My valver/172 project
yeh geesus :)
the project is starting to get to me now :(
got the deadline looming and it still needs so many more bits to get it running :( :(
Reckon I still need:
172 downpipe - hopefully getting this tomorrow (and hopefully it'll include the lambdas!! but knowing how much i seem to have been stitched up on parts, it wont
idle control valve
crank position sensor (bought, but not sure when it will arrive)
vacuum tube for fuel rail
bracket made up to support the mk1 fuel rail
coolant temp sensor!! (why is this missing?!)
bit of pipe for one of the breathers (I think)
roll pin for the driveshaft (gave my last one away, I'm too kind ;))
2x adapters for the heater matrix (after the pipes were chopped, they're too small)
then I need to wire up the mk1 fan and get a fuel pump relay (it works atm, but on a constant live only)
I need to get my alternator charge light to work too
then things like guages etc would be nice
I need to find out why my aux belt is jumping 1 tooth towards the engine too
and ofcourse I need to see if this engine will actually work (or else Dan if you're reading this, I know where you live!!)
Nice one on getting it running! Will it idle? Take is that puff of blue smoke was just oil in the head after the rebuild?
yeh, i need to fit an ICV still :(
the battery is weak as fook and i dunno if the alternator is charging properly, so maybe it was just drained...
but im happy! :p
:D :D
well chuffed with it!
I just need to find somewhere to make me a downpipe tomorrow and ill be ready! :)
the problem i had is there is an 'earth' which seems to have about 80k resistance on it? hadnt connected it to the engine... as soon as i did, it fired in to (asbo) life!
Beanie, could you give me a clue as to how to wire up the coolant temp guage and the rev counter (even if it only reads half for now?)
plugged in my fan relay... and now my fuel pump primes! :p crazy thing!
I'm insured on it (172 and mods declared!)
I taxed it today (and declared it as a 1998cc)
It has MOT (even though its been rebuilt :D)
the coolant is in! (my hose adapters arrived)
all I need is my exhaust really, the a few little bugs to iron out, like a coolant fan and the idle control valve and a bracket for my fuel rail
tomorrows plan is the exhaust though...
Got a downpipe off a pug 405 which fits the 172 manifold!
but the fun will be cutting and welding it to fit my existing exhaust :(
progress! :D
Good lad! How the hell did you find out that about the 405?!?!?!
Have you seen the forecast?! Need some thermals!
that earth you were on about, towards the back of the engine is it? around the starter area ish?
yeh (thermostat housing as it was easiest :p - need to move it somewhere more secure i think)
spent all day today running around trying to sort my exhaust...
cut and measured all the pieces myself under the car and got them welded up
looks brilliant, but the bend right after the flange is about an inch and a half too far away from the flange, so i need to chop a section out and get it welded to bring it closer ... it just hits the bulkhead atm :(
so close!! :(
What bore size is it matt? Looks a tad small in the pics
You could use this one as a template now and go get yourself a nice stainless made up
the 'old' looking bits are my old 16v exhaust.. so only 2" i think
not measured the new stuff, but it looks big! :p
but yeh, at some point i'll replace it with a bigger size
the fact im not running a mid box or cat should help though?
it's alive... sorta...
it runs but then after a while just dies :( - looks like its using oil too, but im not sure if thats cause the engien was completely dry before and the oil is still finding its way around?
exhaust is on
i have gears
ive adjusted the clutch pedal so i can actually select gears... :D
problem i'm having is that the car will start and idle fine... occasionaly it might cut out... but restarting it is impossible :(
Im using a CTS out of a 1.6 as it looked the same :p - could this be causing issues, i've heard of this sort of problem being CTS related...
i reckon that could well be your problem
can you cross reference the part numbers and see of they are the same?
ive got my old cps sensor in the garage if you want to try that (i put the new one on thinking that was causing my starting problem)
give me the part number for it tho as ive mixed the valver one up with the 172 one :o
the connectors are different :p
ive not got any lambdas connected.. would that fox it?
the 2 black cps sensors i have both fit the same plug?! its the new blue style cps that has a different connector :S
i've only got the upstream lambda connected
oooo
i still need to post your crash switch!!
I completely forgot
no worries, in no rush
