Nafoff
sicktorial
actually love that
actually love that
Oh have you thought about wrapping the Manifold as its off?
As above, get it ceramic coated - not fabric - it makes the perfect wick for any resident oil leak for example.
Cracking project - wish I had time. It's how an RS should live it's second life![]()
what power and torque you hoping for with te new spec?
nobody on here has used the cams which i have used so im not sure. The 422's which are the slightly milder cam produce around 235/240bhp so i would suspect around that. Not sure on torque tbh.
Carl
Carl
What cams are you using mate?
standard valves with uprated springs? ...
with 422s K-tec were trying to use (I scrapped it) nimonic valves which use a strengthened alloy. Which I'm pretty sure is totally unnecessary on f4r
Looks brilliant mate
Im using Catcam 423 cams with standard valves and catcam springs:
5502423
292 / 284°
255 / 247°
11.25 / 11.25mm
3.95 / 3.40mm
custom
HYDR: rally & race
These were the wildest cam i could go for without using solid lifters, i did look at the 551/552/553 cams but they all require solid lifters, which would have added the engine price on top again for the lifters which i was not prepared to pay.
Carl
news???
