182 Titanium Yorkshire B Road Project
f**k chatgpt off for starters :LOL:
Voltage should be 13.8+ when running. Id verify with test meter.
Needs scanning with clip to see whats stored. Might be pedal, tb or wiring at a guess.
im f**king useless with a wrench, as you can see by this thread.
checked with a volt meter and was much lower, highest it got to was 12.8v
Throttle bodies were redone by MS engineering recently so I am pretty sure thats ok. wiring very possibly as ive had all sorted of electrical gremlins but thought the UCH had sorted that.
So battery light is on and when the car is running your battery is showing 12.8v across the two terminals when you check with multi meter? If so your alternator is almost certainly done. You’ll enjoy changing that at the auxiliary tensioner if you’ve still got all the ac in place mate 😂😂
This is my set up but it doesn’t have AC
Gave everything a wiggle and the throttle pedal connector a clean and plugged back in. Started up and all lights out and running normally again, ordered a new throttle pedal. Voltage is still low on the multimeter when running 12.5v
Aux belt was slipping and not charging, new aux belt and a new throttle pedal thrown at it. Saved me a few quid and lots of pain hopefully.
Weather looks good this weekend so will head out and give it a little shakedown.
Not sure what kit it is, garage did the belt change, so hopefully competent enough that if anything needed doing they got it done. Appreciate the insight!
New accelerator pedal arrived today, checked the connector and all looks clean and tidy on the pedal end, wires look in good nick too.
Fitted the new pedal and did my usual short B road loop, no issues, no lights, running much smoother with the new aux belt too. Will take it on a bit of a longer drive this weekend and see if anything else crops up.
Fingers crossed thats it ready for the track season, already booked croft, oulton and donnington for the next 3 months.
Put a few miles on the car to make sure nothing else is going to go bang before the track. All going well. Gave it a clean yesterday and despite stone chips and a few areas of lacquer peel it scrubs up well. It also needs the sill which was welded properly prepped and painted.
I am planning to get rid of the car at the end of summer (maybe even CSF), wife is pregnant so doubt I will get much use out of it once the baby arrives.
so not sure I want to spend more money tidying it up when I’m never going to get my money back on it as is. It’s probably worth 3.5-4.5k as it sits? I bought it for 4.5k and probably put £3k into it so far.
Congrats on the baby news!
Glad the volt issues are sorted. First rule of selling up - don't add up what you've spent on it! :ROFLMAO:
Thanks mate.
To be fair its been so much fun and scratched a long standing itch (not contagious). Don't cry because its over, smile because it happened.
Well, I may retract my previous statement after yesterday! Took a trip to croft for the first track day of the year. 100 mile round trip and 150 miles on track and the clio was perfect. Need a track specific pad because the brake fade was real but apart from that it did really well. Nice to finally meet the legend that is @Brigsy as well.
That being said, I did get a go in a caterham which was WOW and I fit...just
