo
I always polish the lights first and use the ceracote for uv protection. Seems to last well.
The plastic dipstick are a nightmare to read with new oil too.
They are a nightmare to read. Only accurate way is to pull stick out on a cold engine and read the level. If you redip it, its half way up the stick
Brigsy
  T.Turbo
Updates
Pre mot checked the blue dci on Sat. Quick jack up and all looks good, floorpan etc in really good nick for a 22 year old clio used in all weathers. Not much to note, front tyres need changing sooner rather than later, whilst in the air i greased the brake pipes and selecror bush, front brakes were squeaky so deglazed/chamfered the pads, half hours work. Should be ok for a clean pass come mot time in a week or so.
In other news i got an oem renault boot flexi liner. Its listed for clio2 and other models of the era.
Renault oem accessories.
Tried it out today as doing a tip run. With it being a one fits all, it kind of fits where it touches but not bad overall.
2mins work to chuck it in, stops the back getting coated in s**t.
Cost £7 so worth a buy. After tip run there was loads of grass shavings on it, quick dust off and back in the bag and no cleaning needed.
Current mileage of today, 204125.
